Old 03-02-2010, 07:58 PM   #26
bigblazerboy
bigblazerboy's Avatar
Re: 20 years later
good looking build so far. newer beds look better on this body style than the 67-72 thats for sure but they look good on some not all. might look good on yours
bigblazerboy is offline   Reply With Quote
Old 03-02-2010, 11:08 PM   #27
dgodecke
dgodecke's Avatar
Thumbs up Re: 20 years later
Originally Posted by 89muscletruck View Post
Another member on the board 85_praireboy has done the newer bed swap, http://67-72chevytrucks.com/vboard/s...d.php?t=371586 IMHO it looks pretty good, enough of the bodylines match up so that it doesnt look too unnatural. The new box would probably require some tweaking to look perfect but it could be done.
By the way sweet find!
WOW, thanks for that link it is what I have in mind and didn't know how the two would look together. That answers my questions.
07 Chev 2500HD Classic
Project Ranch Hand, Hauling A$$ since 1973
I was told this Project had a L-72 427 425HP, It did not.
It does have a 427 block and parts from various 427 motors. It will end up with a nice strong 454 in the end.
It has not been run for 20+ years
Frame up restoration started2/15/2010
dgodecke is offline   Reply With Quote
Old 03-03-2010, 01:26 AM   #28
centexan
Re: 20 years later
I have to admit, as a 4x4 guy, it's making me tear a little to thing this truck may be dropped. If I found that clean of a truck here in Texas I might have had to resort to illegal things to acquire it. It has everything I want EXCEPT the motor; axles, transfer case. WOW that is a find. I am definitely subscribed to this one. Got to love the GMC's. I have a '74 GMC Jimmy. GREAT score there buddy!
1989 Chevy Suburban v1500
centexan is offline   Reply With Quote
Old 03-03-2010, 11:37 AM   #29
jchav62
1962 C-10
jchav62's Avatar
Re: 20 years later
Nice truck! I can't wait to see the end result... The 427 is b!tchen!! I love that old intake and valve covers.
As for the later model bed, I think it will look good. The fender openings are similar enough and the body lines match enough to make it look right. I've seen those beds on older 60-66's and 67-72's, and to me, they look wrong.
Good luck!!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 03-07-2010, 12:44 PM   #30
dgodecke
dgodecke's Avatar
Unhappy Project Ranch Hand
Good luck!!
Well this 427 has turned out to be a problem. What was first billed to me as an L-88 turned then to a L-72 and now a L-Nothing.
The block and one head are the correct match for the 72. The other head does not match and in fact is even a different size combustion chamber!
The cam is not a Chevy cam but a weak Crane grind.
The block has been bored over .030 I will need to go farther to clean up one hole. How far I don't know and I don't know if I will have to sleeve it in fact. It has some rust pitting from standing with an open valve for 20 years.
The crank is an over the counter replacement crank, for a 427 but not out of this block or any block. They were sold over the counter or in a crate motor only.
Most of this I can handle and even expected to to deal with but the fact it doesn't even have a set of heads that match has bummed me out a bit.
A guy at work wants this block very badly and has offered a built up 454 in running condition in exchange for the block and parts "as is". the temptation is strong. I am looking at about $1500 to $2000 to get this 427 right and running.
Old 03-07-2010, 12:49 PM   #31
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Re: 20 years later
Sorry to hear about the problems on that motor. Even though the 427 would be cool to have, I think I would trade him for the running 454. Especially just seeing what Horsepower TV did on a "budget build" that aired this morning.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 03-07-2010, 01:13 PM   #32
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: 20 years later
not sure what your plans were on the 4x4 side but...if you'd like to make it permanent and clean up the floor at the same time...a NVG-149 AWD transfer case would get you there. Its the best AWD case available IMHO and has shown to withstand some serious horsepower. The nice thing about it is that it is a full time mechanical AWD, using a viscous coupler to transfer 38% to the front wheels and 62% to the rear...unless of course traction is needed differently and it can transfer up to 100% to the rear...or 100% to the front. A benefit in a truck is that the front wheels now help "pull" the truck through the corner, making it corner better. These AWD transfer cases have even proven to be better in sand and snow then 4WD.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 03-07-2010, 05:15 PM   #33
dgodecke
dgodecke's Avatar
Re: 20 years later
I saw that show also. I don't think I would build to that level but 400+HP would be just fine with me.
Old 03-10-2010, 02:18 PM   #34
Jhogan830
Jhogan830's Avatar
Re: 20 years later
beautiful truck man im subscribing =D
Jhogan830 is offline   Reply With Quote
Old 03-21-2010, 11:28 PM   #35
dgodecke
dgodecke's Avatar
Update: Project Ranch Hand
Well the tear down is nearly complete on the 73 GMC SWB. The 454 is here and checks out just fine. A good solid 450HP High Torque motor.
After a little cleanup on the firewall and inside under the dash it is time to sandblast the frame and start to work on the re-build.
I am not going to lift the truck and in fact will remove the extra spring leafs the PO had put in. This will allow about 2" of sag that I will adjust back with air bags at all 4 corners. Parked it will sit nice and low while on the highway it will be at normal ride height and if I want to go off the road I can take it up even more. I will put on some nice aggressive highway tires that will give me a full wheel well look.
Old 12-27-2010, 10:44 PM   #36
dgodecke
dgodecke's Avatar
Re: 20 years later
Well I have been moving forward on the idea and found a bed in great condition. Like you said it takes some tweaking to make it fit right but here is what it looks like now.
I also did the rear axle flip, removed 3 leaves from the springs and added air bags on the rear so I can level it out later on.
The gas tank is custom made to fit in where the spare tire was and tuck up tight under the bed.
Old 12-28-2010, 12:59 AM   #37
87 chevy silverado
Re: 20 years later
liking already
87 chevy silverado is offline   Reply With Quote
Old 12-28-2010, 02:45 AM   #38
maxxxy
maxxxy's Avatar
Re: 20 years later
I've been playing around with the idea of the newer bed and I decided it wasn't for me, but one of the things I kinda played with in Photoshop is to take some of the lower trim from a 88-98 and modify it for your truck, it seems to help tie the truck together better.
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 12-28-2010, 04:23 AM   #39
C-10 simplex
Re: 20 years later
What size are the tires?
C-10 simplex is offline   Reply With Quote
Old 12-29-2010, 12:06 AM   #40
zackary027
zackary027's Avatar
Re: 20 years later
HEY MAN DO YOU HAVE ANY MORE PICS OF THE BED IM THINKING OF DOING THE SAME TO MY 81 sorry for all caps i hunt and peck and just realized i messed up
zackary027 is offline   Reply With Quote
