Old 02-25-2010, 09:03 PM   #26
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
Re: rust removal by electrolysis
Originally Posted by Muleman100 View Post
Maybe someone can help me with what went wrong. I am using a 25 gallon vinyl cotainer. Made 4 electrodes out of rebar, cleaned them and placed them around the inside of the barrel. Used washing soda, 1/2 cup per 5 gallons. Connected all my electrodes in series with wire. Lowered the hood springs careful not to touch the electrodes or bottom of barrel. Hooked up the pos to the electrodes and neg to the hood spring and turned on the charger. I read where I should see bubbles forming on the hood spring, well that did not happen. I could not visibly see any action on the part. Is my charger set at 12volts at 15 amps too small for my 25 gallon tank? Or did I do something wrong?
Muleman, first, did the charger indicate any current flow, if not, then one of your connections (most likely the one at the spring) isn't good. If the charger did show a current flow, was the alligator clip in the solution? If it was, then the path of least resistance would be from the clip to the rebar, not through the spring. I clean a small spot on my parts where they will connect so the rust or paint won't inhibit the current flow. I also do not put the battery charger clamp in the solution: actually I don't even put the entire part in the solution, leaving the electrical connection site above the electrolyte so the current has to pass through the part.
Your battery charger is definitely big enough, you only need a couple of amps for this to work
Larry
fleetsidelarry is offline   Reply With Quote
Old 02-25-2010, 09:37 PM   #27
92gmc
Great info - Thanks
92gmc is offline   Reply With Quote
Old 02-26-2010, 09:36 AM   #28
Muleman100
Muleman100's Avatar
Thanks fleetsidelarry, I have the clamp touching the water. I am using the clamp from the charger attached directly to the hood spring. I will clean off a spot on the part and keep the clamp out of the water and see if it makes a difference. Yes, the charger was putting out. What do you think of placing another charger ( same 15 amps ) on the other side of the tank?
" I never think of the future. It comes soon enough " - Albert Einstein
Muleman100 is offline   Reply With Quote
Old 02-26-2010, 10:55 AM   #29
fleetsidelarry
Senior Car Nut
I wouldn't think that another charger would make much difference except on really big tanks. I Like 72's did a whole hood (earlier in this thread), but I don't know whether his had more than one current source. I only have second hand information on this aspect (my tank is a tupperware storage container, only 10 or 15 gallons), but from what I've read, more is not necessarily better when it comes to current.
Originally Posted by 63sbssbbw View Post
But where to find a charger these days that doesn;t have the short out safety built into it,I tried it with a new one and I figured that's why it didn't work
Also I have read 2 amps maximum and on another write up I read 6-10 amps??
T
63sbssbbw, I was curious whether you got your 'new-style' battery charger to work
Larry
Old 02-26-2010, 05:20 PM   #30
Muleman100
Muleman100's Avatar
Thanks to fleetsidelarry for making suggestions that got me on the right track. I am now removing rust by electrolysis. It turned out to be a faulty battery charger.
Old 02-27-2010, 10:30 AM   #31
Street Sweeper
Street Sweeper's Avatar
Has anybody ever tried this on a set of brake drums? I'm a little concerned about the embrittlement I've read about here. Not sure if it would be a problem or not.
Any thoughts?
Street Sweeper is offline   Reply With Quote
Old 02-27-2010, 02:14 PM   #32
Muleman100
Muleman100's Avatar
From what I have read there is no harm to the metal at all. Only the rust is removed and does nothing to the metal. I also read that you could not leave it in too long. That is the upside, after you put in the water and hook it up there is nothing to do until you take the piece out.
Old 02-27-2010, 07:15 PM   #33
1962k20
Originally Posted by jonzcustomshop View Post
now we just need a box big enough to fit a whole 60-66 cab in!
Guess I got an excuse ot get an inground pool!
1962k20 is offline   Reply With Quote
Old 03-28-2010, 09:32 PM   #34
bubba327
HOW long until spring??
bubba327's Avatar
I am liking this process! I cleaned up a a rusty set of springs in about three hours each.
Size:  33.1 KB Ready to paint!! Starting with red oxide primer
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 03-29-2010, 08:44 AM   #35
Muleman100
Muleman100's Avatar
I ct off a 55 gal poly barrel and I can put about 30 gal of water and soda mix in it. I attached four long pieces of rebar equally apart around the inside of the barrel and connected them all with heavy wire. Then all that was left was attaching the battery charger to one of the post of rebar and the other the the piece I want to derust. I have done about 5 parts but it is there and ready to use whenver. I like to use this because it works unattended.
Old 03-29-2010, 07:07 PM   #36
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Could you not coil the rebar to the inside diameter of the bucket or barrel?
Old 03-29-2010, 11:27 PM   #37
bubba327
bubba327's Avatar
I use a chunk of fencing that I rolled up and stuffed in the bucket around the outside wall. It works better after the galvanizing came off. I had to add a rebar or two at first. I use a steel tie wire with stainless hose clamp for the under water connection, then wrap it around the PVC pipe and clamp it down with the Black lead above water.
I have cleaned so much stuff since discovering this process, No more breathing rust dust with a grinder and wire wheel!! .
Old 03-30-2010, 08:41 AM   #38
Muleman100
Muleman100's Avatar
Just like bubba327 states anything you can wrap around the inside of the container will work. Like they say it is directional so if you go all the way around it is better. I am going to double the amount of rebar that I have even though mine works fine now. I really like this process it is easy,clean, just put it in and forget it for a while. Mine has a permanent place in my shop.
Old 03-30-2010, 09:43 AM   #39
slorio
slorio's Avatar
One note of caution on doing this inside your shop. This process generates hydrogen gas which is explosive. It is better to do this outside where you have some air flow to clear out the hydrogen gas than inside where it is trapped.
Regards,
Steve
New Orleans
slorio is offline   Reply With Quote
Old 03-30-2010, 10:30 AM   #40
andyh1956
you know one of my buddies has a setup like this in the back of his truck. he is making hyd gas & has it plumbed to the intake of the engine. he says he is getting free fuel, but he is on his third alternator. he has only blown up one generator so far. but this could be a whole new market- de-rust while you drive! just put your rusty parts in your hyd generator & by time your home from work parts are clean! hey i use 50 / 50 water & white vinegar to derust- wonder if the solution would benefit from vinegar in it?
andy
andyh1956 is offline   Reply With Quote
Old 03-30-2010, 11:19 AM   #41
Malibob
Malibob's Avatar
The smaller the charger the longer it takes. I used rebar too and it didnt seem to work as well. I did half a wheel and it stripped the paint and removed the rust. I thought it worked well, but took forever. I tried a smaller part and it went much quicker.
I would have to think there is some relation to what metal is "pulling" the rust to what metal is "dropping" the rust. I want to try a pc. of sheetmetal and wrap around the container then dip my part. Think it may work better.
This statement was made possible by a grant from this station and continued support from viewers like you.
Flickr
Malibob is offline   Reply With Quote
Old 03-30-2010, 01:17 PM   #42
Muleman100
Muleman100's Avatar
You are so correct slorio, I only keep it own when I have all three of my roll up doors open. I have left it on overnight but I have a full ridge vent and I open the doors immediately first thing in the morning. You offered some very good advice.
Old 03-31-2010, 08:05 AM   #43
63sbssbbw
UCA63
63sbssbbw's Avatar
Not yet Larry
But I did find an old school one and tried it out
After 3 hrs it only seemed to remove the looser rust,the tight surface rust was still evident,after leaving it overnight same thing
I'm going to play around with how I've got it wired up
The more I think about it : current takes the path of least resistance which is at the surface of the solution (this why fish don't fry when lightning hits the ocean),so I'm thinking I might try isolating an anode to the bottom of the tank forcing the current to pass through the solution instead of just at the surface
Any thoughts on this theory
Thanks,T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 03-31-2010, 09:26 PM   #44
Rhoff2009
Any thoughts?
It shouldn't cause embrittlement, the embrittlement would be caused when hydrogen from the solution gets trapped in flaws in the metal and the metal is allowed to cool down trapping the hydrogen in the flaw. I would think that would only happen if you had the drum at a very high temperature and immersed it in a bath of water with a high hydrogen concentration and then allowed it to cool. Like greater than 100 cc/kg high concentration, and since your tank is open to atmosphere the gas will just vent off, lowering the concentration.
Rhoff2009 is offline   Reply With Quote
Old 03-31-2010, 10:04 PM   #45
fleetsidelarry
Senior Car Nut
63sbssbbw: I'd agree that the current is going to seek the path of least resistance (which is one reason not to put anything carrying current into the solution but the rusty part itself. for instance, if you attach the battery charger clamp directly to the part and lower the clamp into the solution, the path of least resistance will be between the clamp to the rebar instead of between your rusty part and the rebar, and you'll reduce the effectiveness of the process) but I don't see why that "least resistance" path would necessarily be at the surface. It doesn't seem to be in the properly working versions I've seen, including my own.
IMO it sounds more like bad connections. As I mention before to Muleman, I make an effort to make sure that the current is going to and through the part. Over-night should show significant results.
It won't hurt to put an anode on the bottom but you'd have to be extra careful not to let the part to be cleaned touch it.
I guess your "new school" charger is still kicking off?
Larry
Old 03-31-2010, 10:24 PM   #46
fleetsidelarry
Senior Car Nut
Any thoughts?
Actually, from what I've read, the process does cause hydrogen embrittlement
Larry
Old 03-31-2010, 10:28 PM   #47
fleetsidelarry
Senior Car Nut
from an article on rust removal by electolysis in Rod & Custom:
Larry
Old 03-31-2010, 11:23 PM   #48
bubba327
bubba327's Avatar
So it appears that a little time in the oven at 375-400 cancels the excess hydrogen causing the embrittlement.
I agree with not exceeding the temperature suggested as tempered parts such as springs would begin annealing.
Well, I missed the one hour window on the coil springs , so I will let you know if they fail in the future.
Thanks for the updated information , keep it coming!
Old 04-01-2010, 11:21 PM   #49
tkeduk8r
tkeduk8r's Avatar
I use an old Hobart TIG/AC/DC welder as a power supply in my 55 gallon plastic barrell... Works very well and you can adjust the current to whatever works best for you... I like 8 amps personally, and have done many parts ove rthe years...love it!!!
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 04-08-2010, 09:49 PM   #50
Rhoff2009
I'm looking for some more info on it. Not to say that the article is wrong, I just think that more info is always better. I'm doing my brake spindles tonight, and i'm not all that concerned about it, but maybe I will find something that will tell me that it wasn't a good idea. I work in the nuclear field and the materials that we are concerned about hydrogen embrittlement on, are significantly different than the spindle I'm working on. While I do have my doubts, I will not say that it won't happen, you should always use your own judgement.
