#26 |
Rollin Coal
Re: Broke the rearend.
I have three letters to all these import guys: God-Made-Chevy 04 GMC Sierra 2500HD Duramax ![]() 1972 Chevrolet C-30 Dually Pickup stock? 350 SM465 four speed ![]() 1977 GMC K-35, TH-400, 4X4 450 horse 454(dad's) ![]() 1993 Dodge cummins 5-speed DEAD!! ![]() |
#27 |
Several things here:
Burnouts on a peg leg axle will tear up the diff in no time. The spiders spin around the center pin at tremendous speed, they were never designed for that and will fail sooner rather than later. Don't do burnouts until you get a limited slip. Most likely you broke the pinion gear yoke as well. One of the little "nubs" that align the caps underneath the u-bolts likely sheared, but maybe you got lucky. The truck 12 bolt will survive some abuse, just stay away from big tires and clutch dumps or you will continue to break parts. If it ever starts wheel hopping on you, back off immediately or prepare for more internal damage. 10 bolt is a pretty decent axle, actually. The 88 and up with 30 spline axles are stronger than a truck 12 bolt because of the previously mentioned larger pinion diameter. The difference between 8 7/8 ring gear and 8 4/8 ring gear not all that significant. The 12 bolt ring gear bolts are smaller diameter and right hand thread compared to the larger diameter 10 bolts which are left hand thread so run without lock washers. I have built several that survived seasons of 1/4 mile passes in Camaros and Firebird running in the mid 10's. Most of a bolts bad rap is from the early 8.2 found in Camaros, Novas and Chevelles in the 60's and then with the 7.5 in the Vega, late 70's and 80's G-bodies as well as the F-bodies. The 10 bolt is certainly NOT an upgrade. Cheapest way out if you cannot re-weld yours is to just replace the whole thing.
#28 | |
http://community.webshots.com/user/hotrodhorn |
#29 |
Also, the tubes are steel, & the center is cast...that takes a nickle rod to weld, & by all rights should be pre-heated before welding , so the weld doesnt crack when it cools.
#30 |
Ooh... Good to know. Thanks!
#31 | |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
#32 | |||
"I ain't nobody, dork."
![]() Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#33 | ||
#34 |
I got the diff back to where its supposed to be, im picking up some nickel rod tomorrow and im going to give arc welding a try. Never done it, If i screw it up to bad, my buddy will take over. Im excited. I also noticed the center of the driveshaft bearng is toast. How do I replace it? Thanks!
#35 |
"THE GREEN GOBLIN"
I'd like to see more pictures of the damage where it needs to be welded if posible..
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
#36 |
![]() You can see where the axle tube is pressed into the diff housing. That circle is like a big spot weld they use to hold it in place. There is one on the front and the back. I will probably end up putting a bead of weld around the edge of the diff housing to hold it still. |
#37 |
Did the tube slide out any?
#38 |
I dont think so. We got the diff straightened out and welded, But I dont know how well those welds will hold. I think I'll have to keep an eye out for another 12 bolt and take it easy on this one.
#39 |
"THE GREEN GOBLIN"
WOW I have never seen that before I couldn't understand what was broke from the other picture you posted but now I can see what you mean. I was changing the oil in my diff this weekend and I was looking at those circle spots and thought they were fill plugs because I had never changed the oil myself and I din't know where the fill hole was but now I know.. Thanks for the extra photo..
#40 |
How much should a shop charge to get a carrier bearing pressed on? Is it something I could do myself?
#41 |
![]() Join Date: Nov 2008
That rear end is tweaked so bad it will never hold up with any type of repair. Your dealing with some big time forces on that rear end and if it is tweaked slightly out of alignment it will fail.
You don't want that rear end coming apart on the freeway or anything and 12 bolts are cheap. ....but if it does work it would be cool. ![]() |
#42 |
If you bring them the driveshaft and the carrier bearing, 10 bucks. You can do it yourself though. You can pull and replace a u-joint right?
#43 |
have you opened the cover to check for damage like shavings or broken gears?
#44 |
Iv been driving the truck around without problems so far, but I really want to replace the rearend just to be safe. Ok, So if I find a 12 bolt from a later 5 lug truck, is it a quick change to put my 6 lug stuff on it? Or does it have to be a 6 lug to begin with? Im not losing my rally's lol.
