Old 04-16-2010, 11:47 AM   #26
ShredSled
ShredSled's Avatar
Re: lets see the 5x5 lug wheels
Originally Posted by butternut1972 View Post
275/60/15 in back 235/70/15 up front. drop is 5/7. thanks for the compliment.i would like it alittle lower in front.
gotcha, thanks for the info! So you stayed with approx. 28" tall tires all around then.
Can't tell from that photo alone, but it looks like the front is plenty low, no? Now do you have a 5.5/7 drop, or are you using some newer 2" drop spindles, instead of the more common 2.5, making it an actual 5" drop?
What about rear, 6" drop coils and 1" block, or what? Are you notched?
How do you intend to get more drop up front?
still wondering about the truck with 17's on it...
get it!
ShredSled is offline   Reply With Quote
Old 04-17-2010, 02:26 AM   #27
butternut1972
butternut1972's Avatar
[QUOTE=ShredSled;3923508]gotcha, thanks for the info! So you stayed with approx. 28" tall tires all around then.
I used a dropped spring 3" and when i originally built this truck i built some stepped lower control arms that have a 2" drop. I am not sure how i will lower it more yet or if i will. The rear is dearched leafs with bell tech flip kit and a notch. This setup has been on the truck since it was put toghether in87-90. Does this mean it's old skool? That is how we were doing it back then.
butternut1972 is offline   Reply With Quote
