#26 |
Dually Pride
Re: What did you get done 5/16/2010 half through May edition
bought some parts this weekend, a 80 grille and a new glove box for $20. and I pulled a 73 GMC grille, brackets and trim for $25. i grille is crappy but I'm going to try to make inserts with steel mesh...hey the mesh was free!
If I have to explain, you wouldn't understand. '74 Chevy C-30 350/4 speed/dually ![]() '94 Ford Ranger |
#27 |
New rear shocks on the truck! Tune up on a friends Kia Sedona which required pulling the upper intake manifold. Wish the engineers would think when they designed this stuff. Last was a trans fluid change plus new vacuum lines on another friends Audi S4 that we drove from New York to Wisconsin last month. Than I took my truck for a nice long ride to the local ice cream stand to enjoy my new suspension.
#28 |
Do you have a build thread anywhere? You need one or at least a thread on how your doing the swap. I'm working (loosely used term) on one to and would like to see how your going to locate the crossmember. My build thread is in my sig, but 50-60 hr work weeks since last Oct have prevented me from doing anything but parts gathering....
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
#29 |
yeah.. but i don't think i've added anything since the original post...
i should start doing that.. as for locating it... im not sure, the frame seems to be tapered ever so slightly.. i don't know if it;s supposed to be but mine is... so im just going to lift it to the frame and slide it back until it's tight and see if that's going to work.. I've read that 4wd to 2wd thread a couple times... and he says there's like holes on both frames... but i have not seen any.
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
#30 |
>130dB Moderator
I was at work all weekend and at night i was doing house work. This weekend I plan to tear the little truck down and do more dynamat. I need to take the dash out and give it some sound dampening as well.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
#31 | |
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ Last edited by bluex; 05-19-2010 at 01:22 AM. |
#32 |
Now that is one nice cab belly!
Project #1 "Pops"--1980 Chevrolet Scottsdale C10 3rd Generation in the same original owner family. GOAL: Restore to "almost" original. View Project Pops HERE Project #2 "Cletus"--1986 Chevy K20 4.10 Gear Ratio GOAL: Restore into a heavy duty work/plow rig View Project Cletus HERE - SOLD DD--2008 Duramax CCSB |
#33 |
Junior Member
Replaced the front fender on the 77 (rusty, only spot on the whole truck), got her side repainted. Pulled off the cheap side moldings. I probably will put some new moldings on her next month after I get the rest of the truck reshot.
I let my 16 year old son drive my every car that I own. I don't let him drive my truck. A man has to draw a line somewhere. |
#34 |
Me and my son installed a billet grille into the '87.
California Shloopter '87 fleetside shortbed, 5-7 drop, stock engine '66 VW Beetle, on the ground '57 VW Manx copy, work in progress |
