Old 05-17-2010, 07:43 PM   #26
USSkoval
Re: New Suburban Project
Looks real good, and very clean!
As for the two-tone discussion previously, that's how it was done at the factory in the '89-'91 years. Always drove me nuts too. I would have to paint from the marker light down.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 05-17-2010, 07:44 PM   #27
C20_Paul
C20_Paul's Avatar
Those wheels look SHARP!
Between those and the drop you've got a whole new truck!
C20_Paul is offline   Reply With Quote
Old 05-18-2010, 09:25 AM   #28
justpball
justpball's Avatar
love the roll up windows too! Super nice truck bro!
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 05-24-2010, 06:39 AM   #29
13gman
13gman's Avatar
Man, really nice looking burb! cant wait till I finsh mine, Did you you a c-notch with the flip kit?
13gman is offline   Reply With Quote
Old 05-24-2010, 09:32 AM   #30
rdm1208
rdm1208's Avatar
Thanks, no I havent c-notched it yet. With the flip kit and then adding a 1" lift shackle I have approx 2" clearance full of fuel with the family inside. I dont really want to notch it so I may try a set of the air-lift, slam air bags just to help it out a bit. I wont be going any lower than what it is right now.
rdm1208 is offline   Reply With Quote
Old 05-25-2010, 09:54 PM   #31
87 chevy silverado
i like it as is it is one killer burb and very clean
87 chevy silverado is offline   Reply With Quote
Old 07-03-2010, 02:51 PM   #32
BGRAFX
Your suburban looks really good! Thats the exact stance I want for my Suburban, so I'm looking for specific info to order wheels and tires. Are you happy with the tire size you chose? I think 40 sidewall looks perfect.
What size rims are on there? 20x8 20x8.5 20x10
what offset/backspacing?
where did you order them from?
BGRAFX is offline   Reply With Quote
Old 07-04-2010, 09:58 AM   #33
rdm1208
rdm1208's Avatar
BGRAFX: Thanks. The wheels are 20 x 8.5 front and 20x9.5 rear, think it is a standard offset and no ther choices. I had to use a 1.25" wheel spacer on the rear to get the wheels out far enough. The front i had to use a .5" spacer with special lugnuts that went down inside the wheel a little. Maybe not special but was hard to find around here. I am not sure if my front wheels were the older hub style but either way it worked good. The tires are 245/40/20 front and 275/40/20 rear. The front will rub a little on BIG bumps but not to bad. I bought the wheels from a local vendor, the cost was $1300 out the door, complete package.
I used the western chassis kit front and rear and then thru on some slam air bags on the back to help out a little. I didnt notch the frame and the bags were just enough so the axel didnt hit the frame. I also used 1" lift shackles on the back becuase the full flip kit was to low and not level.
If I had to do it over again the only thing I would change is not buying the shocks from Western Chassis, they made the burb ride like a cement truck. Once I took those off it rides like a cadillac.
Old 11-25-2010, 08:43 AM   #34
85silverbeast
85silverbeast's Avatar
It looks real clean bro. What shocks are you running now?
85silverbeast is offline   Reply With Quote
Old 11-25-2010, 02:59 PM   #35
kikkegek
kikkegek's Avatar
WOW!
really nice one!
kikkegek is offline   Reply With Quote
Old 12-11-2010, 10:21 PM   #36
texassquarebodies
Truck Nut
texassquarebodies's Avatar
rdm1208.....do you think I could get some pics of your rear air bag set up??? Also, can you tell me where you got your brackets?? I have a dropped burb that sits too low in the rear.
Tony Kee
Texas Square Bodies
texassquarebodies is offline   Reply With Quote
Old 12-12-2010, 11:37 AM   #37
rdm1208
rdm1208's Avatar
texassquarebodies: I sold this burb so I cant get any pics for you. I used the slam air system, I think I ordered it from summit. Simple install, the only thing that was off, I had to space out the passenger side about 1". I also used a 1" lift shackle from western chassis. A little grinding for clearance but worked good. Between the shackle and bags I didnt have to notch the frame. Even with a load the axle never hit the frame.
85silverbeast: For the shocks I ended up with using the cheap summit shocks in the rear, I think they were made by doechtech or how ever you spell it. And I used stock shocks in the front, that was the best ride I could get without spending more money on shocks.
Old 03-24-2011, 04:24 PM   #38
ryanmcb
Did the Burb go to another board member? Do you have any contact info to get in touch with the new owner? Thanks!
ryanmcb is offline   Reply With Quote
Old 03-25-2011, 10:30 PM   #39
69C20CUSTOM
69C20CUSTOM's Avatar
Man looks killer. And in super shape.
2003 Nissan Frontier Crewcab 4x4-Daily
1982 Chevy Suburban 3/4ton 4x4, Mud Toy
Lookin for a C10
69C20CUSTOM is offline   Reply With Quote
Old 03-26-2011, 02:42 AM   #40
american revolution
american revolution's Avatar
you get a good deal on the rims? might be purchasing some soon. live in nor cal
american revolution is offline   Reply With Quote
Old 03-26-2011, 10:11 AM   #41
d-666
d-666's Avatar
very nice truck!
1990 k5 blazer
1990 gmc jimmy
1949 1300 p/u-sold
1977 bbc skylark
96 roadmaster
06 9c1 impala
d-666 is offline   Reply With Quote
Old 03-27-2011, 09:09 PM   #42
dropd80s
dropd80s's Avatar
Dont know that I have seen manual windows and power locks, pimpin.
dropd80s is offline   Reply With Quote
