Old 03-09-2010, 03:27 PM   #26
thepenguin99
Re: How can I relocate my tank....
Originally Posted by Crispyr1 View Post
Going to purchase a 75 lwb today for a donor. Will the gas tank off of it fit under the bed of my 68? Has anybody here used one of those? Also if i can use the 5 lug setup off of it that should mean that my stuff should go back on the other right? I'm just going to turn around and re-sell the truck after i'm done getting the parts i need off of it.
75 will have a tank that runs along the frame rail right behind the cab I think. Not what has been pictured. Also, the 5 lug rear on that truck will be leaf springs not coils. You could use the front but the front is also readily available elsewhere.
thepenguin99 is offline   Reply With Quote
Old 03-09-2010, 05:44 PM   #27
Crispyr1
Crispyr1's Avatar
I wasn't going to use the whole rear axle just the outers and keep my rearend.
'68 C-10 SWB LS 5.3L, 4L60E, 3:73 posi, Dakota Digital HDX Gauges, Boss 338's 18's front 20's rear. 3"/5" drop.
Crispyr1 is offline   Reply With Quote
Old 03-09-2010, 06:09 PM   #28
monte0185
monte0185's Avatar
That 75 is probably a 10blt axle. If so and IIRC the axleshafts will not swap. If its a 12 bolt though you can swap the shafts with no issue.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
