Old 04-29-2010, 08:54 PM   #26
SCOTI
SCOTI's Avatar
Re: Need some part number help here
Originally Posted by kev2809 View Post
what about the brake lines to the rear? or is this something totally different? i just assumed you guys were talking 73+ hard lines all the way to the back.
so its 73+ up front, then original hard lines to the rear?
That's how I did mine. Spliced them together @ the factory union under the pass side of the cab.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-29-2010, 09:29 PM   #27
kev2809
low n' slo
kev2809's Avatar
sounds like a plan. well im gonna get the calipers and rotors and pads for 73+, then when i get to the new lines ill be back to ask some more questions
thanks for the help
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 05-26-2010, 03:04 PM   #28
b&a72
Active Member
b&a72's Avatar
So if I am reading this right I can put 73-80 rotors on my 71-72 spindles? And also buy 73-80 front to rear shortbed brakelines and it will all match up?
b&a72 is offline   Reply With Quote
Old 05-26-2010, 03:26 PM   #29
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
73-80 rotors, calipers, pads, bearings and seals, absolutely. They are direct interchange.
You can also use the 73-80 brake hoses and lines too. Beware though, that you need to use all or none of the brake hoses and lines. The 73-80 brake lines are much different than 72 and earlier. The prop valve mounts down under the radiator. But, if you remove all of the lines from the master cylinder to the wheels, they will all bolt on.
My current 63 has every inch of factory 80 model brake lines and hoses under it.
Old 05-26-2010, 04:45 PM   #30
b&a72
Active Member
b&a72's Avatar
The rotors were the biggest part as they are cheaper then the 71-72 as are the calipers. Thanks TX Firefighter!
Old 05-27-2010, 08:47 PM   #31
kev2809
low n' slo
kev2809's Avatar
well i picked up the rotors finally, but the dude said the bearings are special order, but when i called last night they had em lol
can anyone find a pn from o reilly on what else i need? these rotors did not come with any bearings, so im gonna need to buy them. im guessing it needs inner and outer? when i took my old one off it only had one on there...
its a lot easier for me just to go in with a pn and tell them to get it, their guessing game sucks lol
-_--_--_ _________
