04-30-2010, 12:54 AM | #26 |
Big Red - Now its a SWB!
Re: Questions on Changeing intake manifold gasket is this normal?
Big props for handling the job yourself, it gives you a lot more pride in your truck to say that you did it yourself. We all had to learn sometime and now you can show someone else.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
04-30-2010, 02:35 AM | #27 |
Good job. It's nice to have an install go right.
04-30-2010, 06:40 AM | #28 | |
"THE GREEN GOBLIN"
Petey-pablo
"THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi Sold Drive it like you stole it! Petey-pablo@sbcglobal.net |
04-30-2010, 06:43 AM | #29 |
"THE GREEN GOBLIN"
That I did not do was I supose to? I didn't think it was nessacery since I didn't spill any coolant in the block when I took the intake off. I just figuerd if there was any debris that had fallen in it would circulate then I can change the oil...
Petey-pablo
"THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi Sold Drive it like you stole it! Petey-pablo@sbcglobal.net Last edited by petey-pablo; 04-30-2010 at 06:48 AM. |
04-30-2010, 08:41 AM | #30 |
You'll be fine. Its good to change it just to be on the conservative side of things.
1968 LWB C20 / AC / Wood Bed |
04-30-2010, 01:53 PM | #31 | |
Felpro Z1212 is the correct gasket btw. If you still have problems with it leaking than I would suspect the gasket. Edelbrock doesn't even sell a steel core gasket and the 7203 Summit list as steel core is incorrect its not steel. Also Chevrolet didn't use steel core intake gaskets on 69 Z28's (w/ aluminum intakes) either btw if I an not mistaken. Last edited by HOGDADDY; 04-30-2010 at 02:20 PM. |
04-30-2010, 05:19 PM | #32 |
If the gasket was bad to begin with I'd imagine you were getting coolant in the oil to begin with
'72 cheyenne super step, '05 long bed gmc |
04-30-2010, 06:36 PM | #33 | |
"THE GREEN GOBLIN"
Petey-pablo
"THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi Sold Drive it like you stole it! Petey-pablo@sbcglobal.net Last edited by petey-pablo; 04-30-2010 at 06:38 PM. |
04-30-2010, 07:45 PM | #34 |
Between Trucks...
Just use an Edelbrock gasket for your manifold, guaranteed to work.
Beat it to fit, Paint it to match... |
04-30-2010, 09:44 PM | #35 | |
I guess some mechanics will use whatever is available and maybe he didn't know any better I dunno. Ask Edelbrock or any engine builder for their honest opinion on the matter but if you really think about it how well will an aluminum intake compress a steel gasket? Also sometimes steel head gaskets are used on aluminum heads but it will indent a ring on head where the steel is around combustion chamber and of course the bolts on heads are torqued much higher than intakes too. Last edited by HOGDADDY; 04-30-2010 at 09:50 PM. |
05-01-2010, 01:55 PM | #36 |
"THE GREEN GOBLIN"
Ok cool thanks.
Petey-pablo
05-01-2010, 02:40 PM | #37 |
thing id to since this is your first task.. is to take a sharpie.. and mark the distributor and manifold.. so when u stick it back in you can line it back up
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
05-01-2010, 02:50 PM | #38 |
i have always used the ones you used. I also have always had iron heads, and some sort of aftermarket aluminum intake. I have never had a problem.
I have used them on the following setups my old mans stock 350 in his 67 my 383 stroker in our 75 corvette my 454 with a blower in my 70gmc I dont think youll have a problem at all |
05-01-2010, 03:40 PM | #39 |
Like I said ealier from my observations the non-steel gasket is the preferred choice for aluminum intakes but please don't take my word on it do your own research here.
Hopefully I have at least raised some concerns here and am only trying to share the best method here for my fellow truckers. |
05-02-2010, 12:18 AM | #40 |
"THE GREEN GOBLIN"
Thanks guys took the truck for a nice long drive down to Gilroy today it ran strong I am happy I have acomplished something once again with the help of everyone here on the Thread..
Petey-pablo
