01-28-2010, 10:28 PM | #26 |
Re: Automotive clearcoat on bed wood, how do i get the color?
I would go with a marine grade varnish...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
01-28-2010, 10:41 PM | #27 |
I liked the Satin look, this is what I used. 4 coats brushed on both sides of the boards required 2 quarts. This stuff can't be sprayed and you must be careful to avoid bubbles.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
01-28-2010, 10:49 PM | #28 |
You can now get water based satins in any color (actually a dye). My local Benjamin Moore store has a full set of wood dyes. You dye the wood to the color of your choice and then use the finish of your choice.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
01-28-2010, 10:51 PM | #29 | |
PITbut
I think Minwax helmsman spar urethane is marine grade. Its just the best i have found so far after doing TONS of reading. ahah.. I was going to go with pelucid with helmsman over that.. Then found out you cant stain under pelucid. So im just going to go with a good stain and tons of helmsman. lol
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
01-29-2010, 04:57 AM | #30 |
Can you use a red candy paint to get the tint
70 SWB STEPSIDE 70 BLAZER 09 challenger |
01-29-2010, 05:58 PM | #31 |
PITbut
Got some info for you guys if anyone wants to hear. Minwax got back to me and what they recommend on using on truck wood is.
Dear Del, The Wood Finish Stain does not contain UV inhibitors. The stain color willfade quickly once the Helmsman Spar Urethane begins to breakdown. Use theGel Stain and Helmsman Spar Urethane for the best outdoor stain and finishcombination. Maintain the Helmsman Spar Urethane by lightly sanding andre-coating as needed. I hope this helps! Thanks for contacting Minwax. Regards, KimMinwax Product Support So, looks like i have my combination. lol..
01-29-2010, 09:02 PM | #32 |
I used some marine stuff. Mixed a few cans of quality stains to achieve what I wanted on scrap. Then used the quality marine coating on top. Nothing is going to last for ever. However something designed for UV/ sal****er protection has to last longer than what you would get from another source. Talk to a guy who does restoration on boats. Thats where I got my ideas from. They have been dealing with UV and extreme conditions for several years. They know what works and what doesn't. Comparing outdoor furniture coatings or doors to what goes on a boat are different applications.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" Last edited by Sammy; 01-29-2010 at 09:04 PM. Reason: sp |
01-30-2010, 03:58 AM | #33 |
i was reading thru this thread and i just have to say that the bed pictures on the previous page are amazing! wow!!! unreal man...
time and money... ....mostly money |
01-30-2010, 10:10 AM | #34 |
'71 chevy s.bed/s.side
I used Bristol Finishes Marine Amber Clear. It is a 2-part mix. I applied 4 coats of that on both sides, ends & edges, then sanded with 400 grit and applied 2 coats of Sherwin-Williams Automotive Ultra 7000 clear, sanded with 400 grit and finished it off with 2 more coats of S/W clear. Alot of work, but it looks good and it is well protected.
I would stay away from the Minwax/Thompson's, etc. Go with a premium Marine finish. You won't be sorry.
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
01-30-2010, 10:31 AM | #35 |
i am new here, but i have had some experience with wood. i would recommend a hardwood instead of pine. it is much more durable. walnut is very dark brown or black and would be hard to get a red tint. mahogany is a natural red wood and is less expensive that teak. as far as finishes, nothing holds up as well as marine finishes. if it rains a lot your part of washington, moisture will be worse on the truck bed than kids' feet. as noted in posts above, each board needs to be completely sealed (especially the ends). if moisture gets in through the ends, all the hard work is for nothing.
'79 Blazer (pushtruck) '68 C10 (under construction) just think, 100 years from now, all new people Last edited by AZTowman; 01-30-2010 at 11:27 AM. |
01-30-2010, 01:49 PM | #36 | |
PITbut
01-30-2010, 03:24 PM | #37 |
This is what I used: Not rocket science, I just sticked to a wood finish. Select the shade of oil based stain, Minwax carries various shades. Then seal with Minwax Helsman outdoor urethane at least three coats. After it is totally cured dry, you may want to try sand lightly with 1200-2000 sandpaper and buff for a cristal clear gloss.
01-30-2010, 04:01 PM | #38 |
I work with wood al the time and the Helman's is an awsome product, I have never shot it before but it works great from a roller. Minwax has about every color you can think of for stainging the wood all types of colors. I have used the Helman's on every outdoor product I make it good stuff. I don't know if you plan on putting anything in your bed but pine is very soft and dents very easy, but it is easy to work with. I fyou can get some pacfic northwest lodgepole pine it has much tighter grain and is more dense then the southern pines, since it growes slower. Just some thoughts.
02-01-2010, 04:50 PM | #39 |
not sure if it is available in your area, but alder is a hard wood that is very economical. the grain is usually not as interesting and i am not sure what the current price difference is, but check it out. be sure to get plenty of the product you choose on the ends of the planks.
'79 Blazer (pushtruck) '68 C10 (under construction) just think, 100 years from now, all new people |
02-01-2010, 05:00 PM | #40 | |
PITbut
02-02-2010, 05:01 PM | #41 |
Alder is a very good choice for a bed and has a very wild grain, but is a bit more spendy if you want it clear. Pine is good just look for grain that is very close together (rings per inch) in the boards you pick out these closer rings have a stronger and more dense with makes the boards stronger.
12-05-2012, 08:51 PM | #42 |
I am about to start applying product to my pine boards. I decided to go with POR-15 pelucid, I am not sure what to use as a UV protectant top coat? I did research via mark-k. They used helmspare. Any better suggestions that will work with the pellucid?
12-05-2012, 09:57 PM | #43 |
What's the goal here? You want to tint it and then be able to throw stuff in the back without damaging the wood "too much"?
I agree with a lot of the other guys suggestions and look for more of a Marine grade products. I did mine with Carolina Ash with 2 coats of Minwax Medium-Oak and then 4 coats of the Marine Spar-Varnish. Oh and remember to sand between all coats of Varnish. Good luck. Post pics on how it goes and the finished product.
1968 SWB. GMPP 350/350 Turbo Trans, Edelbrock Performer & Carb. Hedman Hedders, Hooker Aerochambers Mufflers. Tuff Stuff Alternators. Remember, no matter where you go, There you are. Gary |
12-06-2012, 04:59 AM | #44 | |
now your color, fitz is right a dye would be best, stains will fill in wood pores a dye coats the walls of the pores accentuating the grain. be carefull i used an automotive blue for the stain on oak once appeared more greenish than blue . if you decide on a varnish use epifanes http://www.epifanes.com/ used on some of the best yachts in the world for its high UV rating if you are lookn for a high quality " glass" finish you may try a wood filler to fill the pores & to go one step further color it to accentuate the pore again. Do a sample first i can give a few more tips if you let me know what you are shooting for show or driver? color matching your body color etc. perhaps something really trick like sprinkling wet metal shavings on a prepared wood surface let dry blow off the shavings. i read a comment here once bout sanding down to a 400 grit......no no. you are then polishing the surface, no finer than 220 grit hope i made some sense its late here & this is my forte,its a blast tricken out some bed wood have fun with its a large part of this project that can make it as sure as it can break it theres a lotta great tips here like botie suggestion to coat top bottom & edges all with an equal amount of coats<<<<<very important tip.
1990 chevy 4x4 with a 1940 IHC body Last edited by peglegs; 12-06-2012 at 05:05 AM. Reason: additioal info |
12-06-2012, 12:09 PM | #45 |
Proprietor of Dale's Corner
How bout spar varnish? It's designed for marine apps and weather and you can get it in high gloss. I've used it on the wood in convertable top bows and model a wood in the body with fantastic results. I believe it was a minwax product purchased at a Benjermin Moore store
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
06-12-2013, 01:24 AM | #46 |
Are any of the beds in this post exposed to weather ?They all look great but Id be curious if they would last over a 2 year period before peeling and discolouring if not kept in the garage.
I have been doing some research on tung oil.A coat once every 2 years without having to remove the wood to do it. Mar-k has done extensive tests and results prove there is no product that lasts longterm. Thoughts anyone ?
Always a place in my heart for old Chevy trucks: My build thread-project truck dream 65" http://67-72chevytrucks.com/vboard/s...d.php?t=510863 |
06-12-2013, 07:52 AM | #47 |
There is no way that you can have a pretty glossy truck bed that sits out in weather and expect it to last more than one season. The best you can do with an outdoor wooden bed is to think of it as the same as your deck. Go look at deck treatments. Even then, expect to refresh it on a regular basis.
06-12-2013, 12:05 PM | #48 |
I am a Referee of life.
Look at the boards over on td&ttt. IIRC the Forums are Mikenchell.com.They build teardrop trailers and coat them with a clear waterproof epoxy.They then suggest auto clearcoat for the UV protection. "SPOILER ALERT" If you don't need a small light camp trailer to look good and tow behind your classic rig,just search for wood finish info.
BTW Their forum is a lot like this one.They have about the same rules and expect about the same amount of civility or maybe a little more(less banter amongst members).They tend to be a bit "Green" also.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 06-12-2013 at 12:11 PM. |
06-13-2013, 12:19 AM | #49 | |
Thank you, Ed.
06-13-2013, 08:50 AM | #50 | |
