Old 04-06-2010, 02:56 PM   #26
Sinister
Between Trucks...
Sinister's Avatar
Re: miss at slow acceleration and cruise
Originally Posted by Sinister View Post
I think you need to tune your carb.
See Above.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 04-06-2010, 04:05 PM   #27
Mertz
I think that you have a lean surge. Running lean causes the engine to run hot and could cause the plugs to get really hot and maybe what is causing the glow. Try tipping in the choke flap when running at 2000 rpm and see it the engine speeds up. If it does it is lean.
Mertz is offline   Reply With Quote
Old 04-07-2010, 01:30 PM   #28
drewdude92
72 chevys 4 life
drewdude92's Avatar
thank you mertz ill try that tonight if i keep the edelbrock on long enough to mess with it. Im puttin a 750 double pumper on it once i go get it =)
I dont call it being young and dumb....I call it young and havin fun
drewdude92 is offline   Reply With Quote
Old 04-09-2010, 01:40 PM   #29
longhorn396
S.D.M.F.
longhorn396's Avatar
Ur timing is probably to fast. when the motor is cold is it hard to start?? i was having the same problem and i fixed it this morning by back the timing down.
EDIT: dont know about the plugs though
1969 Chevy Longhorn 396/400 3/4 ton.
1991 Chevy Camaro RS 305/700r4
1978 Honda XL175 and XL350(the evil twin)
2006 Kawasaki ZX-14r drag bike-best e.t. 9.4@145 mph without nitrous
1971 BSA Thunderbolt 650cc
longhorn396 is offline   Reply With Quote
Old 04-09-2010, 01:47 PM   #30
drewdude92
72 chevys 4 life
drewdude92's Avatar
ill try to retard it a little more i guess. And no it is not especially hard to start when cold.
Old 04-10-2010, 12:44 AM   #31
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
usually if it is too advanced it will start ok when cold then after it warms up it'll crank slow then fire.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
