#26 |
Re: 2wd lift kit
ok so i have a 3/4 ton truck. the upper ball joint will be fine for the spindle but the bottom one has to be changed or?
Lifted 2wd 1969 C20/ 5.3LS/4L60E :http://67-72chevytrucks.com/vboard/s...d.php?t=728388 |
#27 |
Re: 2wd lift kit
Any word on this? I am trying to lift my 72 c20. All help appreciated. Thanks
Nick Old pic of my 72: http://img340.imageshack.us/my.php?image=img0435co5.jpg 04 Silverado Daily Driver 68 GMC short step http://67-72chevytrucks.com/vboard/s...d.php?t=379665 "I'll beat you to the gas station!!" ![]() ![]() |
#28 |
Re: 2wd lift kit
I got some answeres, as far as a lift, what i was told had to be done was to convert to 73-82 i believe front control arms, spindles, linkage ect. . . and then buy a lift for that year. i might be off on the year but ill research my past posts around here and ill try to find out for sure.
#29 |
Re: 2wd lift kit
the 71 and 72 3/4 and 1 ton susp are the same as the 73-87 3/4 and 1 ton susp. you don't have to change anything. The only "suspension" lift on the market is the Fabtech kit for the 1/2 ton 73-87 truck.
www.cardomain.com/id/pooz911 |
#30 | |
Re: 2wd lift kit
Good luck finding a kit. . There impossible to come by and a few grand if you do catch one. . . it was the 88-98 spindle option that some were saying would work, just gotta change the ball joints and then you can do a spindle lift. Also here is a kit made for our trucks its just not high enough for what im wanting. but heres the link in case any of you want it. http://www.airbagit.com/product-p/x2-car-gm6387h.htm
#31 | |
![]() Quote:
http://store.fatbobsgarage.com/chevy...nly-p5636.aspx Last edited by QKENUF4U; 09-23-2010 at 01:01 PM. |
#32 |
Re: 2wd lift kit
K you got me interested, How would you do this???
#33 |
http://www.google.com/products?q=199...w=dd&scoring=r
if those arms would work then these spindle would work.... ???? |
#34 | |
Re: 2wd lift kit
#35 | |
![]() Quote:
#36 |
Re: 2wd lift kit
after reading all the links on this site, its still not clear as to what to use to lift a 87 suburban 1/2 ton 5 lug.
from what i gather, i need 4" lift spindles, 88-98, 3/4 ton lower a arms,(year) and what ball joints do i need to buy ? (year) thanks |
#37 |
Re: 2wd lift kit
My step Dad owns an autoparts store that I work at. Sometime this week, I will go through the parts books and see if I can find something that will work. I have a feeling that the ball joints and tie rods won't be an issue, but the brakes could be. I'll check back with the info that i gather.
#38 |
Re: 2wd lift kit
Kewl...
#39 |
Re: 2wd lift kit
TTT
Any updates on this?
69 Chev C20 396 T400 Dana 60 3.54 A/C Daily Driver - Stolen 67 Chevy C20 CST |
#40 |
gets board easy.......
Re: 2wd lift kit
#41 |
Re: 2wd lift kit
You can use 73-87 lift spindles and or a fab tech kit "but they sag so you won't get as much lift as claimed by the kit.
#42 |
Re: 2wd lift kit
Orry I guess I should read. The topic has changed it seems since I last posted. On the newer trucks they make different kits I think. But I did figure out how to lift a classic 2wd
#43 |
Re: 2wd lift kit
i dont think fab tech makes 2 wd lift spindles anymore? anyone?
#44 |
Re: 2wd lift kit
Ok i'm gonna let the rest of u boys figure out the frontend but in my mind the best solution for the rear is to find a donor truck with a leafsprung rearend and convert ur truck to leafsprings and get a liftkit for 4x4 67-72
