Old 05-15-2011, 02:12 PM   #26
52 Rat
52 Rat's Avatar
Re: Trailing arm length, C-Notch Placement
Guys, I just picked up a new set of NASCAR trailing arms this weekend. My concern is the U bolt size and the axle seat hole location. Keep in mind I am installing the arms in my 52 AD project using a '70 trailing crossmember. The U bolts I have are 4.25" not 3" like the stock axle seat. The guy I purchased the trailing arms from supplied the new U bolts and nuts. I need new trailing arm axle seats and from what I am seeing on line, they are all for 3" axle tubes not 4.25". What am I missing here? Any advise is greatly appreciated.
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671
52 Rat is offline   Reply With Quote
Old 05-16-2011, 01:18 AM   #27
Blue666
[Guys, I just picked up a new set of NASCAR trailing arms this weekend. My concern is the U bolt size and the axle seat hole location. Keep in mind I am installing the arms in my 52 AD project using a '70 trailing crossmember. The U bolts I have are 4.25" not 3" like the stock axle seat. The guy I purchased the trailing arms from supplied the new U bolts and nuts. I need new trailing arm axle seats and from what I am seeing on line, they are all for 3" axle tubes not 4.25". What am I missing here? Any advise is greatly appreciated.]
The U-bolts lay diagonally across the axle housing rather than perpendicular to the axle housing. The extra 1.25 allows for the extra distance of the diagonal.
Is there a spell check in the quick reply? Way too early in the morning for a spelling test.
Blue666 is offline   Reply With Quote
Old 05-16-2011, 09:34 AM   #28
52 Rat
52 Rat's Avatar
Awesome! I ordered the weld on axle seats from CPP this morning.
Old 05-16-2011, 10:04 AM   #29
Bartonius
Bartonius's Avatar
Blue666, that makes sense, I had a spring shop bend me up some dropped u-Bolts for 3 inch tubes and they took some persuasion to get into the NASCAR arms.
'65 BBW LWB/Pile of Parts
http://picasaweb.google.com/barton.michael.e
Bartonius is offline   Reply With Quote
Old 05-17-2011, 01:08 AM   #30
Captainfab
60-66 Nut
If those new U-bolts are 4.250" center to center, that is about right. That would make them 3.50" on the inside. With the angle of the trailing arms in relation to the axle tube, that is what they should be. If they are indeed 4.250" on the inside, then that is a bit wider than they need to be. If you need a set of custom trailing arm mounts let me know.
