#26 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: N/A 6.5 Diesel
I agree with 67C-30. These engines last a long time if not worked really hard day after day. This swap shouldn't be too bad at all since you have a donor truck. If you can't find BBC engine mounting plates, just make some your self if you have access to the tools needed. Good luck with the swap!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#27 | |
I have a radical idea!
Re: N/A 6.5 Diesel
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
#28 |
Re: N/A 6.5 Diesel
nice project! my son and i have a 67 gmc dually that we are going to build with a 6.5t nv4500 and 3.42 geared 14 bolt. i also agree the project is going to be easier with the donor truck on sight,good luck!
#29 |
Re: N/A 6.5 Diesel
Sorry i haven't replied in a long time guys. life has taken over....i have been busy with the church band I'm in and some family problems that have been going on.
But this next week i will be hitting this project full force so be looking for updates!! Cheers ![]()
![]() ![]() 2000 Ford Powerstroke (daily driver) |
#30 |
Re: N/A 6.5 Diesel
SHE LIVES!!!
i have been spending the last weeks tracking down a fuel problem and glow plugs malfunction. i figured everything out and once she had a steady flow of fuel she started right up and never hiccuped once. Now that i figured my problems out and the motor is running i am ready to start breaking everything down and start on the swap! stay tuned. ![]()
#31 |
![]() Join Date: Aug 2001
Re: N/A 6.5 Diesel
COOL... I'M JUST DIPPING MY TOES SO TO SPEAK ON THIS DIESEL THING MYSELF. I JUST BOUGHT AN 84 MILITARY BLAZER WITH A 6.2 NON-TURBO DIESEL BACKED BY A T-400 NP208 COMBO. AT 52.. I'VE NEVER OWNED OR WORKED ON A DIESEL... BUT I'LL LEARN. MY NEXT IDEA IS TO FIND A WRECKED OR OTHERWISE JUNK LATEISH 80s CHEVY TRUCK WITH A 6.5 TURBO, JUST TO TEAR APART, & LEARN HOW THEY OPERATE. GOOD LUCK ON YOUR PROJECT..... IT CAN BE DONE.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
#32 | |
*** That's interesting ***
Re: N/A 6.5 Diesel
Tom ![]() Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
#33 |
![]() Join Date: Aug 2005
Re: N/A 6.5 Diesel
I have a lot of years as a diesel mechanic. 6.2's and 6.5's are great little engines. As others have posted, they were designed for economy, and they are not a medium duty commercial engine like the Cummins B5.9 (Dodge Ram) is. But, the 6.2L and 6.5L weigh about the same as a Big Block Chevy, and the motor mount locations and bell housing bolt patterns like any Chevy V-8, so the swap is much easier. A 4 row Big Block radiator should be fine if you are not towing a lot. 6.5's have better block and head castings than the 6.2 did. If you are using an automatic transmission, be sure to get a diesel torque converter, it has a different stall speed than the gas one does. In stock form without a turbo, the 6.5L makes about 145 h.p. and 300 ft. lbs. of torque. I know it doesn't sound like much, but the torque curve is very flat and comes on early, so it will pull the truck around just fine. 6.2's and 6.5's rev. good for a diesel, so your stock gearing should work (try that with a Cummins!).
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
#34 |
Re: N/A 6.5 Diesel
THERES AN AWFUL LOT OF THESE OLD MILITARY TRUCKS & PARTS AVAILABLE RIGHT NOW WITH EVERYONE SWITCHING TO HUMMVEES.(EVEN THE GSA IS HURTING FOR MONEY) EXAMPLE... BRAND NEW 1985 6.2 DIESEL CRATE MOTORS WITH EVERYTHING BUT THE STARTER & TWO ALTERNATORS...$1799 , NOS HOODS.. $90 , NOS REAR BUMPER WITH FACTORY HOLES FOR BLACKOUT LIGHTS & TIE-DOWN BRACKETS...$40 . I BOUGHT THIS M1009 (84 3/4 TON BLAZER) THREE WEEKS AGO & HAVE BEEN WORKING ON IT EVERY DAY SINCE, GOING OVER EVERYTHING WITH A FINE TOOTH COMB, & LEARNING SOME NEW STUFF TOO. I'M 52 & HAVE BEEN BUILDING BIG & SMALL BLOCK CHEVYs FOR 35 YEARS, BUT HONESTLY BELIEVE I'LL BE SELLING OFF MY HOARD OF GAS ENGINE PARTS IN THE NEAR FUTURE (I HAVE A FEW) & GOING STICTLY DIESEL. THE FUTURES HERE... & IT SMELLS LIKE DIESEL FUEL TO ME.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 07-17-2010 at 09:32 AM. |
#35 |
Parts Hunter
Re: N/A 6.5 Diesel
I've got about 7600 miles on my 6.5 TD conversion in my 67 gmc 3/4 ton 2wd. I've had pretty good luck with it using a dmax clutch fan, and upgraded cooling parts from ssdiesel supply. I had a really slight coolant leak at the neck and was towing about 6K at 100 degrees and my water temp stayed around 220 with a stock 4 core radiator. When I got home I found I was just shy of a gallon of coolant. I've also done quite a bit of mods on my engine. Check out the link in my signature for my build and the rest of the specs on my truck.
1968 Chevelle 300 DLX (350 4 speed) 1984 GMC 2500 6.2, 700r4 work truck 1967 GMC Custom (was 6.5 Turbo Diesel powered) My ebay Store: http://stores.ebay.com/The-Musclecar...3aFQ3aSTQQtZkm My website:http://themusclecarshop.net/ 1967 GMC 6.5 TD conversion build:http://67-72chevytrucks.com/vboard/s...d.php?t=290922 |
#36 |
Re: N/A 6.5 Diesel
Any updates?
#37 |
Re: N/A 6.5 Diesel
WOW its been forever since i have posted on this thread, i have been busy with traveling for my new job. but recently i have started on the project again! i have the motor bolted down and in place...radiator and battery trays mounted. I am about ready to start working on wiring this baby up. I am a complete idiot when it comes to wiring, is there anyone one here that can kind of give me a break down of wiring for a dummy? I really appreciate it guys! stay tuned for updates, im going to be hitting this project hard for the next few months!! Ill post pics tomorrow.
#38 |
Re: N/A 6.5 Diesel
Ok everyone here are the pictures i promised. I guess the best way to update on this thread is to start from the beginning.
#39 |
Re: N/A 6.5 Diesel
Here are some more pictures of disassembling the truck, we took the 350 out of the engine bay and discovered a few nasty cracks.....
#40 |
Re: N/A 6.5 Diesel
In the words of Adam (Mythbusters)
"Well theres your problem lady!" That is nothing a bottle of alumaseal wouldn't take care of......
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
#41 |
Re: N/A 6.5 Diesel
OK, I'm going to throw my usually rational, practical, logical, yet sometimes uneducated opinion into this. Sure, rebuilding a 350 Chevy engine is dirt cheap, if you do everything yourself. First of all, looks like the young man will need another block or core to start with (I don't think you can put enough Bars Leaks in that block to make it hold water), so there is money out of pocket for a block or engine core, then you may have to bore the new block if it's worn-out and buy a new set of pistons. Basically, "Rebuilding" a Chevy 350 isn't as thrifty as everyone makes it out to be. He already has a running engine, with a working transmission, in a complete other truck. The motor mounts should bolt right up and there may be some modding required for a trans cross member. The glow plug circuit shouldn't be that difficult to transfer over from the 85, just start at the glow plugs and trace the wires back until they lead to a 12v power source and install everything in-between. If it needs a return fuel line, you got a whole parts truck sitting there it'll have the line in it. Cooling issues, I do not know the depth of that, but a 4-core radiator with a flex-fan should keep it cool enough? The biggest expense I see is having the driveshaft modified to mate-up and fit. I think this will work and would be the cheapest route, just do everything yourself.
1968 C-10 Longbed, 6-cyl., 4-speed. 832-584-1245 "You see, in this world there's two kinds of people, my friend, those with loaded guns and those who dig." |
