#26 |
Re: Airconditioning
Here are some pics of the instulation
#27 |
Re: Airconditioning
Well I finally got some more work done on the AC, here's some pics.
#28 |
![]() Join Date: Sep 2009
Re: Airconditioning
for all of you guys out there is an airconditiong install something that the average person can do?
#29 |
Re: Airconditioning
Yup - it is more time consuming than hard. A system designed for an application is for the most part a "bolt in" kit with very little fabrication needed. A custom system like OK is doing takes a little more planing out and think how you want the finished product to look - ie, smooth firewall, hidden lines, SS Braided lines, etc.
Hey OK - looking good!! If you think about it, call me next week - I have a question about your drier - (we are closed Friday the 23)........Mark |
#30 |
Re: Airconditioning
Looks good OK....this is giving me some ideas
Togart '66 GMC 1500 '77 C-10 Scottsdale Big 10 |
#31 |
Re: Airconditioning
Like Coolair said, it is pretty easy, just need to plan it out and not get in any hurry, its been almost 2 week since I started it, and I didn’t want to rush anything and make any mistakes.
#32 |
Resistance is Futile
Re: Airconditioning
Looking good so far, OK!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#33 |
Re: Airconditioning
Well its Sunday afternood and I have all of my AC installed and hooked up, with the exception of the AC lines, they go in tomarrow and have crimped, and at 5 bucks a pop it wont be cheap.
#34 |
Re: Airconditioning
Can you not borrow a cimp tool from your local parts store? Usually napa has makes a/c hoses and they could loan the tool or crimp them to your cut hoses, Im sure for much less than $5 ea!! that sounds like a rip off!!
I love the smell of lead paint! |
#35 |
Re: Airconditioning
I have checked and no one has a tool that I can use. But the place I bought the system said that I could send the hoses back to them and they would cromp them for me, but after shipping and the wait I figured I might as well just have them do it.
#36 |
Re: Airconditioning
Boy this AC blows, I don’t mean in a bad way, the blower puts out way more air out than I expected, on low it blow's more air than the old stock unit did on high. Actually I wish that on low it would blow less. The heater about ran me out of the truck on the way to work this morning.
#37 | |
Re: Airconditioning
#38 |
Re: Airconditioning
On all vintage air products we have some long deals for all board members here please call us or e-mail for quates or orders
justin@scottshotrods.com (805)485-0382 |
#39 |
Re: Airconditioning
hey guys- i noticed a couple of yall are still installing fittings the old way of indexing & taking them to get crimped. this is what i use. air-o-crimp. check out the web on them. they work! also you can remove them & use them over. only need the plier tool to install. the ones i use have an o-ring on the barb that fits right under the clamp. they never leak!
http://www.atcomail.com/products/airocrimp.htm enjoy! andy |
#40 |
Desert Dweller
Re: Airconditioning
Oklahoma, what pulley system is on your truck? I'm starting the process of doing the same to my truck and like your setup. Did you have to do anything special to mount the VA compressor to the system? I have a short water pump, is yours short or long?
Thank you! Tony |
#41 |
Re: Airconditioning
I'm not sure if it is shor or long, but it does have to be a reverse style pump, I just got the one off the truck that I got the brackets off of. I'm not sure what a VA is, but if its the AC a stock GM will work fine, but the new pump comes with adapter brackets. Any other question's fee free to ask.
#42 |
Re: Airconditioning
VA= vintage air
#43 |
Re: Airconditioning
OIC, missed that one
#44 |
Re: Airconditioning
.....after I pushed Virginia outta my head it clicked!!
#45 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Airconditioning
As far as I know all reverse rotation water pumps used with the serpentine accessory drives are long water pumps. Except for the '84-'91 Vette's.....
#46 |
Desert Dweller
Re: Airconditioning
Thanks guys!
Ya sorry, I sometime get lazy and use acronyms which sounds great to me, but not everyone can read my mind... ![]() Thanks for the info and great job on your truck OK ![]() Tony |
#47 |
Re: Airconditioning
Well all done, it blows ice cold, 32 deg.
#48 |
60-66 Nut
Re: Airconditioning
Wow, that is some cold air.......
#49 |
Desert Dweller
Re: Airconditioning
Hey Oklahoma, do you have any more pics of your install? I just got my Vintage Air kit in today and I'm just looking for some guidance on the dash, under-dash and firewall work.
Thanks man! Tony |
#50 |
Re: Airconditioning
Here are some pic's I took today, hope I wasnt to late. I dont know how much good they will do, pretty tight in that area. Good luck and if you have any questions I will try to help if I can.
