03-25-2010, 09:23 PM | #26 |
Designated Grumpy Old Man
Re: Anti-Theft Measures?
Put in a electric fuel pump with a hidden switch. Engine isn't going to run with out gas.
The only other way they will steal it is with a tow truck. And that is hard to stop.
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
03-25-2010, 09:40 PM | #27 |
Find a member on here that lives near where you want to stop for the night and stay with them.
03-25-2010, 10:38 PM | #28 |
Man of Mini-Talents
Could pull the distributor rotor, chain the frame to a pole.
Park it in a well lit area. |
03-26-2010, 01:44 AM | #29 |
Here's what I use on my fiberglass dune buggy - run a wire from the hot wire on the dist to a loud horn with a well hidden toggle switch. If any juice goes to the ignition the horn goes off unless the toggle is switched off. Even if they hot wire it, it will go off if you wire things right. Of course, it still won't stop the tow off...........
03-26-2010, 02:21 AM | #30 |
if you have cut outs open them duct tape a baby monitor under the truck and have the other one in your room with that and a secret gas shut off u is good to go! hear them take off walk about 50 yards down the road beat the hell outa them turn the gas on and drive her back! lol but in all seriousness the rest of the guys have very inventive and suitable ideas!
04 Chevy Colorado Z71 4X4 76 Chevy C-10 Custom Deluxe (sold) 67 Chevy C-30 1 Ton 9' stepper 6.5 Turbo Diesel Last edited by NORMSCOLORADO; 03-26-2010 at 02:22 AM. |
03-26-2010, 09:56 AM | #31 |
In my limited experience, turning off the gas feed has been the best for me. My Jeep has a toggle switch in line to the fuel pump, the couple of times the brain trust in this area have tried to steal it, it just turns over and over and over - the noise of the engine actually gets more attention than an alarm would. If it is next to your room - you will know instantly what is going on.
Your wife does have an excellent idea though - a thief would probably look at - and take your other three wheels. |
03-26-2010, 12:43 PM | #32 |
03-26-2010, 01:31 PM | #33 |
Older than most of you guys here but find you a T-Model coil, that will keep them away!
03-26-2010, 03:28 PM | #34 |
Six in a row makes it go...
3-on-the-tree. Very few people know how to drive it anymore.
3-on-the-tree with worn linkage. Even if you know the pattern, you might not make the one-two shift. On a more serious note - I have a ball-valve in my fuel line. When shut off, the truck will start and go about a block before the bowl is dry.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
03-26-2010, 08:52 PM | #35 |
Take a road flare and lay it on the seat with 2 little wires that go to somewhere under the dash. Stuff the removeable end of the road flare into the cushion.
That way it looks like a stick of dynamite with the fuse wired to the ignition! Plus the other real stuff. A big chain with a big Master lock through the wheel around the lower control arm will keep the wheel from rolling very far. Even if theives remove the wheel the chain is still inside the spindle. Hope it doesn't rain before you have to take it off. |
03-26-2010, 10:47 PM | #36 |
Its not unreasonable to drive it in a day. A long day but still a day. I have driven from Dallas to Georgia many times in under 16 hours. Even Oklahoma to Georgia on occasion. The drive is not bad. Depending on which way you go the Rainbow casino just outside of Vicksburg Miss on I20 is a good half way point. Plus they have a blackjack table that has a 21 plus 3 game where you play a 3 card poker hand off your cards and the dealer up card. It pays 9 to 1. I usually cover my whole trip by stopping there.
1970 GMC truck 1988 Harley 1200 Sportster |
03-27-2010, 09:11 AM | #37 |
Old School
When I worked on the road servicing rolling stock at Home Depot stores, I kept a driveway monitor in the trailer and kept the receiver beside the bed in my motel room. Any time you even opened the door of the trailer the receiver would let you know. These things are fairly cheap (25.00 range), and battery powered so they are very portable and easy to set up. The unit is basically a motion sensor. Another thing is, it does not see through glass, so setting one in the floorboard of your truck will not pick up someone just wqlking by your truck. The reason I know this is because I keep this monitor in my glass cased gun cabinet at home. When the door is closed, you can stand in front of the door and make all the movement you want, but open the door and it lets you know real fast.
#1 Project...69 Chevy swb Fleetside (Dad's truck) #2...1983 El Camino SS (Choo Choo Custom) #3...1974 Datsun truck (4.3L V6/4L60E) #4...1951 Cadillac Limo (1975 Caddy running gear) #5...1938 Dodge M38 3/4 ton Military truck #6...1968 Sportster XLCH trail bike 5 GMC & Chevy parts trucks 68 to 72 Last but not least; My 1978 Harley Davidson Electraglide (trusted & reliable companion for the last 30 years) |
