#26 |
![]() Join Date: Mar 2010
Re: Driving straight is harder then it looks, problem.
iv'e posted new replies if you didn't see them. pictures tommorow around lunch.
trv67 |
#27 | |
Caster shims are one way to adjust your caster but use the 4 degrees if you need 4 degrees. Let the alignment shop tell you where your caster is to begin with, along with the condition of the rest of your front end. Aftermarket lifts and poly spring bushings both introduce squirrelyness in your steering. The original bushings are infinitely stiffer, as are the stock springs (longitudinally). If you look down the front axle at the steering arm from the passenger side while someone else is turning the wheel back and forth, you'll wonder how you could control the truck at all. The whole axle rocks back and forth, storing energy in the spring and bushing, so it's a constant fight to drive straight. One solution is to go crossover, but that has it's own challenges. Whatever the case, lift or otherwise, if your front end is tight and well aligned it should be more than manageable to drive so somethin aint right!
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod |
#28 | |
#29 |
71restorod and any others that dont have the steering problems. take the bracket in question off, its only two bolts. then take a long drive and reply back. THIS IS ONLY A TEST. LETS DO IT FOR CHADGILES70.
trv67 |
#30 |
Heres pics of the part.
trv67 |
#31 |
If you have a 4" lift or more you need 4 degrees of caster or more. The leaf spring stop stopped the crazy steering problem that me and chadgiles70 have. My front end and steering wheel also would start shaking real bad after hitting a bump the four degree caster shims fixed that.
trv67 |
#32 |
Broke and still trying
check the rag joint on the steering box. It may be loose, torn, or just totally FUBAR!
#33 |
I agree with 71RestoRod completely, I have never even had the bracket on my blazer and my steering works perfectly, the Blazer does not drift or shake in any way... I have read at least one post that discussed the bracket and everyone was in agreement that it was for recall purposes only. Hope this helps. BTW, I also have a 4" lift.
-Tristan |
#34 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I have a 6 inch life and those brackets are still on there with no problems id check the rag joint for sure... blu70k5 does your blazer have an aluminum roll bar in it?
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#35 |
FRENCH,
No, I don't currently have a roll bar but I'd like to get a mild cage eventually. -Tristan |
#36 |
sharp as a marble
![]() Join Date: Jan 2007
I assume it is a 4wd? IF it is a 2wd very low caster number will make them do this. My experience is 2 wd. if you have negative caster these guys will wander? In my shop, I have a rule of thumb - - - get as much positive caster as you can, without running out of bolt on the control arms. We like about .5 caster spread from the right side to the left. HERE WE GO
right side is 1.0+ I would like the left side about .5+ caster. This will correct for the crown of the road. Meaning that Technically the truck SHOULD pull left? But the road crown will make it drive straight. I have seen our old tired truck have -2 degrees camber because of suspension drops and old age |
#37 | |
The purpose of the recall bracket shouldn't be taken lightly. Don't attempt to adjust it too close to the spring. You don't ever want that bracket to touch the spring, especially with lifted and arched springs which, when flatened under compression, will build up huge stresses if confined. You could easily bust a spring or knock loose the rivets from the front spring mount. Sort of defeats the purpose of the recall, doesn't it. I'm not blowing smoke, simply dispelling the misinformation. Here are a couple of pictures for you. The first is out of my webshots album taken of the buildup back in 2004 when I removed the recall strap from the front spring mount along with the rear bracket. I had to remove the strap to make room for the Alcan military wrapped springs but the military wrap basically serves the same purpose. The truck was finished in '05 and I've got over 25k miles on it now if that qualifies as a long trip. I live in the mountains and built the truck for canyon roads. It handles great. The second is a phone pic taken a few minutes ago. You'll notice the recall bracket's gone. Also, here's an example of a 4" lift w/o the need for caster shims. The 9-pack Alcan springs are fairly flat so they don't wrap the axle forward. The longer ORD shackles also contribute to a positive caster which sits at about 4+ degrees total, right where it needs to be but I didn't guess... I had it measured. IMO, those cheep aluminum caster shims are dangerous anyway. If you need shims, buy the steel ones after dialing it in and weld them on. ![]()
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod Last edited by 71RestoRod; 09-03-2010 at 11:02 PM. |
#38 |
this is out of the 1972 chevrolet 10-30 series repair manual.
trv67 |
#39 |
it is NOT a recall item !
trv67 |
#40 |
1/8" if necessary. unless you use military springs?
trv67 Last edited by travis.vaughan; 09-09-2010 at 02:28 AM. |
#41 |
Travis,
I'm pleased that your repair manual specifies that the bracket should be adjusted both with the spring flattened (weight on vehicle) and so as not to touch the spring; however, please note that the adjustment applies to a stock vehicle, not one with aftermarket springs. I pulled the following information off of the National Highway Traffic Safety Administration (NHTSA) web site. They maintain a database of safety recalls going back to 1966. Unfortunately, their collection of technical service bulletins weren't as inclusive. From their safety recall database: NHTSA CAMPAIGN NUMBER 71V139000 VEHICLE/EQUIPMENT MAKE GMC, CHEVROLET VEHICLE/EQUIPMENT MODEL JIMMY, K10, K10 BLAZER, K1500, K20, K2500 MODEL YEAR, 9999 IF UNKNOWN or N/A 1969, 1970, 1971 COMPONENT DESCRIPTION SUSPENSION:FRONT:SPRINGS:COIL SPRINGS MANUFACTURER THAT FILED DEFECT/NONCOMPLIANCE REPORT GENERAL MOTORS CORP. VEHICLE, EQUIPMENT OR TIRE REPORT V POTENTIAL NUMBER OF UNITS AFFECTED 124000 DATE OWNER NOTIFIED BY MFR 19710818 RECALL INITIATOR (MFG/OVSC/ODI) MFR MANUFACTURERS OF RECALLED VEHICLES/PRODUCTS GENERAL MOTORS CORP. REPORT RECEIVED DATE 19710819 RECORD CREATION DATE 19791012 RECALL NOTES CHEVROLET CAMPAIGN NO 71-C-12, GMC CAMPAIGN NO 71-C-9. ALL 4- WHEEL DRIVE. POSSIBILITY THAT UNDER CERTAIN OPERATING CONDITIONS FRONT SPRING MAY BREAK NEAR FRONT ATTACHMENT ON STEERING COLUMN SIDE. BREAKAGE COULD CAUSE VEHICLE TO VEER TOWARD LEFT IN LEFT-HAND DRIVE VEHICLES AND TO RIGHT IN RIGHT-HAND DRIVE VEHICLES. Hopefully this will put the recall debate to rest.
