06-04-2010, 12:05 AM | #26 |
Re: Opinions on overdrive transmissions
I didn't see this mentioned unless I over looked in in the other posts. But,, What about a Gear Vendors under/over drive? A well built TH350 W/ a Gear vendors, is a dang bullet proof tranny combo. not to mention the 3-speed would be a technical 6-speed. The price is a bit more initialy but seems to be a simpler of a setup and once again bullet proof.. Look them up at: http://gearvendors.com/
A TH350 to be rebuilt comparable to a 4l60 is roughly half the price. And most likely you would have to have the driveline reworked anyway. But you wouldn't have to get a different crossmember with the G/V unit. between friends and I, We have had quite a few blowouts with the 700R4s and 4L60's, They are just not as stout as a good ole TH350 or even a TH400. That is at least my plan for the near future with my 71 blazer. |
06-04-2010, 07:29 AM | #27 |
The gear vendors overdrive unit is a good solution but it is quite a bit north of the $1700 figure people are tossing around. AND if you have 4wd, you can only use it when you are in 2wd.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
06-04-2010, 09:45 AM | #28 |
Gear Vendors is the last overdrive you`ll ever need.That`s what I plan for my 4spd`67...eventually.Meanwhile I`ll drive a bit slower and listen to that sweet 327 do it`s thing.If it happens it happens.If not...oh well.
06-04-2010, 11:20 AM | #29 |
I installed a Gear Vendors overdrive on my 72 C-20 a couple of years ago and it works great. Bought it on Ebay for $1,600. I keep it in "auto" mode so essentially, I have a 4 speed automatic transmission. My Turbo 400 shifts up through all of it's gears then the GV kicks in at about 40 MPH. Made a huge difference in the way the truck drives.
