Old 02-11-2010, 10:04 AM   #26
68 TT
Still plays with trucks
68 TT's Avatar
Re: Power Window Wiring
Originally Posted by playinsafe44 View Post
Ok, so we are talking about two different uses for the relays. I'm going to go ahead and install the wiring using the single relay mod as shown in Fleet72's little sketch up. I don't expect this to make the windows perform any better than the stock setup, but it will make for a clean and easy install. The other relay mod would be to install 2 relays per door, one for up and one for down. This would take the load of of the switches, reduce the voltage drop, extend the life of the switches, and hopefully speed up the windows by providing full voltage to the motors.
I'm going to get the doors installed with the one relay for the harness just to get started. Once they are in I plan on tearing the doors apart to clean the tracks, rollers, insides of the motors and switches. I also picked up some garage door spray lubricant to slick everything up. Once I'm this far, I want to try the relay mod to speed things up (2 per door). I found this diagram that looks like it should do the trick. Let me know what you guys think. http://www.thestreetrodstore.com/Doc...icWindows1.pdf
Looks like what everybody was talking about. It should do the trick.
If anybody has a source to get the carbon / copper replacement brushes for our window motors please post up a source. The only article I could find the guy made his own out of larger plain carbon brushes.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 02-11-2010, 11:32 AM   #27
joe231
joe231's Avatar
I haven't checked prices, but I got this from a quick google search
http://www.boyocarbon.com/pro-copper-brush-E.htm
CHEVY ONLY
