Old 03-20-2014, 06:36 PM   #26
Tinkermc
Re: 68 C10 w/ no marker lights?
68's had no marker lamps on the sides they did however have reflectors front and rear.
Tinkermc is offline   Reply With Quote
Old 03-20-2014, 07:46 PM   #27
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
I saw a 67 one time that had side park lights and it was listed on the spid as an option ,,,
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 03-20-2014, 10:04 PM   #28
i love my c-10
My 68 had markers on the corners but removed by PO. However I have an original cab with the rear view mirror on the cab ceiling and a foot e-brake not the hand brake. I often wonder if GM even kept up with this stuff.
i love my c-10 is offline   Reply With Quote
Old 03-20-2014, 10:35 PM   #29
too much stuff
Roadtrip!
too much stuff's Avatar
This is correct.
I would bet it was listed as marker lights on the spid which would be roof lights i believe. I don't think the side lights were ever listed as an option.
That would be correct for a 69-71 cab.
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again...
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 06-17-2017, 10:59 PM   #30
johnac
While doing rusty firewall and rusted out wiper motor mount repairs on a 69 GMC I had all the wire harness out from under the dash and straightened it all out before putting it back in.
With the plug for ignition switch melted and wired around, a toggle switch for the distributor, being changed to electronic ignition, and a single wire alternator I ended up taking the engine bay harness apart and started figuring out cut wires and rewires there also.
In the process (related to this thread) I couldn't figure out all the little brown wires with no place to go. This is a 69 GMC Long Box and it has reflectors all around but appears the harness is partially wired for the lights.
If your pickup has reflectors and you want lights, unwrap your harness and you should find wires to connect to.
Also there is a 1969 C10 short step side Chevy in the yard, it has reflectors, wire harness is mostly gone though. It is a fairly original forest service truck.
This all seems consistent with the other info about what years still had reflectors.
The 2 wires over the green rag are the brown ones. I think I know where to go with the big red and the big green wires.
johnac is offline   Reply With Quote
