Old 01-31-2010, 09:52 PM   #26
Strut
Strut's Avatar
Re: Questions for under bed gas tank guys....
Here is mine:
Hope it helps....
1972 Chevy C10 SWB
1999 GMC Sonoma Mini
2008 Yamaha R1
2007 Harley Nightster
Strut is offline   Reply With Quote
Old 01-31-2010, 10:27 PM   #27
SCOTI
SCOTI's Avatar
Originally Posted by Strut View Post
Here is mine:
Hope it helps....
This is the direction I'll go if I route a straight pipe up from the tank inlet. What did your 'hinge' come off of?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-01-2010, 11:05 AM   #28
SCOTI
SCOTI's Avatar
ttt
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-01-2010, 01:47 PM   #29
Strut
Strut's Avatar
It came off a late model Dodge truck I think.... it was an extra just layin around the shop, so I cut it up and used it. I think that anyone will work.....
1972 Chevy C10 SWB
2008 Yamaha R1
Old 02-01-2010, 02:23 PM   #30
OJ1988
Just a car guy
OJ1988's Avatar
Strut, what size fuel cell, and how low does it hang?
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 02-01-2010, 02:38 PM   #31
SCOTI
SCOTI's Avatar
I figured as much but thought it would be good info to know regardless. I have an old license plate flip bracket I was going to use. They're spring loaded to close & have a ratchet position to stay open as well.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-01-2010, 02:53 PM   #32
Rollie396
someday it will be done!
Rollie396's Avatar
FWIW I had an old one ton with a deck on it,that would not take fuel.I found out that if I drove up on a 4x4 block so the fuel fill side was higher,it would take fuel without any trouble.I don't imagine you want to be doing that everytime you fill up,but it does suggest the problem is in the angle moreso than the size of pipe.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 02-01-2010, 03:24 PM   #33
redbaron69
redbaron69's Avatar
strut that looks great man. just one question, have any you guys had ground clerance issues? planning a 4/6 drop. pics of how low the tank sits?
69 short fleet 350/350 "under construction"
70 short step 307/3 speed
redbaron69 is offline   Reply With Quote
Old 02-01-2010, 03:46 PM   #34
SCOTI
SCOTI's Avatar
That's part of my issue w/the limited amount of slope.
My tank was being raised for better ground clearance but the drawback is the fill line angle. I'll prob resort to the straight up fill if I keep the *cheaper* re-pop blazer tank so that I maintain my amount of planned clearance.
*cheaper vs. aftermarket fuel tanks/cells
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-02-2010, 10:00 AM   #35
lakeroadster
I got an invite PM from Scoti to share my modifications. Always glad to help so here goes:
What kind of tank did you use?
"Tanks" P/N 51-CG. It is a stock repro 1949-52 Chevy passenger car steel tank
How did you route the fill line?
Modified 1937 Ford filler neck that I bought from Bob Drake Reproductions P/N 78-9034-B $35.00
What size fill line?
2 inch. The "key" here however is that the tank has a 1/2" vent line.
Any problems w/modern pumps 'shutting off' during the fuel fill process?
I have yet to fill this tank from a filling station.
My '65 C10 gas tank relocation is my 3rd custom gas tank installation. The first was a custom stainless tank I built for my Model A Ford, the 2nd was for my Model T Roadster Pickup. Both cars are V-8 fenderless Hot Rods. I have used a vent line on all 3 and have not experienced the fuel belching problem on any of them.
The belching problem is due to pressure build up within the tank due to inadequate pressure relief. If the fill line is a straight shot down into the tank the pressure vents itself during filling (that's how our OEM tanks work without a vent line and why you fellas with the rear mount top fill tanks in the bed don't need a vent line.) If you have any bends or elbows that causes turbulence during filling, the tank can start to build pressure. A vent line coming out of the top of the tank will solve this problem. However the vent line needs to be installed with a "roll over" valve so that in an accident if the vehicle rolls over gas won't run out of the vent line.
Here are some pic's of my installation. (Notice the vent line adjacent to the fill line.) For more data, including pricing and part number data, check out my build thread.
I hope this data helps....
lakeroadster is offline   Reply With Quote
Old 02-02-2010, 10:29 AM   #36
SCOTI
SCOTI's Avatar
Thanks!
Our mounting placement is similar but your 'fill pipe' extends much higher as mine is just above the bed floor (@ 3"). My concern was I have to 90° turn 3" under the floor to get my < 5° slope & I feel that 90 such a short distance from the cap/opening is going to be my dilemma with or without the vent.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-02-2010, 03:15 PM   #37
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Idk if it will work on your year bed scoti but john fabris(hope i spelled his name correct) fills his rear tank through the steak pocket hole.... Just an idea..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-02-2010, 07:19 PM   #38
Strut
Strut's Avatar
Its a 16 Gallon fuel cell from Summit. I cut the last brace under the bed to get it closer to the bed floor for clearence.
The tank doesn't hang any lower then the rear bumper.....
1972 Chevy C10 SWB
2008 Yamaha R1
Old 02-02-2010, 07:25 PM   #39
Strut
Strut's Avatar
My truck has a 3/5 drop and there is 13inchs from the lowest point of the tank to the ground.... I'll get a good side view where you can see the ground and the tank as soon as I can. Its pretty nasty outside right now......
1972 Chevy C10 SWB
2008 Yamaha R1
Old 02-02-2010, 08:26 PM   #40
lowbuck72
lowbuck72's Avatar
How about a pic of the van tank. Curious to how low it hangs down
lowbuck72 is offline   Reply With Quote
Old 04-03-2010, 06:15 PM   #41
milner
milner's Avatar
Not sure if these help or not but I thought I would post them anyway
http://67-72chevytrucks.com/vboard/s...ht=tail+filler
http://www.classicheartbeat.com/mark...t_gas_door.htm
355,vortec heads, Doug Herbert cam, Performer intake, 750 Holley, Hooker Comps, 2 1/2 duals w/Aero Chambers, 2500 stall and 3.73 posi.
milner is offline   Reply With Quote
