Old 03-14-2010, 10:13 PM   #26
ezekiel
Re: Criwn vic suspension idea!
Here's a link to the article on the F*rd-trucks website.
ezekiel is offline   Reply With Quote
Old 03-16-2010, 08:38 AM   #27
solidaxel
solidaxel's Avatar
Originally Posted by fixit-p View Post
sudscribing
.,me to
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-16-2010, 12:38 PM   #28
mr48chev
mr48chev's Avatar
I followed that build for quite a while and while it is fairly easy on that model of Ford it is wide for that Ford pickup and requires wheels with a negative (woops, positive offset) Thanks T hilde. to keep the tires inside the fenders. It is a nice all in one piece setup that would be great if it will fit under what you are working on though.
Anyhow I read Carcrafter's thread a year or so ago and followed it for a while when I was thinking diesel in the 71 and he was worried about what wheels would fit the Ford truck then.
We have a Crown Vic cop car at work that I have been going to measure the tread width on if they will ever leave the wheels straight. I think that they are about six inches too wide for an AD truck and probably a few inches too wide for the 55/59 trucks.
Old 03-16-2010, 03:52 PM   #29
T Hilde
I think you meant positive offset wheels (like front wheel drive). Negative offset pushes the wheel out of the fender.
T Hilde is offline   Reply With Quote
Old 04-09-2010, 08:22 PM   #30
speesh
speesh's Avatar
Has anyone done one of these on a Task Force truck? I have a 57 burban that would like it....
57 suburban(sitting in the driveway), 2 69 C20 longbeds (sitting in the field ) and a 2003 8.1 Suburban
Endeavor to persevere.
"All of a sudden, I'm the old timer!" Some old timer on American Pickers.
speesh is offline   Reply With Quote
Old 04-10-2010, 02:53 PM   #31
Ellington
This looks cool, I will keep watching.
Ellington is offline   Reply With Quote
Old 09-02-2011, 04:48 PM   #32
speesh
speesh's Avatar
I wonder what ever happened to this project? Does anyone know anything about this concept?
Old 09-04-2011, 01:16 PM   #33
mbgmike
its really nothing that new. we have done them.
mbgmike is offline   Reply With Quote
Old 09-05-2011, 11:04 AM   #34
mr48chev
mr48chev's Avatar
I think the deciding factor would be your choice of wheels that you want to run. If you are ok with the positive offset wheels that look like front wheel drive wheels you should be good to go. If you want to run some "reverse style" wheels it isn't gong to work unless you are into the hot wheel car wheel look which is rather silly these days.
It might look great on a Task force truck that you were going for a salt flats racer look with spun aluminum caps on the Crown Vic wheels or slightly taller steelies though.
Old 09-05-2011, 09:20 PM   #35
Dan Bowles
AD Addict
I run full hubcaps usually so I think I could live with something like this other than the track width issue on my AD. I'd probably have to have the drop center dual whels up front to make it as narrow as Mr48 measured.
Now, if you were going to go hot rodding with 1 1/2-2 ton AD or TF sheet metal, this might be perfect. Just something to think about.
And Mr48, that hot wheel car wheel look wasa rather silly in THOSE days as well. IMHO!!
Dan Bowles is offline   Reply With Quote
