03-19-2010, 04:47 PM | #26 |
Re: t5 troubles...?
you have to grind the grooves in the splines on the input shaft back about 3/8 to 1/2 in. I put the disc on the shaft till it won't go any further. I mark where it stops & pull it back off. Then i grind the grooves with a die grinder or cuttoff wheel. Try the disc till it will slide back far enough from the marks. You have to remove the brg retainer & cover the front of the trans. to keep the fillings out.
03-19-2010, 09:56 PM | #27 |
Re: t5 troubles...?
brad- the clutch for the 87 s10 was too small, so i found a shop that made a 10in 14 spline clutch. only difference is the diameter, same amnt of splines etc.
Heavy70- it is mechanical. thanks for the advice. we took the pressure plate, clutch, and throwout bearing to a driveline shop today, they put it on a machine (not sure what it was), and it was all compatible. i think ive found the problem though, the z bar on the clutch linkage seems to be hitting the header, not letting it engaging/disengaging all the way, so ill have to modify it. i think thats what it is, not for sure, but i will be able to nail down an awnser tomorrow. marshall
70 Chevy C10, LT1, T5, "Blue Beast" Last edited by aggieguy713; 03-19-2010 at 10:01 PM. |
03-20-2010, 10:09 PM | #28 |
Re: t5 troubles...?
we found the problem. it wasnt the clutch,pressure plate, or throwout bearing. the clutch linkage had to be adjusted...alot. and the z bar was hitting a header, so we took the bottom part of it, cut it moved it over about 3 inches and welded it back so it could press freely. thanks for your help.
marshall
70 Chevy C10, LT1, T5, "Blue Beast" |
03-21-2010, 11:58 AM | #29 |
Out of the carpool lane.
Re: t5 troubles...?
Glad to hear you figured it out. Thanks for letting us know what the problem was.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
