04-01-2010, 10:40 PM | #26 | ||
Re: McGaughy Big Brake kit
04-01-2010, 10:42 PM | #27 |
A few more . . ....
04-02-2010, 04:11 AM | #28 |
04-02-2010, 08:30 AM | #29 |
I'm just glad to be here!
Scoti - That set up looks good. I assume that is a 20" Coy wheel in the pictures. Are the holes that the bracket bolts to the original holes in the spindle?
When I called they have a hub for both the HD and LD brakes. The HD hub is not on the web site yet, but the one for the LD hub is the same hub as the one for the GM Tall Spindle HD for the Impalla SS.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
04-02-2010, 08:37 AM | #30 |
The rotors are the 340 mm C6 Z51 Front Rotors. Looks like they have added the 5 on 5 pattern and opened up the center hub hole.
04-02-2010, 12:34 PM | #31 | |||
04-02-2010, 10:20 PM | #32 |
I looked a little more on the Kore3's site and now I am REALLY interested in doing this mod to the front of my '98 daily driver. I will most likely hold off on doing this to my 65 for a while. I am going to use 15" ralley wheels for now.
Looks like I have to save my lunch money...
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square Last edited by aggie91; 04-05-2010 at 09:17 AM. |
04-03-2010, 06:02 PM | #33 |
BMW & ASE Master Certified
I modified a stock spindle like shown above and I'm going to cut the rotor portion off of the stock front brake rotor and turn it into a hub.. I'm going to try and put dodge front brakes on this spindle. The front rotor of the dodge has the same register as the fronts 3.08... im sure I can get it to work, but for 50 bucks for a rotor/caliper.. its worth a try. If sucessfull it will match the rears, plus I can grab the master and prop valve and call it a day.. probally wont be that simple but.. all else fails, just grab the hub from Tobin and a set of rotors.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
04-03-2010, 07:21 PM | #34 |
It'd be alot cooler if you did
Scoti that is a really nice looking kit. What is the application on the caliper? Wondering if Wilwood makes a replacement...
04-03-2010, 07:37 PM | #35 |
usually kore3 sells either regular corvette or zo6 calipers.
04-05-2010, 09:19 AM | #36 |
It is a Corvette front caliper with Kore3's logo machined into it. Look on Kore3's web site, I think that they have other Vette calipers and colors also.
