#26 |
Re: Guage install
Looks awesome so far! The final look will be well worth the cost!
1976 C-10 472 Cadillac Big Block |
#27 |
GM Addicted
Re: Guage install
what size gauges did you have to use??
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
#28 |
Ironmonger
![]() Join Date: Dec 2004
Re: Guage install
I'm glad I didn't think of something like this a while ago, I might have spent far too much money...looks really good, though
![]() Last edited by JEM; 02-28-2010 at 01:30 PM. |
#29 |
Broken Down
Re: Guage install
I used the 5" speedometer, and tachometer. All the rest were 2-5/8" .
kenm78 1982 Chevy 4X4 Project truck ![]() ![]() ![]() ![]() “It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt” |
#30 |
Broken Down
Re: Guage install
Some wiring pics
#31 |
Broken Down
Re: Guage install
Another wiring pic.
#32 |
Broken Down
Re: Guage install
Dash torn apart.
#33 |
Broken Down
Re: Guage install
I know it looks like a fire hazard. But after their ziptied it doesn't look to bad.
#34 |
Broken Down
Re: Guage install
Finally installed..... I managed to keep the factory turn signal indicators in the OE spot. I had to add my high beam indicator in between the tach and speedo. and if you look real close you see a small green LED in between the tach and speedo at the bottom. That is my 4 wheel drive indicator light... All in all I'm glad its done I like it the only thing I don't like is when its all together you don't see the full faces of the speedo and tach. I need to figure a way to angle them up a little
#35 |
It followed me home?
Re: Guage install
looks good, how many hours in wiring do you think you have there?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 02-28-2010 at 01:51 PM. |
#36 |
Broken Down
Re: Guage install
About 3 hours for the gauges, and about 5 hours for the truck wiring including swapping oil, and temp sending units, and installing a speedometer sender. I'm not fast by any means.
#37 | |
Broken Down
Re: Guage install
#38 | |
Re: Guage install
Looks very cool none the less, would be nice if you could see the full face though. Good work!!
#39 |
Re: Guage install
Come on over to the store we'll work on it! I have tons of PVC!
#40 |
Re: Guage install
Buy you some gauges and we will figure it out!
#41 |
Broken Down
Re: Guage install
Might just take you up on that one day. I'm tired of messing with it at the moment. LOL
#42 |
Re: Guage install
Couldnt you just use the angled piece that you cut off the back?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
#43 |
Broken Down
Re: Guage install
I thought about that, but its too small I need it to go all the way around the gauge to make it look flush on the outside. I think PVC will be the best route Just not today LOL.
#44 |
yeller
Re: Guage install
I am pretty sure you can buy those angled pieces...check Summit, Jegs, or similar places.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#45 |
yeller
Re: Guage install
I can't find them for the larger gauges, but I am sure they make them
http://www.jegs.com/i/Auto-Meter/105...oductId=745211
#46 |
Re: Guage install
#47 |
Squarebody Aficionado
Re: Guage install
nice progress any more pics of the wiring or info on the way you wired it all up. as for angleing the gauge up try using these, they use them for boats, they are a bit pricey but they are really nice.
http://shopping.rexmar.com/Merchant2..._Code=458angle |
#48 | |
Broken Down
Re: Guage install
#49 |
chevy truck fan
Re: Guage install
kenm78,
thanks for the pics!! did you by chance make a wiring diagram of how you wired it?. i am just now starting the wiring of mine into my '72.... thanks again!! rodstored-72 |
#50 |
Re: Guage install
If you guys working on wiring don't want to go through tracing and wiring each component, Painless has a kit they offer and supposivly pretty detailed directions on how to hook everything up.
I personally have used the kit yet but I think a few other board members here have and have liked it pretty well, it's what I plan to use when I do my own soon. Here's the link to the one Jegs sells, they offer one for electric and manual driven speedo's http://www.jegs.com/i/Painless+Perfo...30302/10002/-1
Joe ![]() ![]() |
