Old 04-11-2010, 09:47 PM   #26
chevynutt58
chevynutt58's Avatar
Re: My 58 chevy build
After with a 4" dropped axle from sid
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=396157
chevynutt58 is offline   Reply With Quote
Old 04-12-2010, 10:59 PM   #27
poncho_villa
poncho_villa's Avatar
Yeah that sounds like a good plan. I was just wondering if a front clip modification was in the works soon. But you're right, that is something you can get back to later when the cash is better.
58 Apache short fleetside ona 64 chassis:
poncho_villa is offline   Reply With Quote
Old 04-13-2010, 08:38 PM   #28
chevynutt58
So I went to TCI today to pick up a rear end kit and I have to wait for a week so they can build it.I guess Il start cleaning some other stuff Instaed.I thought I could just go there and pick it up but they said they dont build there products until you buy something then they make it for you.
Old 04-13-2010, 10:05 PM   #29
poncho_villa
Well at least it's guaranteed to be fresh. You could use the downtime to shampoo that awesome carpet.
Old 05-03-2010, 12:28 AM   #30
chevynutt58
heres some of the things ive been working on
Old 05-03-2010, 12:33 AM   #31
chevynutt58
I welded up the leaf pads and set them at 3 degrees
getting it ready for paint
Old 05-03-2010, 12:35 AM   #32
chevynutt58
put a couple coats of por 15 on the rearend
Old 05-03-2010, 12:38 AM   #33
chevynutt58
Everything from TCI bolted on pretty easy I got the leaf mounts on and the springs hung
After everything seemed to fit good I installed the rearend
Old 05-03-2010, 12:41 AM   #34
chevynutt58
Old 05-03-2010, 02:31 PM   #35
Kabwe
Certified Car Nut
Kabwe's Avatar
Nice work keep the pics coming.
Kabwe is offline   Reply With Quote
Old 05-03-2010, 03:58 PM   #36
poncho_villa
Yeah! Looks great. What's next? Axles and brakes with the plumbing? Are you going with discs in the rear?
Old 05-03-2010, 07:15 PM   #37
chevynutt58
Thanks guys for the comments.heres some more pics for you.
Old 05-03-2010, 07:24 PM   #38
chevynutt58
I was going to buy stainless steel brake lines for the rear but they only sell them in a complete kit for the 58 and 59 trucks so when I was down at the truck shop in orange I seen they sold the stainless steel 6ft tubes for $17 so I picked one up and made them myself.
Old 05-03-2010, 07:28 PM   #39
chevynutt58
I change the bearings and seals in the rear end put new springs and brakes on also
I went down and bought some polished stainless bolts for both the rear end covers put a new seal in the pinion also
Old 05-03-2010, 07:30 PM   #40
chevynutt58
cleaned up the driveline painted it with por15 and installed some new u joints
Old 05-03-2010, 07:33 PM   #41
chevynutt58
I rolled it out the garage to see how it looked.
Old 05-03-2010, 08:12 PM   #42
blackdiesel
blackdiesel's Avatar
Did you top coat that POR 15? It looks good now, but if not top coated it will chaulk. Ask me how I know
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 05-03-2010, 09:14 PM   #43
chevynutt58
its says not uv sensitive I talked to a sells rep on the phone for about 30 min before I bought it and they hooked me up with everything and said I should be good to go.I put the por 15 on then this.
Old 05-03-2010, 09:30 PM   #44
blackdiesel
It's about time they came up with something like that. Looks good....
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 05-03-2010, 10:03 PM   #45
chevynutt58
Thanks for the heads up though.they told me I didnt have to top coat it if it wasnt going to be in the direct sun I figured Id rather be safe than sorry.did the stuff that chaulked up on you get direct sunlight or was it under the chassis?
Old 05-03-2010, 11:57 PM   #46
poncho_villa
The brake lines and the rest of the plumbing looks great with that black por 15. Are you going to put a gas tank in the rear while you have it at the point of assembly? Any thoughts on wheels yet or are you keeping the white spokes?
Old 05-04-2010, 07:55 AM   #47
blackdiesel
I did just like you, Painted frame and axles. After 1 year it chaulked bad, no direct light need.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 05-16-2010, 08:33 PM   #48
nevrenz
nevrenz's Avatar
Looks good!
nevrenz is offline   Reply With Quote
Old 11-08-2010, 09:37 PM   #49
Kabwe
Certified Car Nut
Kabwe's Avatar
Any updates man? I have not heard from you in a while.
Old 02-07-2013, 09:11 PM   #50
mark '87 930
mark '87 930's Avatar
Are you c-notching the frame in the rear? I'm curious if it will work without doing it as i want to do the same setup as you're doing.
mark '87 930 is offline   Reply With Quote
