#26 | |
I know the pieces fit
Re: LED review:Dash yes, Clearance Lights no
#27 |
cool man!
I also changed to LEDs for my cluster, but only painted the back of the plastic cover that reflects the light from the LEDs and was already very happy with the improvement. Maybe I'll paint the bezel sometime too. I also changed my flasher module so I could use LEDS for the front Flashers. Now the Flasher indicators come ON whenever I turn on the headlights (and ofcourse the flashers come on too). I have no idea how to solve this. Maybe change the flasher indicators for normal bulbs?
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS Last edited by kikkegek; 10-27-2010 at 03:13 PM. |
#28 |
I have spent the better part of 2 hours searching high and low to answer this question.
How do you remove the printed circuit & connectors off the gauge cluster, so you can sand it for paint and clean it? How did you guys clean yours without removing the printed circuit? Mine is a filthy mess, and I would like to run it through the kitchen sink with a good scrubbing and then sand it so the paint will stick. Any help is appreciated! |
#29 |
Mine was relatively clean inside. I took a damp cloth, not wet, and wiped it out. Let it dry then spray bombed the inner shell with a chrome paint.
![]() I left the circuit board, that plastic film on the back side alone. It can come off but why do it if not necessary? To clean that part before reassembly I just wiped it off "Carefully" with a soft damp cloth. I was careful to mask any hole where paint could overspray onto the circuitry. Not sure if it would matter, but why not? Yet all that needs to be reflective is the inner portion of the shell. The backside is mute. The goal was to just get a shinier background from that light green plastic color. Nothing more. Perfection is not necessary as it will not be seen when it's all reassembled. The goal for this area is one at best to achieve reflective surface only. ![]() Then there is this piece: ![]() ![]() And if I did it again, which I will someday, I would have gone ahead and painted the outer plastic shell black as well and maybe detailed the silver trim around the gauges, or in a contrasting color, or left it all black. ![]() Saw a nice one where someone painted it a color other than black to match their dash color...was very well done when detailed out with the trim. Yet good luck with the project and hope this helps. It looks more complicated than it is. Trust me, I have been there done that too. It gets easier. ![]() Learning that always learning is a good thing, Mark ![]()
1985 Chevy C-30 Hydraulic Dump Bed 2001 Saturn SC2 (go to work car) 2010 PT Cruiser (wife's car) "Reality is just a hallucination brought on by lack of alcohol." ![]() Last edited by RuralRoute C-30; 10-31-2010 at 08:28 PM. |
#30 |
Thank you very much!! Out comes the damp cloth.
Yours looks good, and that's why mine is apart on the kitchen counter now. Your post was the reason I'm doing this to mine. I had only one good light working on the speedo, so it was time to do something. I have the one out of my '88 suburban parts vehicle here, apart as well. Trying to decide which one I want to do and re-install in my '87 V10. I have been trying to see if the harness' are the same or not. Thanks again. |
#31 |
nice work!!
I did something similar, but I used white plastic paint and 168 incandescent bulbs, it was so bright I was afraid to put LED's in it ![]() pics start HERE
#32 |
So what would be best to choose paint wise? Silver or white?
#33 | |
white IMO
here is a quote from another thread on the subject... Quote:
#34 |
Slots go on anything!
Is it necessary to paint the front of the cover white too? You can see it behind the lens a little bit. I understand painting the backside of it to reflect on the inside of the cluster, but does the outside reflect light too?
1974 Jimmy- 5.3/4L80e/NP241 |
#35 |
Jon,
It isn't necessary, I painted it all because it was easier than masking the front off. And it turned out to give the gauges a kinda halo effect that I like. Posted via Mobile Device
#36 |
Agree.
![]() Mark ![]()
1985 Chevy C-30 Hydraulic Dump Bed 2001 Saturn SC2 (go to work car) 2010 PT Cruiser (wife's car) "Reality is just a hallucination brought on by lack of alcohol." ![]() |
#37 |
joe231 kinda answered this question but I had to do some cost effective research on light reflection and here's what I found out.
you'll get the most reflection from white now you have the question of flat or gloss you want flat because gloss has to much varnish in it and the light diminishes as it passes through all the layers of varnish aswhere flatwhite the light reflects off of the pigment itself also food for thought flat white has a higher lumination reflective rate then: mirror polished metal or about anything you can think of thats cheep and be used to cover large sq ft
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
#38 |
1) RE: cab clearance/marker lights: But leds last longer?
2) When driving at night you don't want the interior lights to be too bright. Just my opinion. |
#39 |
Does anyone know of anywhere else to get a gauge overlay. It looks like white face gauges will be down for relocation for almost a year?? Any help please.
#40 |
I would rather dim out too much light than squint to see anything at all.
#41 | ||
Thanks Quote:
![]() that's why vehicles have dimmers ![]()
![]() ![]() Last edited by joe231; 11-02-2010 at 05:43 PM. |
#42 |
Salty Sailor
when i put my LED's in, the dimmer for the dash lights was innefective. all the way turned down was the same output as turned up. but with the standard bulbs the dimmer worked fine. but overall i would rather have LED lights that i can see rather than have standard bulbs that i cant see how fast im going.
86 c-10 Custom Deluxe Savannah, Georgia Last edited by bucannon; 11-03-2010 at 04:02 AM. |
#43 |
does anybody have pics with the red led's
#44 | |
Arrived on a Pale Horse
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW Last edited by babyJay; 11-04-2010 at 01:20 AM. |
#45 |
never took any night pics of the green LED's because my camera isn't the best at night pics. Might be operator error.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
#46 |
I am going to try the 168 bulbs in my tach cluster. I painted it with white base, so it is more satin, I guess. Can't wait to actually have it in the truck!
#47 | |
Happy to be here
![]() Join Date: Mar 2000
I do think we need to look at LED replacements for the interior lights. The illumination inside my cab is terrible.
#48 |
I painted the gauge cluster on my 87 like you did yours, but used a can of chevy orange engine paint instead of the chrome/silver stuff.... it wasnt as bright as i would have liked, but it looked like the inside of a pontiac, everything showed up really red. maybe a good feature for an army truck or something, as they like red lights.
#49 |
You can dim LEDs with PWM. Pulse Width Modulation.
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
#50 |
Yep, it's how they do good LED tail/running lights that need to be on and then bright when the brake comes on or blinker flipped on. It's actually turning the LEDS on and off really quickly for a dimmer light versus a brake light which is constant on usually. There are several good site out there that talk about the circuitry needed to make a PWM for automotive lights, interesting stuff for my future ideas to tinker with once the body is good.
2006 Silverado Crew Cab 1500 4x4 5.3L automatic 1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208 1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his. 1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out. 2016 Nissan Altima grocery getter/commuter Last edited by Adams74Chevy; 11-04-2010 at 05:07 PM. |
