02-24-2010, 06:32 PM | #26 |
Re: 572 update
here is the factory info
02-24-2010, 06:35 PM | #27 |
Re: 572 update
Actually those are Mr. Goodwrench uniforms.
02-24-2010, 06:38 PM | #28 | |
Re: 572 update
02-24-2010, 08:57 PM | #29 |
Re: 572 update
"swang"
1970 Jimmy 4x4 IL6 1971 Jimmy 4x4 350ci v8 1971 SWB 327ci v8 1972 Short Stepside 305ci v8 1972 Blazer 2WD CST LS9 350ci 4sp 1999 4 Door LB 1 Ton Old Body Style 5.7 v8 |
02-24-2010, 11:04 PM | #30 |
The Black Pearl
Re: 572 update
So What kind of motor mounts did you use?
02-24-2010, 11:38 PM | #31 |
Re: 572 update
I used the stock 400 big block mounts, have new poly bushings comming for them of course.
02-25-2010, 12:44 AM | #32 |
60-66 Nut
Re: 572 update
So you're using the original style '72 BB mounts in the stock BB location?
02-25-2010, 02:23 AM | #33 |
Re: 572 update
Not to thread jack but Fitz, do you have more pictures of that beast? Any vids? lol
'70 K10-- 4" lift on 35"s-- For Sale http://www.ksl.com/index.php?sid=733...iew&ad=4578305 |
02-25-2010, 01:36 PM | #34 |
Re: 572 update
So far thats whats goin on, stock mounts in the stock location, may need to modify a bit, depends on final clearances etc. waiting on the Tranny to arrive, and a whole lot of other parts. Big project short deadline.
02-25-2010, 02:04 PM | #35 |
Re: 572 update
hope the rearend doesn't end up on the ground the first time your foot gets heavy
02-25-2010, 06:55 PM | #36 |
Re: 572 update
Well here are a few more pics, some shots of the mounts, and clearance, and some test fitting of the headers (these are just for mock up).
02-25-2010, 07:14 PM | #37 |
Re: 572 update
did you have any clearance issues with the surp belt set up and the valve covers ?
02-25-2010, 09:08 PM | #38 |
Re: 572 update
Don't have the Serpentine setup in yet, on order, and the valve cover is giving me issue on the booster side, the booster on this c20 is 10 1/2" wide and doesn't leave much room at all, I will probably replace it with a smaller diameter one.
02-25-2010, 09:39 PM | #39 |
Re: 572 update
02-25-2010, 09:45 PM | #40 |
Re: 572 update
Oh and for anyone wanting to use a 4L60-E, 4L65-E, 4L70-E, 4L80-E, or 4L85-E you can get one of these and have no issues.
http://www.crateenginedepot.com/stor...57-P722C0.aspx of course though if you are using a carb setup you will require the TPS from Holley part #534-202 Last edited by handsomerob; 02-25-2010 at 10:50 PM. |
02-25-2010, 11:49 PM | #41 |
Re: 572 update
sorry handsomerob... thought those pics fitz posted were yours ... how bout you fitz ? any clearance issues with the valve covers and surp belt kit ?(i ask because i just did the surp belt kit and am now lookin for the valve covers ... handsomerob i think you should just pull those valve covers and give em to me .... no really .... swap to a hydrobooster for the brakes ! call the guys at tallonhydrolics.com ! thats who i used they are way cheeper than all the other guys.
02-26-2010, 02:52 AM | #42 |
60-66 Nut
Re: 572 update
A couple of the parts that I make and sell may help you with the booster to valve cover issue.
02-26-2010, 07:41 AM | #43 |
Re: 572 update
Very nice project! I would love to put a massive 632 in my Suburban, but I've spent to much on the vette!
Are you doing any driveline upgrades/ chassis strengthening? Other info for those that care...You can get standard deck big block capacities up to about 598ci (same size demension engine as your standard 396-454), then with the higher deck the skys the limit! well almost, You can easily get up to the 700+cube! Ive got a standard deck 540cuber in my Vett with 755BHP, You have to do some chassis strengthening and use a heavy duty drivetrain, otherwise expect constant breakage!
*1972 454ci Burb, C20 3/4T, T700, 2WD *1969 540ci Vette, 540ci Aluminum BB,755 BHP & 734 LbFt torque, No NOS, No Forced induction! Just BIG CUBES Last edited by 72 DIRTY RAT; 02-26-2010 at 07:53 AM. |
03-01-2010, 10:10 AM | #44 |
Active Member
Re: 572 update
Curious who you purchased the super-matic and the controller from? Have you received them yet? I've got more questions and notes to compare with you about this tranny set up however I don't want to swamp you...
"The Great State of Florida" |
03-01-2010, 01:20 PM | #45 |
Re: 572 update
Tranny and controller ordered right from GM as well as the Engine.
03-01-2010, 04:07 PM | #46 |
Re: 572 update
Buy one one please
03-01-2010, 05:45 PM | #47 |
Six in a row makes it go...
Re: 572 update
That is just an awesome piece of machinery.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
03-01-2010, 07:51 PM | #48 | |
Re: 572 update
03-01-2010, 08:57 PM | #49 |
Re: 572 update
those valve covers are sexy ... know where i can get some cheep ?
03-03-2010, 07:57 PM | #50 |
Re: 572 update
Well got the Breather in and the High Torque starter.
