Old 05-04-2010, 09:56 PM   #26
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: Raising the roof to the roof...Version 2.0(PIC'S)
I finally got the measurements you guys wanted.
Plus I changed a couple things today.
Got the top down on the ground and laid a tape on the main beam span. It's 59.5".
Here's the boy helpin out.
Then took a measurement from the front of the main beam to the lifting point.
That is 28".
Then I replaced the 1/4" bolts with some proper locking pin's to secure the arms with.
Then to be REAL sure the top stays secured I attached a ratchet strap at each corner of the main beam and wrapped them around the rafters in the ceiling of the carport.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 05-05-2010, 09:16 AM   #27
69-72
69-72's Avatar
Thanks, its top lifting season soon. You might save me from having to buy an engine equalizer.
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 05-05-2010, 09:58 PM   #28
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Wow! That is nice. I am not going to show you my 2x4s and rope rig-lol.
PICKMUP is offline   Reply With Quote
Old 08-07-2010, 11:37 PM   #29
BobbyK
BobbyK's Avatar
Well...this is how I started... not even any rope.
Old 10-21-2010, 03:15 PM   #30
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
That is very nice. What was the total cost of it when you were done. Thanks for showing use your idea.
1972 GMC Jimmy 1/2 4X4 4wheel camper
1970 GMC Jimmy 1/2 4X4 350
1969 Chevy Blazer 1/2 4X4 307
1967 chevy LWB 3/4 396
Gary 70 Jimmy is offline   Reply With Quote
Old 10-21-2010, 03:46 PM   #31
ProchargedSS
ProchargedSS's Avatar
Great idea!!!
ProchargedSS is offline   Reply With Quote
Old 10-21-2010, 04:17 PM   #32
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Great lift!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 10-21-2010, 10:59 PM   #33
BobbyK
BobbyK's Avatar
About $50 in new steel.
$70.00 for the winch (already had it though)
< $10.00 for the 4 locking pin's.
Total price...PRICELESS...Saves my back and is much safer for a one-man operation.
Approx. $130.00
Could have gone with scrap steel to save money but didn't.
Old 10-22-2010, 08:17 AM   #34
Gary 70 Jimmy
Did you youse 1" square tubing and what size was the round tubing.
Old 10-22-2010, 09:01 AM   #35
BobbyK
BobbyK's Avatar
1.5" square tube, .125 (1/8") wall. round bar is 3/4"
Old 10-22-2010, 09:05 AM   #36
Gary 70 Jimmy
What was the length of the 2 bars going across the top.
Old 10-22-2010, 09:21 AM   #37
BobbyK
BobbyK's Avatar
2" wider than the widest part of the top on each side. Measured from bottom edge to bottom edge. I think is was 6'.
So whatever the widest measurement is +4".
Old 10-22-2010, 09:31 AM   #38
Gary 70 Jimmy
Ok thanks for the help.
Old 10-22-2010, 10:04 AM   #39
2003 silverado
2003 silverado's Avatar
Man that looks awesome.I need to make one now ,Having three girls nobody to help lift the top off.The one thing i see is would it have made sense???to have had a return up on the feet so it doesent slip out maybe two inch return. Then you coould just slide it from the back /and down from window area?????Just throwing it out there.
!972 K5 Blazer,Highlander,A/C a twin to the one I Had
1972 K/5 Blazer CST Highlander 15YR project
2003 Silverado Crew 2500HD (Daily driver)
1997 Ford focus (Beater)
2003 ford Taurus (student)
2014 Ford Fusion HYB (wife)
2003 Jetta ( Student)
2003 silverado is offline   Reply With Quote
Old 10-22-2010, 10:14 AM   #40
BobbyK
BobbyK's Avatar
The top is bolted to the feet of the arms using the factory holes in the bed rails of the top.
Having a lip on the foot would interfere when you slid the foot under the top. Unless of course you just raised the top up enough to clear whatever sized lip you have made.
The 3/4" arms are are more than strong enough to hold the top up without the weight of the top splaying out the arms.
Basically it's like having the top on the ground.
Old 04-23-2013, 07:39 AM   #41
Guana
Guana's Avatar
Did you ever figure out he COG, i fixing to start working on a lift for my K5 roof and it would save me lots of time if you knew what it was.............thanks
Guana
_____________________________________________________________
Originally Posted by BobbyK View Post
UPDATE 4/20/10
Some good progress today.
Still in the mock-up stage but here are some pic's anyway.
Got the "I" frame up on the Blazer's top and temp. attached the winch to it with a chain.
removed all the mounting hardware and got the top up on two pieces of wood.
Then, one corner at a time I slid the "arms" into the I-frame.
Unfortunately I have no pic's of the actual top up in the air. It was a little scary at first as I don't have the COG (center of Gravity) figured out yet and I was alone. So I couldn't leave the top up in the air by it's self.
Here it is on the ground though...
So after a long day I ground all the surface rust off all the parts and primed them up.
I'm not sure what color to paint the lift.
Black... or white like the top.
Opinions?
Guana is offline   Reply With Quote
Old 04-23-2013, 08:51 AM   #42
Dale99
Guana
He showed a measurement that was 28" from one of the ends.
2008 Sierra k3500 LMM
1994 s10 blazer 4x4
1991 Camaro Vert Rusted in Half RIP
1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364
1967 C10 L6/3tree(dads truck)
Dale99 is offline   Reply With Quote
Old 04-23-2013, 11:11 AM   #43
BobbyK
BobbyK's Avatar
I used the 1st and last mounting holes in the rail of the top.
So the arms of the frame are right in line with those holes when the top is suspended in the "I" frame.
28" from the front of the "I" frame back to the eye bolt.
Your measurements may vary +/- 1" as it seems there are slight differences between the single and double walled tops.
I still have the top on my blazer but I will update the post this summer with an actual COG measurement on the Blazer top itself.
Old 01-02-2014, 01:56 AM   #44
BobbyK
BobbyK's Avatar
The front arms are in line with the 1st holes in the rail of the top.
So the COG would be approx. 28" back from those 1st holes.
Old 01-02-2014, 02:45 AM   #45
Gibber1967
I know what I'm doing with the rest of my Christmas vacation...thanks for all the great info.!
Gibber1967 is offline   Reply With Quote
Old 01-17-2014, 01:32 PM   #46
Guana
Guana's Avatar
Thanks for the tips, this is how I did mine and where it's stored......
Old 07-02-2015, 01:05 PM   #47
BobbyK
BobbyK's Avatar
Nice single wall.
Wish I could keep mine indoors.
Nice Blazer too!
