07-26-2016, 01:15 PM | #26 |
Moderator
Re: DIY Front End Alignment
You want to talk about Castor? - http://67-72chevytrucks.com/vboard/s...d.php?t=501241
07-26-2016, 09:49 PM | #27 |
But Found Her 25yrs Later!
I got it out for a spin around the block.
I took two shims out of the back post on the upper arms. I did notice it did change camber and toe, but I just wanted to see if more positive caster would give more high speed control. It did. I'm pretty sure it was pretty close to zero caster. After doing more reading on the topic of caster, I'm thinking the almost zero caster was because of the manual steering and wide tires. Now with power steering, more caster won't be an issue. Tomorrow I'll put those two shims back in on the front post which will put my camber back where was, but also increase caster more. I'll take it for another quick run and then readjust toe.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
08-02-2016, 06:19 PM | #28 |
I have a condition I can't figure out. I installed a CPP lowering spindles and there complete front end rebuild and added a sway bar. I have the front end set at -3/8 degree camber...+3.5 degree caster...1/16" tow in. The truck has a lot of oversteer and wants to dart around some. I increased the tow in to 1/8" and it didn't seem to help it any. It is manual steering with a Redhead rebuilt steering box that is really stiff. It might be stiff enough I am thinking it could make it feel like oversteer since I have to do more steering. Any ideas?
1990 Silverado Sport 2010 Silverado K1500 1996 K2500 |
06-03-2020, 09:16 AM | #29 | |
Old thread, but well worth dredging up from the depths of 67-72 forums. And I needed it too!
The below link must be found through Archive now. https://web.archive.org/web/20100103...573T/index.htm Quote:
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
06-03-2020, 10:34 AM | #30 |
I recently did this video to explain alignments to my highschool auto mechanics students. You might find it helpful:
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate Last edited by SkinnyG; 06-03-2020 at 10:59 AM. |
06-17-2022, 07:06 PM | #31 | |
06-20-2022, 08:02 PM | #32 |
Well, I ran strings parallel with the back wheels and checked it couple places along the frame to make sure they were right on parallel.
The front wheels were about 3/4" toe out. So I put them at 1/8 inch toe in and now it shimmys when I get up above 40mph. It drives straight, but it shimmys. Before it would pull whichever way I was turning, but it didn't shimmy. Any idea what to check? Oh, it isn't a wheel out of balance, because I know that feel. This you can feel the front end shimmying side to side.
06-20-2022, 08:19 PM | #33 |
Looks like I might want to check things again.
I may have got something wrong in that too much toe in can cause a shimmy. From Motor Trend: "The front wheels on most rear-drive road cars benefit from a touch of toe-in. It compensates for the road force that can induce a toe-out condition. Toe-in also eliminates lash in the various components, which enhances straight-line stability. Excessive toe-in can induce a bear of a shake. It causes the tires to fight each other for traction and the rapid release/traction cycle can cause a shake."
06-20-2022, 10:27 PM | #34 | |
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
06-20-2022, 11:21 PM | #35 |
Maybe you have a measurement error?
How are you making sure the strings are parallel? You cannot measure off the front and rear wheels, as the track width is different.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
06-21-2022, 12:05 AM | #36 | |
But yeah, now I remember that I should just run the strings perfectly parallel front to back. So I'll do it again but make sure the strings are the same distance apart front to back. I'll post back how it goes. Thanks.
06-21-2022, 12:06 AM | #37 | |
I forgot all about that.
06-22-2022, 01:33 PM | #38 |
Yeah, I re-strung the strings and made sure they were exactly the same distance apart at the rear of the truck and the front of the truck. And parallel with the truck.
I think I was in 1/2 inch too far. So, maybe they were originally only 1/4 inch toe out. Either way, I'm first going to take it for a test drive this afternoon, but then I'm going to string the lines one more time to verify. I know this method works, because I did it on my 65 early on - along with a framing square for camber, and the tires wore evenly and it didn't pull any direction.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 06-22-2022 at 01:39 PM. |
06-22-2022, 08:37 PM | #39 |
Still shimmying at around 45.
What's the name of the arm opposite of the pitman arm that keeps the draglink level? Leveling arm?
06-22-2022, 08:44 PM | #40 |
Just remembered: it's the idler arm.
Gonna replace it - it's got some play in it.
06-24-2022, 05:45 PM | #41 |
I use pieces of straight edge (pieces of 3/4 angle steel) draped over the wheel/tire using a bungie cord to hold them approx @ center of the hub.
Pull & compare the measurements @ the F vs R of the front tires. Adjust the tie-rods to dial it in. Roll the vehicle/tires forward/backward if possible between rounds of measurements/adjustments.
