#26 |
Who needs sleep...
![]() Join Date: Aug 2009
Re: Those with ECE 2" drop in front
Mine actually worked out as a happy accident, turns out I like the 6 in the back... we're pulling the front 2" drop springs this weekend and we're going to cut the stock springs to bring it to the height I want, measuring as we go. Then, in a couple months when my budget recovers, I'll use the 2" drop springs with the appropriate spindles to do it right..
I'll post measurement pics of my old and new this weekend when I pull them too. Trip |
#27 | |
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 03-09-2010 at 09:26 PM. |
#28 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Stan at ECE has always taken good care of me but there is one thing that confuses me about the deal. ECE doesn't sell any springs lower than 2 inch. I can't see how they could have sent the wrong springs. It's not like they sell 3 inch springs or anything.
I dug up some pictures of springs I have run in my truck. First picture is a Ground Force 3 inch drop coil that has settled after being run in the truck for awhile...10 inches ![]() These are new DJM 2 inch drop springs. Never been installed. They did settle about an inch after driving it a few hundred miles. Again, this measurement is out of the box brand new...12 inches. If I measured them now, I'm quite sure they would be about 11 inches since they took a set after use. ![]() You can barely see my bump stops in this picture. They are short Energy Suspension units from Summit that cost about 12 dollars. ![]()
#29 | |
Who needs sleep...
LMAO Sorry, couldn't resist. It is starting to look to me like the unsprung height widely varies, which make sense if the material and process is different, too bad it's so tough to measure the sprung height to compare across... TX Firefighter, any chance you could take a center of hub to fender well measurement? ~Trip |
#30 |
My measurements wouldn't mean anything. Those pics are of my 63 truck with 84 Suburban front suspension with drop spindles too.
#31 |
ECE may not offer more than a 2" spring but I guarantee you the spring shop that makes springs for ECE does. When I ordered ECE was out of stock. The springs were drop shipped straight from the spring shop. Seeing the measurement of your 2" & 3" springs makes me even more certain the springs I have are wrong.
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 03-09-2010 at 11:51 PM. |
#32 |
Not sure what the solution is going to be on this but Spring Specialties says they tested the springs and they should be a 2.25" drop. I have been talking with Stan @ ECE and we are still working on it. It just does not make sense for my truck to be on the bump stops if those springs were right.
This suspension was all the original from the factory front end parts when I took it apart to rebuild it. I replaced everything with Moog parts from ECE. It is the original control arms. Nothing is obviously out of wack. The truck sits level side to side. I'm tempted to order another set of springs from a different vendor just to see if I get the same results. I'm grasping at straws at this point. If it is something with the truck and not the springs I need to fix it. I just can't fathom what it could be other than the springs. Anyone got any other ideas? |
#33 |
Man of Mini-Talents
Since I posted here last, I got my 3.5 / 5 kit from ECE. My truck is a big block, and I specifically stated that when I ordered. The kit arrived last week, and the box containing the springs said 1" SB Chevy. Called ECE up and sure enough my order called for BB springs but they told whoever makes the springs SB.
No sweat, everyone makes mistakes, so they ordered a set of BB to be sent out. Today I get a call from the spousal unit that Fedex had delivered a box and I took off early to get to work on it. When I got home, the %$$@ box said SB Chevy!! I called them up and explained, then Jeff @ ECE suggested I mic the springs as maybe they just labeled the box wrong. The springs I got measured just a tick over 5/8 and he said SB Chevy should be 3/4. So I don't know what the heck they sent me. Now they're going to overnight another set so I'll get them Monday. I guess the story seems to be their spring supplier is having issues. Your idea of trying a different manufacturer may help solve the mystery. |
#34 | |
#35 |
Redefining LowBudget
I noticed in your pic that your bump stops seem to be pretty tall compaired to the ones I cut out of my truck...
if your going to do something outback flip your shock mounts on your axle it works very well and I'm using the monroe 5752 shocks up front...(50 chysler imperial)
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#36 | |
Short story is Coil Spring Specialties is confident their springs are correct for a 2" drop. They seem to think there is something different about my truck. They suggested that maybe it is actually a 3/4 ton frame or that the cross member is from a 73 &^. I am pretty confident that is not the case. They are building me a new set of springs. They should be here Tuesday. Stan @ ECE has put more effort into this than I ever expected. They have been a huge help. We are all a little perplexed. I started another post asking for spring dimensions for others with the factory 40 year old springs in the front here. The measurements of my springs seem to be pretty consistent with others. I will post more when I know more.
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 03-28-2010 at 02:52 PM. |
#37 |
I saw that and its what brought me to this post
I just measured my bump stops on my spare stock frame 3 3/4" from the LCA the rubber is 2 1/2" tall maybe that wil help
#38 | |
Bump Stop ~2.5" ![]() Mount ~1.75" ![]()
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 03-28-2010 at 02:15 PM. |
#39 |
The other thing Stan and the spring shop noticed is how compressed the spring is in this pic. As Stan put it "It looks like an elephant is sitting on the hood."
![]() As far as I know, there is nothing unique or changed about this truck. It is a survivor small block Cheyenne Super. The SPID says 350, the fender badges say 350. The motor appears to have never been removed. Until recently when I replaced the suspension parts, the front end was the way it rolled off the line right down to the riveted upper ball joints. My dad bought the truck with 107K on it back in the early 80's from the original owner. I took possession of it around 20 years ago when he passed. ![]()
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 03-28-2010 at 02:24 PM. |
#40 |
Here are a few more pics of the truck before I started the restoration just so you can see what I mean by a survivor. All I have done to the truck is carpet, seat cover, timing chain, HEI and now the suspension rebuild. My dad put the dual exhaust and rally wheels on back in the 80's. The paint was also touched up back when he drove it. You can faintly see the change in white over the drivers rear wheel where it had a few scratches. They also painted below the fuel fill and the front of the hood. You can also see a little white over spray on the drivers door jamb.
EDIT: Oh Yeah, I put a Z-Rock sticker on the back window back in the day. ![]() ![]() Maybe someone will see something from the pics that we are missing. ![]() ![]() ![]() ![]() ![]() ![]()
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 03-28-2010 at 02:39 PM. |
#41 |
Reading this Thread makes me think I'll just go with the Drop Spindles and play it safe. Thoughts? Al W.
#42 |
be right back I'l go peal the rubber out!!...LMOA
#43 |
LOL. Wait another week and we will probably have this resolved.
#44 |
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 03-28-2010 at 02:36 PM. |
#45 |
dam I got the same #'s as you
Need a good used bump stop...lmao!!
#46 | |
Next batter??? |
#47 |
Ugh. Got my replacement springs today. I give up. They raised the truck almost 4" which is about as close as you can get to stock ride height. ~19.5" from center of the hub to the top of the wheel opening. Stan and all the guys at ECE have been very helpful. It's the guys at Coil Spring Specialties that can't get it right.
I ordered a set of DJM springs from Summit tonight. They will be here in a few days. I'm betting they put the truck exactly where I want it. 2" lower than stock ride height in the front.
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 04-01-2010 at 11:01 PM. |
#48 |
you may have the right ones now your old ones may have been sagging us it level
70 SWB STEPSIDE 70 BLAZER 09 challenger |
#49 |
Nope. The springs that are in it now have the truck sitting at the stock height. I know my original springs sagged. The first springs were suppose to drop the truck 2" from original height. It dropped it all the way to the bump stops and beyond. This was closer to a 4" drop. The second set of springs raised it almost 4" from there. This put it back at stock height or 1.5" higher than it was with my original sagging springs. This has all been confirmed with ECE after taking several measurements.
#50 | |
