#26 |
Re: CA Engine Swap Laws/Question
I called the BAR and spoke to some one there and they said same year or newer and/or same size or bigger. As i understood you could not go smaller in engine size. And per what ia was told it made no difference to go gas to diesel. But like the CA DMV it is most likley subject to the person you spoke to that day.
#27 |
Sounds like your on your way...
1995 GMC 4x4 1/2 ton 1999 Jeep Wrangler w/ 33's 68 camaro 350/350 1987 Chevy 3/4 ton 4x4 Suzuki DRZ 400s Dual Sport 1971 chevy long bed 2x4 194? Dodge 2.5 ton 1980 Chevy Cheyenne 4x4 1/2 ton I6/sm455 1989 Chevy V30 crewcab dually 454/TH400 |
#28 | |
Ironmonger
![]() Join Date: Dec 2004
Basically, the engine must be of the same year or later and must have originated from a vehicle of the same class (that is, no 8600GVW TBI 454s in passenger cars or sub-8600GVW trucks.) It must be equipped with all OE smog equipment including cats in the original location (usually this means stock exhaust manifolds, sometimes something EOd for the engine's original application.) In his case, the engine would have to have been a half-ton truck 454 ('90-93 4554SS) with the proper part serial #s and all the smog equipment for that application. It has nothing to do with the original type of engine, there are RX-7s running around legally with LS2s in them. Sometimes they get a bit persnickety about the details; I believe it's still the case that if you want to (legally) put a 351W in a Fox Mustang you need to have a block with the same part number used in the '95 Cobra R (the same block used in the '93-95 Lightning pickup and some other '90s half-ton pickups) because that was the only 351W passenger-car application of that era. There are some vehicles, like Fox/SN95 Mustang V8s, that come in for such scrutiny from the state on smog-check results that many smog-test outfits just won't even touch them. Vehicles 1975 and earlier are not subject to biennial smog inspection, but legally they're supposed to retain original smog equipment. I believe '66(?)-75 are still required to be smogged on transfer of ownership. There are still some counties in the state that do not require biennial smog inspection. Last edited by JEM; 05-17-2010 at 03:12 AM. |
#29 |
Thank god for Florida no emissions check
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] ![]() 1999 k3500 crew cab dually 6.5tdi/4l80e |
#30 | |
Moderator
![]() Join Date: May 2007
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#31 |
Moderator
This is 100% correct.
#32 |
I was thinking about this topic. What about a crate motor from the dealer, or a rebuilt from Kragen? Is there no numbers on the block? If I put a crate motor (similar to stock) or kragen motor in my 1987, I don't think anybody would ever call me on it, would they?? Not sure how that could even be enforced.
#33 |
This is one of the reasons I have a pre-1975...
FWIW, I bought my truck from a private party, transfered the title, and didn't need to do a smog check upon transfer. About 8 months later I did an engine swap in my truck with a brand new crate engine from Jegs. It's still a 350, but stronger and with a higher compression ratio. Although I don't need a smog inspection every other year, right now I have most of the smog gear still attached. I do plan on getting rid of the air rails at some point. I think AceX is pretty right on in the requirements in CA. I do have a buddy that tried to put in a 454 in his C10 when the engine blew, and it failed the test b/c the 454 wasn't available for his model/year. So the truck's been sitting for the last nine years behind his house, unused. ![]()
1974 GMC C-10; my new addiction 1998 4 Runner; daily driver |
#34 |
Well, God has nothing to do with smog check, but lazy, good for nothing eco friendly bureaucrats make these decision when persuaded by eco-lobbyist and test equipment manufactures. In the end it all means very little as China, as of today, is the biggest (and growing) car market in the world with worst emission standards overall. India is not too far behind. Do not see too many eco-lobbyists there! No matter how they (state gov, CARB, EPA) try to spin this 'clean air' is just another form of taxation and jobs destruction. Once government starts taxing you on something it is next to impossible to 'ween' them off! Had enough already???
//RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) ![]() New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
#35 | |
//RF
#36 | |
They may be jerks but it's still possible to title and license a 32 Ford runninng a mid fifties Chrysler 392 Hemi! |
#37 | |
On the other hand specialty constructed vehicles (without pre 1960 VIN i.e. before smog requirements) is a completely different problem when it comes to titling. For full gory details see here: http://www.dmv.ca.gov/vr/spcnsreg.htm You have to camp out (or make an appointment) around DMV on the first day of the New Year for a chance for 500 spots allocated for such vehicles!! http://www.dmv.ca.gov/vr/spcns.htm It is a royal pita, but it is an eco-bureaucrats dream! //RF
