Old 04-14-2010, 04:58 AM   #26
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
Re: Insert witty title here....
Mo pics
screamin_c10 is offline   Reply With Quote
Old 04-14-2010, 05:03 AM   #27
screamin_c10
Ok, just a couple more...can you tell I'm stoked....
Old 04-14-2010, 07:51 PM   #28
mikajo39
Gearhead and audio junkie
mikajo39's Avatar
Originally Posted by screamin_c10 View Post
Mikajo39 - What compression are you running? How well does it do on pump gas?
9.5-1 It runs alright on 91. wish I could run some more timing, but otherwise it's pretty solid On a 110 degree day if I'm running a few too many degrees of timing it'll ping.Otherwise runs good, most of my problems are with my carb(jetted too lean), edelbrock 600cfm, definitely not suited for the cam and quite a choke on the engine, since Edelbrock flows their carbs dry(no wet flowing) which boosts the CFM rating falsely. I have a 2500 Rpm stall converter and even with the 3.08 gear in the back it has plenty of get up and go and I can roast my right rear tire for 4 city blocks
mikajo39 is offline   Reply With Quote
Old 04-14-2010, 07:53 PM   #29
mikajo39
mikajo39's Avatar
WOOHOO! Stoked for you! can't wait till it's up and running! It's gonna be a solid and powerful motor you can enjoy for many miles!
