#26 |
Restoration Virgin!
Re: putting 71-72 brakes on a 68?
68....asked this question awhile back....see if this thread helps any....http://67-72chevytrucks.com/vboard/s...d.php?t=381785
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
#27 |
ok so i would also have to get new ball joints for a 73+. now all i have to do is find a 73 and up parts to do this
#28 |
I put the complete crossmember from a 76 1/2 ton onto my 67 1/2 ton. I used the master and proportioning valve from the 76. You need to increase the bore of the rear wheel brake cylinders to the 1 1/16 variety or your rear tires when braking will lock up too easy in the wet. The inner tie rod end is from an 89 3/4 ton. Have the machine shop knock about 1 1/4 inches of thread off (That'll leave you with about 5 inches to the good).
So that being said, now you have 5 bolt lugnut pattern up front and 6 bolts on the rear. So for the rear I used a 3 series diff housing from the mid 70's or 80's so I dont have to run around with 2 spare tires. Weld new spring purchases in new locations. Pete |
#29 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-17-2010 at 10:48 AM. |
#30 |
Thats a good point. Its totally dependent on your situation, and as with anything, do a lot of reading and research so you dont have to completely reinvent the wheel every time you come up with something you'd like to do. Us older guys have been through many projects, and its important to just take it all in, and then just do what you were going to do anyway!
#31 | |
gets board easy.......
#32 |
humm, i thought the frames were narowwer on the 72-older trucks.
And ive been using the orig crossmembers from 72 |
#33 | |
Google AGR or try Flaming River.
#34 | |
68 C/10 short bed 77 C/20 silverado long bed 05 GMC Duramax Crew |
#35 |
I drilled the weld hole out and bolted it on to the otherside. If i remember right the hole was already there. Yes you will need to change the lines they are larger. I just bought a set from LMC. I had to redo the passenger side line. It was to far inside the frame rail i couldn't use my headers. It would have boiled the brake fluid. So i ran the new line in front of the motor mount. Then run it over the sub. I'm getting ready to run rear disc next.
#36 |
again sorry its been a while, i found a 73 what i and going to get the parts off of tomorrow if it doesnt rain, i got the spindles and rotors the other day and cleaned them up and painted the spindles, going to grab the calipers, master cylinder, booster, proportioning valve, hard lines, tie rods ends, center link, and maybe the rims,.
im going to get new ball joints and wheel bearings, ill try tokeep you guys updated a little beter from now on, also im getting a rearend out of a 71 or 72, so that i can keep the rear coils and go with the matching 5 lug, and something a little better than 4.11 gears lol |
