Old 05-26-2010, 02:31 PM   #26
3r!c84
Badass
3r!c84's Avatar
Re: Show me your 4-6 drop!
what are u all doing about inner fenders?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 05-26-2010, 03:00 PM   #27
Jonboy
Slots go on anything!
I am just running the original ones. No problems yet.
1974 Jimmy- 5.3/4L80e/NP241
Old 05-26-2010, 03:04 PM   #28
3r!c84
Badass
3r!c84's Avatar
no rubbing? mine rub alot
-00 Saturn 5spd
1/4:13:90
Old 05-26-2010, 03:05 PM   #29
JWall
Frequent Flyer
JWall's Avatar
My buddy has one with a 4/6 and he did nothing to his inners and has had no problems.
Running stock ones on my Dads truck too..There were a couple bolts that went thru the inner fender that I flipped over so that the head of the bolt was on the bottom side incase the tire ever got into them (instead of the long threads sticking down)....its really close with the 6" drop but no major problems yet.
- Justin
1 Owner 1976 SWB
Old 05-26-2010, 03:13 PM   #30
JohnC
JohnC's Avatar
Originally Posted by boatpuller View Post
yeah,that looks sweet jonboy.i got learn how to use a camera.i'd post one of my 4,6 but,everybodies seen the same pic a hundred times.
We never get tired of seeing your truck!
JohnC is offline   Reply With Quote
Old 05-26-2010, 04:34 PM   #31
54Caddy
GM Addicted
54Caddy's Avatar
Jwall do you think the 6/8 drop would clear on 15's i am running 255/60/15's
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 05-26-2010, 05:05 PM   #32
JWall
Frequent Flyer
JWall's Avatar
I would think so because that tire size and the front tires on my dads are basically the same diameter and width.
I would hate to say yes for sure because each truck is different.
Wheel backspacing would also play a part.
- Justin
1 Owner 1976 SWB
Old 05-26-2010, 05:11 PM   #33
54Caddy
GM Addicted
54Caddy's Avatar
yeah im eventually get some 20s and run 235/55/20s they are the same tire height as the ones i have now and was thinking of doing a 6/8 drop. Or just go all out and bag it ahaha
..Mac’s Garage..
IG:MacsGarage
Old 05-30-2010, 11:57 AM   #34
jasonroman
jasonroman's Avatar
Originally Posted by Jonboy View Post
Here is my '79, 2.5" spindle with a full coil cut in the front, and a flip kit in the rear. Wheels are stock rally wheels, 215/70 on 6.5's in the front, 255/70 on 8's in the rear. My truck does have the HD leaves in the rear, and ride quality has improved since lowering it.
this is what i want mine to look like. but my truck is 85.
can i run these tire sized on my truck. fronts and rears are same size tho.
i need new tires and want this kind of look
after i get tires ill be looking for a drop kit.
thanks for any help
jasonroman is offline   Reply With Quote
Old 05-30-2010, 02:23 PM   #35
Jonboy
I think the 8" wheel will be a little wide for a 215 width tire. Maybe a 235/60 would be OK on an 8" wheel, and be the same height. I actually had the van (6.5" wheels) and had to find the 8's.
Old 05-31-2010, 09:41 AM   #36
jasonroman
jasonroman's Avatar
ok. so if i have 8's. what size should i run front and back?
thanks for any help
Old 05-31-2010, 11:28 PM   #37
Mattsch18
ok so whats the easiest way to drop this 4/6? are there 4'' lowering spindels? and the a axel flip kit? and whats involved in the axel flip?
Mattsch18 is offline   Reply With Quote
Old 05-31-2010, 11:55 PM   #38
texasfunk
texasfunk's Avatar
2006 GMC Sierra CCSB, 6.0 swap
2000 Chevy C3500 Crew Cab shortbed dually
1999 Chevy c2500 Crew Cab shortbed
1982 El Camino 350/350
1979 K5 2wd blazer bagged/bodied
1986 Monte Carlo SS
1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4
1955 Chevy Bel Air
2014 Chevy Silverado ccsb
texasfunk is offline   Reply With Quote
