02-20-2010, 08:56 AM | #26 |
Re: Custom radiator cover upper support
can't wait for the final pics, looks good. Might be in the market for one. Which radiator do you have installed?
02-20-2010, 09:06 AM | #27 |
1 thing at a time is progress.
Man that is sweet!
Alan
Philippians 2:14-16 |
02-20-2010, 10:35 AM | #28 |
Joe, what do you think about a panel to cover the grille/ core support area to match your rad cover painted to match the body color? just thinkin Pat
02-20-2010, 10:41 AM | #29 | ||
"I ain't nobody, dork."
Nice radiator cover!
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
02-20-2010, 02:53 PM | #30 |
I Like Mine With No Shine!
I was thinking about something similar....maybe continue the look all the way to the fender. It wouldn't really serve any purpose, but it might look good.
Michael 1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day) 2006 GMC Sierra Crew Cab 4x4 1969 Lincoln Continental Coupe Project FOR SALE http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17 1981 Honda CM400 C Bobber SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=384152 |
02-20-2010, 06:50 PM | #31 |
Sunburst C10!!!
i might be intersted in one
waiting on pricing though
Gage 1967 C10 Shortbed Stepside |
02-20-2010, 07:34 PM | #32 | |||
I'll have pricing very soon. Last edited by joeelutz; 02-20-2010 at 08:05 PM. |
02-20-2010, 08:46 PM | #33 |
Pricing and availability
This is what everyone's been waiting for. I appreciate everyones patience. I have the full covers ready. Here is the reduced pricing. 1. Full Cover with standard V8 radiator $145 (this is what is on my blue truck) 2. Full Cover with HD V8 radiator $145 3. Full Cover with standard V8 radiator no holes $115 4. Full Cover with HD V8 radiator no holes $115 The partial covers are styled just like the Full Cover, but are shorter so that they fit between the stock mounts and are designed to work with the stock fan shroud. I will work on the partial covers later. Let me know if you want one and I will get to work on it. I am now accepting orders through my website at http://www.hotroddynamics.com/Products.html Use the drop down box to select which version you want and then hit the Add to Cart button. You will be transferred to PayPal to complete your checkout. Again I want to thank everyone for you support and feedback and if you have any questions please email or PM me. Joe Last edited by joeelutz; 03-04-2010 at 09:15 PM. |
03-04-2010, 09:26 PM | #35 |
Sweet! That looks great!
03-04-2010, 10:20 PM | #36 |
Life, Be In It.....
Can you show the under side of the finished product to show it's constructed and how the mesh attaches to the piece?
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 Last edited by jugernot; 03-04-2010 at 10:20 PM. |
03-04-2010, 10:23 PM | #37 |
I'd need the Full Cover with HD V8 radiator $145. What shipping would you offer to Nova Scotia Canada? USPS priority post is usually the cheapest and easiest at this end.
03-04-2010, 11:51 PM | #38 |
Joe, email sent.....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
03-05-2010, 01:45 AM | #39 |
these are sexxxxxyyyy !!!! ill be buying one soon !!!
03-05-2010, 12:39 PM | #40 |
I'm going to need one for a 4 core HD radiator and one for this:
http://cgi.ebay.com/ebaymotors/67-72...item518fbf57ba
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-05-2010, 12:47 PM | #41 |
I'm in the same boat with Hart Rod. I have an entropy tech radiator and the 4 core brackets don't seem to fit right. I am running a couple different scenarios on how to install this thing. It looks like you may have used an Entropy radiator also???
Thanks, JE
Project Burro Viejo: http://67-72chevytrucks.com/vboard/s....php?p=3778216 |
03-05-2010, 12:49 PM | #42 |
Now that I looked at the pic again, it's not an Entropy.
Do you have any underside pics of your radiator hold down? Thanks, JE
03-05-2010, 01:11 PM | #43 |
69 Fleetside
I just installed an Entropy radiator and have the smaller 3 core brackets. It fits tight and holds very well, but the bottom brackets had to be popped out, moved in a bit and re-rivetted in both spots. The driver side upper mount came over to the center a bit with the right screw hole using what was the left mounting hole and redrilling a new hole for the left hole of the bracket. I then used the same bolt, but put a nut on it to tighten it down. The passenger side bracket remained in it's original spot but I had to remove some of the bracket at the filler neck area...This was all with the radiator dead in the middle, where it should be.
Moral of the story is, this bracket, as fashioned, would probably not work with the 67-72 Entropy and you would need to send Joe your dimensions and have one custom made. Just buying this as is there are definetly a few tweaks that you would need to do to it once you shelled out the $145 - and that's no fun! These are the only pictures I have online right now of my radiator and I am at work(can't go out and take better ones), but you can see that it does fit well with the smaller brackets moved around a bit...and could really use one of Joe's covers!.. Last edited by Beatcoaster; 03-05-2010 at 01:12 PM. |
03-05-2010, 11:56 PM | #44 |
The radiator I'm using is a Champion radiator. http://championcooling.com/
It uses the 3 core upper brackets but was a snug fit. It looks to me like you could use the cover on the entropy radiator. Could someone give me the thickness of the tank where the rubber positions? If it will fit in the rubber, it should fit in the cover... I attached the mesh with SEM door skin panel adhesive. You can get it at NAPA or auto body suppliers. It's a 2 part epoxy. Pretty simple. This view doesn't show the sides very well, but the stock rubber pads fit against the side panels of the cover and just glue in place with weatherstrip adhesive. Once mounted in the truck they really can't move anyway. |
03-06-2010, 08:11 AM | #45 |
Factory the rads sit in the lower mount support brackets by the tank flanges and the upper brackets are suppose to go over the tank flange portion as well. It looks like you have yours holding the core. Is it because you didnt have the longer upper and lower brackets available? If you had used the longer stock 4core support brackets over the tank flanges I think it would have been a drop fit. I'm curious beceause I'm about to oreder the entropytec rad and tony said there were no fittment issues other than changing the size of the brackets if your truck wasn't origionally a 4 core, not bracket location. All the aluminum tanks are the size of the older 4 core rads.
03-06-2010, 05:15 PM | #46 |
Could someone please post the width of the entropy radiator tanks where the mount goes (front to back) and the distance between the tanks?
Thanks My Champion radiator fit the stock 3 core brackets just fine. The rubber went over the weld beads on the tank where the flange would be on a stock radiator. |
03-07-2010, 02:30 AM | #47 |
69 Fleetside
I will take better pictures and do just that tomorrow Joe!
03-08-2010, 12:05 AM | #48 |
69 Fleetside
Yes I did support mine at the core, not the edges of the flanges. The small supports work great if you do this.
Here are the photos with measurements... Stock mounting points on passenger side of truck Moved support over one hole and drilled new From flange point... To flange point Flange is slightly different on passenger side than.. Driver side, and I think the bracket would have to cater to the hose right there being so high... Let me know what other measurements you need!! |
03-08-2010, 08:16 PM | #49 |
Beastcoster, thanks for the pics!
From what I can tell from your measurements, it looks like the HD cover would work well with the entropy radiator in the stock location. You would need to use the 4 core rubbers or just cut some rubber strips to use from a piece of around 1/4" thick sheet. Only mod it appears you would need to make would be to grind some material off the DS rear corner of the cover just to clear the upper hose. No big deal. Last edited by joeelutz; 03-08-2010 at 10:34 PM. |
04-04-2010, 10:21 PM | #50 |
PM sent.
