02-08-2010, 09:08 PM | #26 |
70+ ( Old Skool Club )
Re: First time por 15 user?
Do you mean with rusoleum paint or do you think I might be better to go the powdercoat route?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
02-08-2010, 09:18 PM | #27 |
Watch out for your cornhole !
Well, keep in mind I'm a semi professional powdercoater. I powdercoat everything I own. But, trailer hitches are prone to rust anyway and you live up north somewhere. I'd assume you want maximum rust protection. POR15 does that in spades. I'd POR it and paint it with whatever paint you like best.
02-08-2010, 09:18 PM | #28 |
I will add that the first time I used it years ago I got some on my arm in a couple places and I found that if you cleaned it up right away with Lacquer thinner it came off easily.
I will also add that a spot on the back of my arm that I missed would NOT come off with anything (including lacquer thinner) after the stuff cured. I like the stuff but you know what they say, "Rust never sleeps" it will win eventually. Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
02-08-2010, 09:31 PM | #29 |
As long as you wash it off with solvent immediately while it's still wet, it's ok. But when it dries, you're stuck with it for a while! Acetone will take it off you while it's still wet.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 Last edited by dfwright; 02-08-2010 at 09:32 PM. Reason: grammar |
02-08-2010, 09:55 PM | #30 |
the best way to paint over POR15 is while it's still tacky apply the top coat// i used to spray rylon enamel over por 15 on my trailers worked real well and bonded better that way
02-08-2010, 11:20 PM | #31 |
Does anyone spray it or just brush it on? If spraying, how much do you thin?
02-09-2010, 12:08 AM | #32 |
Moderator
20%
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
02-11-2010, 04:12 AM | #33 |
Going to pick up my "POR 15 Starter Packafe" tomorrow!
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
02-11-2010, 10:43 AM | #34 |
Sofa King Crazy!!
Might as well do the whole floor.....and under the cab, and in the doors, in your fender buckets, cab corners, under the bed, frame, around the squirrel cage, take out the windsheild and POR15 where it normally starts to rust, dog, cat, etc, etc...... I put that SH*T on everything. Amazingly a quart did everything I just mentioned, applied with a brush!!! One thing I did not read in this thread is that less is more and that is very true with this product. It will bubble and look rough if you put it on thick. If you just get coverage on the metal, no more no less, then you will have a slick as ice surface that will be perfect for painting with a little scuffing.
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" Last edited by Slick67; 02-11-2010 at 10:44 AM. |
02-11-2010, 06:36 PM | #35 |
Another thing to consider is the fumes. It will get to you
after awhile. It is good to apply it in a well ventilated area and wear a mask. I have a 55 gal. metal drum over my well head. I got tired of them rusting out after a couple of years. I took a good drum; blasted it and painted it inside and out with POR. I top coated the outside, within the time window, with a good oil base enamel. It has been there for a least 8 years. It has been exposed to everything that nature dishes out including Hurricane George and Katrina. I checked it recently and it is still solid. There is a little surface rust around the top of the rim and on the top which is actually the bottom. Some water will pool on the top even though I notched it for drainage. There is no rust anywhere else.This might give you an idea of how long it will last. I have never had any luck storing it after opening the lid. I did the metal work on an old LaSalle a few years ago. The owner wanted it coated with POR. He had some POR in the original gallon can. He had used the "Screw-method" to remove what he used. It had been stored about three years and was still good. EdB |
02-11-2010, 07:25 PM | #36 |
I'm heading to Nevada next month and want to buy some POR-15 on the trip cause its half the price of what it is here in Canada. Can someone suggest a good place to buy the stuff like a good Autoparts chain store as I'm sure Wally world doesn't sell it.
02-11-2010, 07:52 PM | #37 |
I bought mine at a PPG Auto Paint store. You might try the POR website, if not, Google it.
02-11-2010, 07:54 PM | #38 |
Moderator
Try the POR website to find a vendor. None of the major parts chains carries it.
02-11-2010, 08:04 PM | #39 |
Kung Fu Master
I'm a little curious about the fumes myself. Charcoal mask or fresh air system? Or, just a well ventilated area.
72 GMC SuperCustom 4x4 1972 Chevrolet Cheyenne Super 4x4 |
02-11-2010, 10:18 PM | #40 |
The Older Generation
I bought mine at my local NAPA store. They usually have it on the shelf but happened to be out of it at that time. It came in the next day. $41.95/qt, It seems to be about the same price everywhere. I just use it in a well ventilated area and don't hang around when I'm done painting. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 02-11-2010 at 10:19 PM. |
02-13-2010, 07:50 PM | #41 | |
I've applied the "Marine Cleaner" to the Floor Pan and have rinsed and letting it Dry. The NEXT step is the "Metal Prep" which in the instructions, state after it is put on (and rinsed off), that it shpould be "BONE DRY" before applying the Por 15!!! So my question is, its 4:00pm here on the Left Coast. The Truck is in the Garage, but its 58 Degrees and cooling off fast. My thought process was to put on (and rinse off) the "Metal Prep" and let it dry thoughly overnight and apply the POR 15 tomorrow. That way everything is "BONE DRY" and there is supposed to be Higher Humidity tomorrow, which I'm told, Por 15 likes. Would it be OK to let it dry for 24 hours BEFORE I put on the POR 15? Will the Zinc in the "Metal Prep" still be good after drying/sitting there that long?
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" Last edited by wwotr; 02-13-2010 at 08:23 PM. |
02-13-2010, 08:13 PM | #42 | |
LockDoc
02-13-2010, 08:25 PM | #43 | |
Thanks LocDoc!!! I'd rather do it that way and be SURE everything was dry; then to "rush" it, and not get the results I'm looking for.
02-14-2010, 09:04 PM | #44 |
Put on the POR 15 Today.
Went really smooth and is still in the Drying Pricess (after the 2nd Coat). Pictures you ask!!?? OF COURSE! They can be seen at: http://home.pon.net/wwotr/towing.htm Scroll down to "Seat Installation", and click on the Thumbnails for Larger pictures. Again, thanks to ALL who participated in this Thread.
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" Last edited by wwotr; 02-14-2010 at 09:04 PM. |
