Old 04-13-2010, 12:44 AM   #26
Ru5tyNut5
Ru5tyNut5's Avatar
Re: Project Ru5tyNut5
before I started baggin it, but after I lowered it
startin to tuck that rear wheel eh
'55 Pontiac - Project
'63 GMC - Project
'76 Chev stepside rust bucket - Bagged daily driver
Project Ru5tyNut5
Ru5tyNut5 is offline   Reply With Quote
Old 04-13-2010, 12:47 AM   #27
Ru5tyNut5
Ru5tyNut5's Avatar
bad pic, but that's about as low as it's gonna go unless i cut up some of the floor
front aired up with the house compressor
better side
'63 GMC - Project
Project Ru5tyNut5
Old 04-13-2010, 12:48 AM   #28
Ru5tyNut5
Ru5tyNut5's Avatar
more of the bad side
not as bad side again
'63 GMC - Project
Project Ru5tyNut5
Old 04-13-2010, 12:50 AM   #29
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Maybe I can bag a truck someday. Looks like you you have got a lot done. Lookin' good.
Alan's Classic is offline   Reply With Quote
Old 04-13-2010, 12:50 AM   #30
Ru5tyNut5
Ru5tyNut5's Avatar
pile of parts waiting to go in
mocking some stuff up
'63 GMC - Project
Project Ru5tyNut5
Old 04-13-2010, 12:52 AM   #31
Ru5tyNut5
Ru5tyNut5's Avatar
almost everything is in
made a plate to mount the manifold
'63 GMC - Project
Project Ru5tyNut5
Old 04-13-2010, 12:53 AM   #32
Ru5tyNut5
Ru5tyNut5's Avatar
got the manifold mocked up
took it all out, did a little painting, put it all back in
'63 GMC - Project
Project Ru5tyNut5
Old 04-13-2010, 12:55 AM   #33
Ru5tyNut5
Ru5tyNut5's Avatar
got most everything wired up
'63 GMC - Project
Project Ru5tyNut5
Old 04-13-2010, 01:00 AM   #34
Ru5tyNut5
Ru5tyNut5's Avatar
that's the most recent pic but I got a little more done today. I have the air lines ran from the manifold to the rear bags and have the switch box all wired up now. I need a bunch of 1/4 air line to run to my guages then I can see if I actually wired the box up right. All I have left at this point is run 1/2" air line to the front bags and 1/4" line to the guages. I'm also thinking about going to bigger power wire before I actually start running it, we'll see what happens.
'63 GMC - Project
Project Ru5tyNut5
Old 04-13-2010, 01:05 AM   #35
Ru5tyNut5
Ru5tyNut5's Avatar
Next time I do it I'll just Z the frame in the rear, seems like it would be a lot easier than a big step notch. Other than that there isn't really much to it aside from figuring out where you want to put everything and then making mounts for it all. neither the switch box or the manifold came with any type of wiring diagram so that can make it interesting, nothing a couple emails couldn't fix though. unfortunately there are wire colors that aren't supposed to be there, and some that are supposed to be there are missing.
'63 GMC - Project
Project Ru5tyNut5
Old 04-13-2010, 08:10 AM   #36
scotts62
One day...
scotts62's Avatar
Cool looking good!
Scott
93 crew cab build
Project 62
Old 04-18-2010, 04:31 PM   #37
Ru5tyNut5
Ru5tyNut5's Avatar
started running the air lines
got 'em all ran, I threw one red guage line in there on purpose...figured I'd throw one in so that side would match the power wires and whatnot on the other side.
'63 GMC - Project
Project Ru5tyNut5
Old 04-18-2010, 04:32 PM   #38
Ru5tyNut5
Ru5tyNut5's Avatar
after her second test drive
The chevy's out getting some sun this morning
'63 GMC - Project
Project Ru5tyNut5
Old 04-18-2010, 04:35 PM   #39
Ru5tyNut5
Ru5tyNut5's Avatar
I do have drop spindles for the front but I have some things I need to figure out before I put them on. the gas tank is about 1/8" off the ground when it's all the way down right now for one, and also I have full length headers that are also almost on the ground when it's all the way down. Guess I need a fuel cell and some shorty headers before I put the spindles on.
'63 GMC - Project
Project Ru5tyNut5
Old 04-18-2010, 09:00 PM   #40
VA72C10
VA72C10
VA72C10's Avatar
The spindles might actually help with the tank. Lowering the front makes the rear come up slightly and vice versa. Definitely would need the headers though...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 04-28-2010, 01:19 AM   #41
Ru5tyNut5
Ru5tyNut5's Avatar
that would be great if the tank were in the rear, but unfortunately the tanks on these are mostly under the cab on the outsides of the frame rails, and they hang down pretty good. if I go any lower on the front my tank and headers will be on the ground but my bumper may not be on the ground anymore.
'63 GMC - Project
Project Ru5tyNut5
Old 04-28-2010, 01:38 AM   #42
VA72C10
VA72C10
VA72C10's Avatar
DOH...forgot what section I was in....
Old 04-28-2010, 08:40 PM   #43
creep
Registered Loser
creep's Avatar
What are the dimensions and capacity of your air tank and where did you get it?
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 04-30-2010, 09:41 PM   #44
Ru5tyNut5
Ru5tyNut5's Avatar
Tank Link
'63 GMC - Project
Project Ru5tyNut5
Old 04-30-2010, 09:44 PM   #45
Ru5tyNut5
Ru5tyNut5's Avatar
Learned myself how to make my own wide white walls.....after - before pic below
'63 GMC - Project
Project Ru5tyNut5
Old 04-30-2010, 09:46 PM   #46
Ru5tyNut5
Ru5tyNut5's Avatar
this pic was all of maybe 7 minutes after the other one, can't believe how quick and easy it is. I'm sure I'm the last one to learn it but better late than never.
'63 GMC - Project
Project Ru5tyNut5
Old 05-01-2010, 03:09 AM   #47
Ru5tyNut5
Ru5tyNut5's Avatar
I got some fenders for free, they aren't perfect but they aren't full of rust holes like the ones I got now so they're just right.
'63 GMC - Project
Project Ru5tyNut5
Old 05-01-2010, 08:12 PM   #48
Ru5tyNut5
Ru5tyNut5's Avatar
figured I'd paint the wheels that those white walls are on for the time being until I get the wheels I'm going to use painted.
1st wheel in primer.....
2nd all wire wheeled and ready to be cleaned for primer......
1st one painted......
'63 GMC - Project
Project Ru5tyNut5
Old 05-01-2010, 11:19 PM   #49
Ru5tyNut5
Ru5tyNut5's Avatar
got the 1st one finished
2nd is ready for primer
another angle of both
'63 GMC - Project
Project Ru5tyNut5
Old 05-02-2010, 12:15 AM   #50
VA72C10
VA72C10
VA72C10's Avatar
looks a lot better that way!
