#26 |
Re: Having the shocks relocated is the only way to fly!!CPP shock relocation kit!
#27 |
Jeff,
I just need the upper mounts as I have porterbilt arms, what kind of price on just the uppers and bolts? |
#28 |
Bump...
#29 |
#30 |
#31 |
Is this like going to a car lot & the sales guy says "let me check w/the mgr..."?
#32 | |
Active Member
Danny Nix CPP |
#33 |
Here is a better way to explain it. You are on that car lot and your boss tells you to sell all the toyota's for $15,000 and out of nowhere one customer just needs the rear half of the car and salesman still wants to help customer but needs further guidance as he is not familiar with that territory.
#34 | |
I've got grease on my mind.
With the new brackets the shocks sit much more upright. In the ride department, I went from full compression to full extension over speed bumps and hitting pavement cracks on the freeway at speed. It actully feels like I have suspension now. |
#35 |
Good pics. Thanks
#36 |
The key detail the relocators show is the pics is increased travel range.
Look @ the initial pic & you can see the upper/lower shock housings (1st pic). Just under the edge of the upper shock housing you can see a silver colored decal on the lower housing. Notice the distance is greater between w/the two w/the relocators installed (3rd pic)? Same shocks w/more travel.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-12-2010 at 06:24 PM. |
#37 | |
#38 |
awsome pics, thanks. i def need to get a set of those pretty soon.
67 chevy 402 BB w/ TH400 Learning as much as i can before i dig in!! |
#39 |
#40 |
Jeff,
Any reason you are no surrounding the lower shock hole with some metal on both sides for the bolt to pass through? I think you you guys recently released a piece that fixes that issue for the front upper shock hole where it connects to the frame. One would think over time it would fail like the front upper on does.. Just food for thought.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
#41 | |
#42 | |
Active Member
Danny Nix CPP |
#43 |
Man this thread is old, any chance your still offering these to members for 50?
#44 |
CPP Rear Shock Relocators are great!
I've had them on my ride for two years and they still look new! Highly recommended. Heavily constructed. Dano
![]() ![]() It ain't yours, if you didn't build it! |
#45 |
Speedway has the CPP relocators for $59.99, just put mine on a few week ago!
=MATTHEW 69 Stepper...Stroked & Bagged ![]() 2003 Chevrolet Z71 Ext. Cab 1995 Cavalier gas saver! |
#46 |
#47 | |
Pic of 60-66 lower shock mount: ![]()
#48 | |
#49 |
Jeff your the MAN! thanks again for the hook up on parts. Always a pleasure doing business with you.
#50 |
