Old 10-30-2012, 08:41 PM   #26
bonehead
bonehead's Avatar
Re: 60-63 Spotlight Installation
Has anyone tried installing a spotlight on a 64-66 c-10 cab. Would it mount to the cowl or thru the post?
I would prefer the cowl mount. any pics?? inside and outside??
past trucks:
1980 C-10 Silverado SWB
1961 C-10 custom cab LWB
1966 C-10 custom cab LWB
bonehead is offline   Reply With Quote
Old 10-31-2012, 01:05 AM   #27
markeb01
Senior Enthusiast
markeb01's Avatar
This thread will answer your question, and has additional links which shows the inside and outside holes with the spotlight removed:
http://67-72chevytrucks.com/vboard/s...ight=spotlight
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 11-02-2012, 01:35 AM   #28
Brad54
Brad54's Avatar
Here's my '61 Suburban with twin spots... I found the factory mounting brackets for both sides.
The hard part was drilling the hole through the dash from the outside--it required a looong drill bit. Fortunately, I had a stubby 1/2-inch bit, and a length of 1/2-inch rod in my scrap bin, and was able to weld the rod to the drill bit and make a foot-long bit. The most amazing part is that it turned true! Wasn't warped or wobbly.
I also got parts through Accessoryland... great guy, and VERY knowledgeable. I hope he's still up and running... I need to get a set of spotlights for my '54 Buick Special.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 11-02-2012, 08:25 AM   #29
1963c-10
1963c-10's Avatar
Brad, your burb looks great.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 11-05-2012, 12:09 AM   #30
Brad54
Brad54's Avatar
Thanks. I've had it for 7 years, and in that time I've dropped a crate engine in it (290hp 350), New Process 4spd OD manual trans, rebuilt the Dana 44 with 3.42 gears, dual reservoir/power brake conversion, rebuilt the brakes with self-adjuster mechanisms, new 3/4-ton radiator, American AutoWire wiring kit, full instrumentation gauge cluster rebuilt by AutoInstruments, shifter mechanism rebuilt by Hurst, had the bumpers rechromed, and put new floors in front.
I've put nearly 60,000 miles on the new engine (and drove the original 283 for two years), and it's been through 20 states.
Next up is rebuild the front suspension, drop-spindles, disc brakes and the front sway bar I'm manufacturing, and then paint. I've got another hood that's got a bad dent but not as many other dents, a pair of workable front fenders, mint doors, mint grille support, chrome grille and tail/lift gate set-up to replace the elbow-killing barn doors.
-Brad
Old 12-09-2013, 09:19 PM   #31
socaljess
socaljess's Avatar
what lenth spot light shaft is good to use ?
project 66 flat n low
socaljess is offline   Reply With Quote
Old 12-09-2013, 10:33 PM   #32
markeb01
Senior Enthusiast
markeb01's Avatar
If you are going to use the factory outside bracket #187 (1964-66) the original specified length for the correct spotlight measures 12". This is the distance from the centerline of the handle to the centerline of the lamp head pivot. With the lamp completely assembled off the car or truck, the dimension of exposed shaft between the handle assembly and the head assembly should be 6.5 inches.
Fyi 187 & 187R new OEM bracket kits are still available from UnityUsa. For installation help on a 64-66 this thread should help:
Old 12-10-2013, 10:07 AM   #33
socaljess
socaljess's Avatar
Thanks mark great info much appreciated
Old 07-21-2017, 08:17 PM   #34
jimbo0555
Thumbs up Re: 60-63 Spotlight Installation
Originally Posted by MadnessBigBlock View Post
Hey I got spotlight mounting templates and instruction sheets for 55-59 60-63 64-66 and 67-72 trucks. If any of you need a template and instruction sheet just pm me and i can send you a copy to exact scale!
I'm going to need one for my 63' chevy truck. Thanks
jimbo0555 is offline   Reply With Quote
Old 07-21-2017, 10:41 PM   #35
65chevysub
65chevysub's Avatar
Originally Posted by Revoh View Post
Yeah, it's just an old magnetic metal flashlight. I have the truck lettered up with my granddad's old car lot name painted on the doors. He closed them in the early '70s. There are three things that actually came from the car lot--that old flashlight, the tissue dispenser, and the red glass jewels that hold the back license plate on. They're just little bits of history that probably I'm the only one that thinks are interesting, but I try to preserve as much of the past as I can.
I got one of those magnetic flashlights. Great conversation starters.
65chevysub is offline   Reply With Quote
Old 07-21-2017, 10:43 PM   #36
65chevysub
65chevysub's Avatar
I think it's kind of funny that this thread showed up now. I'm trying to find instructions how to remove a Unity Model S04 from my 2003 Crown Vic CVPI. got someone wanting it to put on his FordRanger
Old 07-26-2017, 02:06 AM   #37
Short 3/4
Originally Posted by tcb-1 View Post
Unity still has any spare or repair part you'll ever need and everything is still made in the States as well. I rebuilt several over the years.
great info!
I agree. They are great people to work with. They even rebuilt some old lights I found and charged me very little .
Short 3/4 is offline   Reply With Quote
