03-15-2010, 06:36 PM | #26 |
Re: What happened to my trans???
I was just making sure because several of the guys on YellowBullet had me convinced that I could do it and it wouldn't cause any damage. I'm not gonna do it now...I'll probably just swap in a glide in a few months to see if that helps any.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH |
03-15-2010, 06:40 PM | #27 |
Usually you dont run a glide in a heavy vehicle. The th350/th400 is generally the better choice to get moving off the line. The first gear in a glide is 1.92ish depending on the unit. First gear in a th350 is 2.52 thats a huge difference when it comes to getting a vehicle moving.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
03-17-2010, 11:15 PM | #28 |
Finally pulled the pan tonight. No big chunks, just shavings every where. The whole inside of the pan was covered and the filter too. Hopefully its fixable.
03-18-2010, 01:43 AM | #29 |
Sorry to hear that bro. Hopefully it's not too bad to fix.
03-18-2010, 08:17 AM | #30 |
Only metal shavings? Or clutch meterial too? A bad torque converter will put a ton of trash in the pan.
03-18-2010, 08:54 AM | #31 |
It wouldn't have had the pretty red un burn't fluid would it? if it had clutch material? I killed several convertors in a truck that was pretty mild.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
03-19-2010, 12:09 AM | #32 |
The fluid didnt look bad in the dim underhood light. But, when I started draining it, it looked like a candy apple paint. I would say its about 50/50 trash and metal, tons of it. Ive got a scattershield and a few 4 gear pieces laying around and a parts truck with the pedal assembly. Thinkin about looking for a trans now.
03-19-2010, 11:28 PM | #33 |
OK sounds like you broke the sprag. The converter will smoke the fluid and turn it black. I just blew my tci converter 2 weeks ago. Fluid black as hell and tons of fine particulate in the pan. Any big chunks is likely a sprag or planetary. Its impossible to tell you 100% for sure without opening the transmission. I will say that since your unit was still functional and not making a ton of noise I would lean toward a broken sprag. The auto will always be faster just gotta put good parts in it. Manual trannies big on a whole other can of worms. Need good flywheel and clutch. Good shifter. If your going to beat on it you gotta make usre the trans is in good shape internally.
