Old 06-06-2010, 12:19 PM   #26
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Re: leaf spring lowering
Originally Posted by C/10 King View Post
Okay, Here are the pic's.......One old,and four new Tada.......
Not much difference to me.
Slam it, Dam it
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 06-06-2010, 03:19 PM   #27
C/10 King
C/10 King's Avatar
Talking Re: leaf spring lowering
Slam it, Dam it
Kev,Put a SOCK in it!!!!!!!
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 06-06-2010, 06:20 PM   #28
KevsClassics
TILT COLUMN GURU
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
RIP EL JAY
Old 06-06-2010, 06:52 PM   #29
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
I believe that chevelle springs will work as well. Much less arch on them.
low'n slow is offline   Reply With Quote
Old 06-11-2010, 09:40 PM   #30
exmonkeypunk
Barrito Loco Diablo
exmonkeypunk's Avatar
Anyone have a rough estimate as to how expensive it would run ya having a shop cut and weld the spring perches? I assume any muffler shop could take care of that.
All 4 of my shocks are who knows how old. They ride like crap. After lowering would it be any wiser to spring the few extra bucks for the "lowered" truck shocks? Or would a regular pair of monroe gas or sensa trac suffice?
Gotta add, i really like how this thread is turning out. All these rear leaf trucks coming out of the wood work. I also daily drive my 3/4 ton 72'. The gas is killing my wallet, but it sure keeps me happy.
exmonkeypunk is offline   Reply With Quote
Old 06-11-2010, 10:22 PM   #31
tasian
tasian's Avatar
you'd want to take just the axle in and already have everything mocked up (centered with right pinion angle etc) just because they can weld doesn't mean they have rearend experience but with them just having to lay down a couple welds im sure you could get it done for between a 12-pack and 50 bucks
for the shocks you don't Need them unless your shocks are bottoming out but if your already replacing them you might as well spend your money on something thats going to work better for you
heres a picture of my truck with just a flip kit in the rear i haven't put a C-notch in yet its about sitting on the bump stops same ride height without the washing machine
Betsy's build
70 c20 4 speed 406sb
tasian is offline   Reply With Quote
Old 06-12-2010, 08:15 PM   #32
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Looks like its time for some drop spindles and springs
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 06-12-2010, 08:26 PM   #33
BHyatt
Originally Posted by scooterskoolkustoms View Post
If you have leaf springs a flip is the way to go.I went to speedway motors and bought new perches @ 12.99 pair 545-85090,and new u bolts @3.99 each 910-43801.I drilled a hole 1" forward on the perches and reused the old plate with a new hole 1" forward.dropped the burb 7" in the rear.under $30.00 plus $10. shipping.
Can you clarify what you mean by drilling a hole 1" forward? You say that you ordered perches then reused the old plate....What plate? If the new hole is in the perch does it interfere with the u-bolt?
Last question, What about shocks?
BHyatt is offline   Reply With Quote
Old 06-13-2010, 05:49 PM   #34
exmonkeypunk
Barrito Loco Diablo
Old 06-13-2010, 05:51 PM   #35
exmonkeypunk
Barrito Loco Diablo
Mine aren't bottoming out, but the ride quality is horrible. Like riding a horse everywhere. I was hoping replacing at least the rear shocks would help out with that a little.
Old 06-13-2010, 10:14 PM   #36
rennalds
Ok so we finished up lowering my sons trucks last week. We went 2.5 spindles and 1.5 coils in the front and DJM Flip Kit in the back. the truck is sitting pretty level. There is no hole to drill. the axle locator that comes with the kit has it already drilled into it so I'm not sure what people are actually drilling. My next question is How do we know if the pinion angle is correct??? At the correct pinion angle are the locator brackets tilted slighty to the front? Thanks for all the response and help!!!!!!!!!!
rennalds is offline   Reply With Quote
Old 06-13-2010, 11:57 PM   #37
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Just Google 'Setting pinion angle'. There are a lot of write-up's out there on the subject and even some video's. I drove about 400 mile's before I shimmed mine and it toasted my already tired U-joint's.
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 06-13-2010, 11:59 PM   #38
dieselarmy13
Oh, by the way.......WE NEED PIC'S!!!
Old 06-14-2010, 12:34 AM   #39
ERASER5
ERASER5's Avatar
I lowered my 3/4 ton on Friday. At first, I dropped it about 10". I later adjusted it to about 4", and then later back to stock height. I used 5,000 lbs of gravel.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
