Old 03-15-2010, 07:37 AM   #26
menace121978
menace121978's Avatar
Re: wilwood d52 calipers
i agree! very nice man
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 03-15-2010, 10:18 AM   #27
thehitchmaster
thehitchmaster's Avatar
thanks!! its got a 5/7 kit.
http://www.gulftruckinc.com
thehitchmaster is offline   Reply With Quote
Old 03-15-2010, 12:12 PM   #28
gearhead1968
gearhead1968's Avatar
I already have Russell stainless steel break lines http://www.jegs.com/i/Russell/799/672300/10002/-1 , will they work with the calipers?
1976 C-10 shortbed 2wd (work in progress)
Mods:
Stock 307, 700R4 Transmission, Hurst Pro-Matic shifter, 2100 rpm stall converter, Headman Elite 1 5/8" headers, H-pipe, 2 1/2 exhaust through Magnaflow mufflers, 3.73 Motive gears, superior axels and Eaton Posi carrier
http://www.cardomain.com/ride/3136537
gearhead1968 is offline   Reply With Quote
Old 03-15-2010, 08:40 PM   #29
thehitchmaster
gearhead, if you look at the pics that i took of the back of the caliper its really not designed to use a block style fitting. I called wilwood and they told me to use a/n style brake hoses( thats why i got a little ill, wilwood says they "bolt right up" factory pads and rotors. but not brake lines wtf!!! ). the threads that go into the caliper are 7/16-20. I'm not sure what the hard lines are for our trucks.
I used my factory block style hoses i just drilled mine out so i could use a 7/16 banjo bolts. To answer your question, no those lines were not designed for these calipers. could they work, yes. If you want you can call wilwood and they will give you a brake hose part# for your app.
Old 03-15-2010, 09:44 PM   #30
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
are either of these the same ones?
http://cgi.ebay.com/ebaymotors/Wilwo...item56370a74e6
http://cgi.ebay.com/ebaymotors/Wilwo...item5ad5abbf3c
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 03-15-2010, 10:17 PM   #31
lolife99
67-72 parts collector,…
lolife99's Avatar
The later C10's (maybe post 1980) had metric calipers.
I believe they take a 10mm banjo bolt. I assume like yours.
The early trucks (71-80) took the 7/16-20 banjo bolt.
Keith
Convert to disc brakes.
Old 03-15-2010, 10:29 PM   #32
thehitchmaster
thanks keith. thats good to know.
Old 03-16-2010, 09:17 PM   #33
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Mighty nice looking calipers man. Looks great.
--Josh
Old 03-16-2010, 09:23 PM   #34
thehitchmaster
I'm happy with the end result. you guys are great, thanks for all the compliments. looking at all of your trucks makes me that much more motivated to get mine whipped into shape.
Old 03-16-2010, 09:49 PM   #35
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
are you going to do rear discs also?
staggerd86c-10 is offline   Reply With Quote
Old 03-16-2010, 10:03 PM   #36
thehitchmaster
yes. im gonna do a wilwood rear kit as well.
Old 03-16-2010, 10:08 PM   #37
staggerd86c-10
I was wondering if the brackets that blackbirds has for the rear can be bought by themselves and just piece the kit together as money comes along so its not such an initial cost. I have some extra calipers i have taken off cars at the shop that we have done big brake kits on and i have plenty of rotors what else would be involved in doing this. sorry for knocking on your thread but now that i know your interested in the rear too im wondering if someone can share some info.
Old 03-16-2010, 10:24 PM   #38
thehitchmaster
the blackbird kits are very nice and simple. you can buy their kit less calipers. they state on their website that they "do not sell parts separately". I priced their kit less calipers, and then added the wilwood calipers. doing it that way would be as much as buying a wilwood rear disc kit. so i'm gonna just do the wilwood.
Old 03-16-2010, 10:37 PM   #39
staggerd86c-10
what part number are you going to use for the wilwood stuff?
Old 03-16-2010, 10:45 PM   #40
thehitchmaster
http://www.wilwood.com/BrakeKitListR...=C10&year=1983
this is what the wilwood website pulls up for our trucks. I called them and they told me that i really need to check the axle tube flange, and also the distance from the backing plate to the axle. to make sure i order the right kit. this is from wilwoods tech.
Old 03-16-2010, 10:55 PM   #41
staggerd86c-10
see i think im a little more form then function, i would want a kit without parking brakes so that it matches the front perfectly. If i was able to piece together the blackbirds kit, i think it will cost me about 450 with the wilwood calipers.
Old 03-16-2010, 11:19 PM   #42
thehitchmaster
blackbird kit is $350 without the calipers. and i paid $165 a peice for the wilwood calipers. plus brake hoses $50 at least. I hope by ordering the wilwood kit without the drilled rotors and adding the red calipers it will look pretty close. I dont really care about the parking brake either.
Old 03-16-2010, 11:51 PM   #43
staggerd86c-10
i can get them at wholesale cost. and thats the case with the other parts too, the only thing that i would need is the brackets.
Old 03-17-2010, 06:49 AM   #44
menace121978
i'm going to have to get these now. the front calipers should bolt up to my blackbirds kit and they will match perfectly
"Dennis the Menace"
Old 03-19-2010, 06:39 PM   #45
smashingchuck
OK, what exact part number are you using for front calipers and what part number are you using for rear calipers?
I'm assuming you ar using the bigger piston calipers up front and the smaller ones for the rear?
Also, what thickness caliper does the blackbird kit use? 1" ?
78 Build Thread
4Runner Build
Old 03-19-2010, 08:46 PM   #46
menace121978
the blackbirds kit uses the larger caliper
"Dennis the Menace"
Old 03-19-2010, 09:03 PM   #47
smashingchuck
larger rotor thickness or larger piston?
78 Build Thread
4Runner Build
Old 03-19-2010, 09:06 PM   #48
menace121978
larger rotor thickness. basicly the 73-80 caliper.
"Dennis the Menace"
Old 03-19-2010, 09:14 PM   #49
smashingchuck
any body know what the black bird kit rotor application is?
78 Build Thread
4Runner Build
Old 03-22-2010, 04:30 PM   #50
thehitchmaster
I was curious as well, scared to ask lol
