04-04-2010, 04:06 PM | #26 |
Living In The Past
Re: Penetrating Oil and Its Worth
Once I discovered Kroil that is all I use. A few years back I was called to do a job at a co-gen plant that had been mothballed and now being brought back on line. When I saw the Mill wrights that were pulling apart the turbines had 55 gallon drums of Kroil on hand I knew I had the right stuff.
04-04-2010, 07:40 PM | #27 | |
Another forum answered me with this remedy::: the guys ask me if I ever heard of Ed's Red Ed's Red is a homebrew bore cleaner from equal part: mineral spirits, aft, acetone, and kerosene. I now wonder if Moon Shine might work ..interesting to say the least. |
10-06-2010, 04:46 AM | #28 |
I used to use WD-40. I switched to PB blaster and buy it by the gallon. Even though it doesn't say this on the can, I use it for drilling, tapping and to cool my sawzall blade if doing multiple cuts. Works great and you don't need a lot.
10-06-2010, 11:18 PM | #29 |
I have tried all the commercially available penetrating oils. and for my money PBblaster is the shizzz! try it and you will see. If you have an old car/truck you need it. cheers, Pat
10-06-2010, 11:38 PM | #30 |
I love Kroil. I use it in my shop and on my guns, I fact the last can I bought was from Brownels.
I found that PB Blaster will get sticky after awhile. It happens when you spray down rusty bolts several weeks before you work on the project. I still use blaster for some stuff, but I prefer Kroil. WD40 is used only a starter fluid for my diesel and anti-rust for shovels, axes and what not.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
10-14-2010, 01:44 PM | #31 |
Vintage 4x4s
All plastics are not equal. Just find a polyethylene or polypropylene bottle. They are very common and marked PE or PP on the bottom. Will hold up to acetone/laq thinner/xylene.
10-14-2010, 01:47 PM | #32 |
1970 C10 six
I knew I liked liquid wrench for a reason.
1970 C10 L6 250 three speeder |
