Old 03-30-2010, 10:00 PM   #26
dan468
dan468's Avatar
Re: T56 into a classic
Originally Posted by capev86 View Post
nice thing about this trans is there are 2 pair of overdrive ratios available (and corresponding first gear ratios). you can have hot rod performance, big rig power AND drive smooth on the highway and get awesome (for a truck) gas mileage with a proper 6 speed. i want to put one of these behind a hot rodded 292 in an early 50's chevy 1 ton panel truck done up to look completely stock right down to the wheels (but with a modern chevy 8 lug chassis with IFS, sway bars and 4 wheel disc....some day)
.8 (5th) / .62 (6th) that would be great behind a 3.42, 3.73, 4.10, 4.11, etc
4.10 x .62 = 2.54 overall
.7 (5th) / .52 (6th) that would be awesome behind a 4.56, 4.57, 5.13, etc
4.57 x .52 = 2.38
5.13 x .52 = 2.67
6.13 x .52 = 3.19 (think rock crawler or stump puller with highway ability)
in comparison, a stock 700r4 in OD
3.07 x .7 = 2.15
3.73 x .7 = 2.61
obviously somewhere between 2.50 and 3.00 is good for mild highway driving (60-70mph). you can see why the 3.07 is a terrible choice in a truck.....it has to work too hard to make overdrive worthwile and so gas mileage is no better than with a more aggressive gear even if the rpms are lower. with OD and a 3.73 you get the best of both worlds! you obviously want to stay well above 2.00 unless you have a turbo diesel truck with a banks kit or other serious mods (tons of torque). tire height and chassis tonnage/primary use and driving pattern will also determine what you want to run. i love my funky 3 on the tree in my 72 burb 3/4 ton 2wd, but if it had been a floor shifter, i'd rip it out and put one of these bad boys in when i get my 406sbc in my truck!
so 3.73 is the best route?
68 C-10
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=414699
dan468 is offline   Reply With Quote
Old 03-30-2010, 10:46 PM   #27
Schwinn68
Schwinn68's Avatar
that's a sweet looking trans you've got there! I've got a nv3500 I'm swapping into mine. So you just ditched the hydraulic clutch and kept the stock mechanical linkage? If that's the case I wonder if I could too. That would make the swap much easier.
Ben
_____________________________________
1971 Chevy shortbed 350/4-speed sold
2005 Chevy Duramax EC/4x4
Local 597 Pipefitters
certified TIG MIG and stick welder
Schwinn68 is offline   Reply With Quote
Old 03-31-2010, 12:18 AM   #28
dan468
dan468's Avatar
I didn't see anything on the site I got my stuff from for the 3550
68 C-10
Build thread
Old 04-12-2010, 08:18 AM   #29
GKsport67
GKsport67's Avatar
Whats the estmated $$$ for the swap,i think it would be a THRILL to drive my cammed 327 with a 5 speed....daily!
GKsport67 is offline   Reply With Quote
Old 04-12-2010, 11:47 PM   #30
dan468
dan468's Avatar
Here's what I got:
800 for tranny
300 for shift location kit
170 for new input shaft
200 for the adapter kit
and it a SIX speed!! haha
68 C-10
Build thread
Old 04-13-2010, 12:08 AM   #31
srea76
srea76's Avatar
was polishing expensive?
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern"
1984 Silverado
Red Baron-72 c10 Project
srea76 is offline   Reply With Quote
Old 04-13-2010, 12:51 AM   #32
dan468
dan468's Avatar
800 for the trans, bell housing, and heads
68 C-10
Build thread
Old 05-19-2010, 01:03 PM   #33
mrgoodwrench_420
do you have any pics of the clutch actuator set up this is the part of my swap i cant figure out
68 gmc 1500 450 hp t56 project
2000 gsx6 750
96 lifted jeep grand cherokee
92 dodge shadow beater
89 prelude 4ws wifes car
mrgoodwrench_420 is offline   Reply With Quote
Old 05-19-2010, 01:32 PM   #34
twillie2460
twillie2460's Avatar
No I do not but there are some threads on this site that I will use alot of his setup at least on the trans side anyway. http://67-72chevytrucks.com/vboard/s...d.php?t=300087
This should give you a good ideas anyway. If you look I think there is a couple of threads on this though.
twillie2460 is offline   Reply With Quote
Old 05-19-2010, 05:33 PM   #35
Custom 68
Custom 68's Avatar
Originally Posted by dan468 View Post
I finished the Mid shift mod last night, it's pretty easy. As far as they hydraulic setup goes...I'm using my factory clutch stuff.
Dan, how tough was this mid shift conversion? I have a t56 but needed to find the info on this change. The one I saw looked pretty involved as far as taking the thing apart. I really hated to get it messed up before I installed it.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 05-19-2010, 05:42 PM   #36
twillie2460
There is a thread on here and I think is was Dan's that goes thru the whole processof moving the shift location. I just ordered my conversion kit yesterday and it will also have instructions in it.
Dave you used the factory clutch setup, you mean you set it up with no hydraulics?
Old 05-19-2010, 07:41 PM   #37
dan468
dan468's Avatar
Dave
Pretty easy it only took a day. I've never taken a transmission apart before (I took everything apart as opposed to leaving it mostly together because I had it polished) and it was very straight forward. I was surprised at how easy it was. I am keeping the factory clutch hardware and not using hydraulic.
68 C-10
Build thread
Old 05-19-2010, 09:14 PM   #38
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
It looks like he used an adapter between the t56 and his stock bellhousing. Using a stock bellhousing means that you can run the original fork, linkage, etc. I have never seen this route before and it has me interested because I was considering this swap but didn't want to convert to hyd.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 05-19-2010, 09:47 PM   #39
dan468
dan468's Avatar
I will have pics ASAP. I will use the factory stuff as much as possible. If you see items in the pics that aren't factory, it's for cosmetic purposes and the fact that the dropmember raised the engine.
68 C-10
Build thread
Old 05-20-2010, 09:18 AM   #40
Custom 68
Custom 68's Avatar
thanks Dan for the update. I had seen the instructions for the mid shift upgrade and it looked like it all came apart. I was not sure I wanted that but now I may rethink. I have a T56 for my 5.3 swap I will give this some more thought.
Dave
Dave
Old 05-20-2010, 09:30 AM   #41
splehigh
splehigh's Avatar
Great thread! I may do this swap in the future also. It would be quite the upgrade from a 3 speed. LOL
splehigh is offline   Reply With Quote
Old 05-20-2010, 06:19 PM   #42
Nova_Cobra64
Nova_Cobra64's Avatar
How necessary is the mid shifter if a guy has bucket seats? Or in other words how far back does the stock t56 shifter position sit inside the cab? I found a guy selling a t56 out of an 02 f-body that he now has in an s-10 behind a sbc using a belhousing adapter. I am assuming if it is a comfortble location in an s-10, I'm thinking it should be fine in this situation too.
I wanted to go TKO for simplicity, but the pricing on this about 1/4 of what the TKO setup would run me.
2004 Silverado - Beater
1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683
2011 Aveo - Work commuter
2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck.
Nova_Cobra64 is offline   Reply With Quote
Old 05-21-2010, 12:08 PM   #43
dan468
dan468's Avatar
I do not know as I didn't mock it up prior to changing the location
68 C-10
Build thread
Old 10-12-2010, 03:49 PM   #44
MB_70
I did this a MUCH harder way ..... AND more expensive !!! GLAD that this thread exists .. because I would do this again.
You can use any automatic transmission crossmember from a 67-72 truck (no modification needed). I used a TH400 mount with metric bolts into the casing. You do have to slide it back on the frame.
I used a new speedo cable for a 67-72 truck with a TH400. Its long enough.
THANK YOU LEEVON for sending this to me, I like !!!!
I enjoyed the highway MUCH more with this transmission in my truck. The mileage was better, but I expected better. I only ran 29" tall tires, and a 3:73 at first. A 4:56 is VERY deep, but if I could go back, I would do it better, and run taller tires with the same gears.
MB_70 is offline   Reply With Quote
Old 10-12-2010, 03:58 PM   #45
dan468
dan468's Avatar
There's more to come, I'm having problems with the pilot bushing narrowing when pressing in and I'm pretty sure I used the wrong bell housing. That's the curse of having parts everywhere I guess
68 C-10
Build thread
Old 11-29-2010, 12:24 AM   #46
ozman3803
Any updates I may have found a t56 if the price is right!
ozman3803 is offline   Reply With Quote
Old 11-29-2010, 03:07 AM   #47
dan468
dan468's Avatar
Sorry, school has consumed my life. I will be continuing in about 3 weeks. Not sure if I'm going to update this thread or just do my build thread. Keep an eye on the build thread...
68 C-10
Build thread
Old 11-29-2010, 04:05 AM   #48
vortech71chevy
there are other ways to do this swap. if you have a 1 pc rear main seal sbc, you can use factory LT1 flywheel, clutch set, bellhousing, hydraulics, and pilot bushing. its super easy, i had it in my 72 camaro and recently began swithing everything over to the 71 chevy truck. check out nastyz28.com theres a ton of info on putting a t56 into vintage iron... or pm me.
vortech71chevy is offline   Reply With Quote
