Old 06-21-2010, 11:20 AM   #26
68 TT
Still plays with trucks
68 TT's Avatar
Re: 4x4 conversion
Originally Posted by 1972SuperCheyenne View Post
Since this frame was already cut to make a CCSB I was thinking about taking a K30 and cutting the frame just behind the front cab mount and the same on the CCSB and swapping the front frame sections. I have alot of fab experience and a buddy who welds for a living so this does not worry me too much but just hate to have too many splices in the frame I will be driving every day. What are your guys opinions on that?
That would be the best solution but finding a K30 for a decent price it not so easy around here. Not many around so they bring a pretty high price.
If you did it right you could put the K30 back together as a C30 and get some of your money back out of it though.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 06-21-2010, 12:06 PM   #27
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: 4x4 conversion
I know a few people parting them out so I would just go cut the front frame section off a parts truck.
--Josh
Old 06-21-2010, 12:21 PM   #28
68 TT
68 TT's Avatar
Re: 4x4 conversion
Around here that front Dana 60 goes for $1200 by itself. Hope you get a better deal.
Old 06-21-2010, 12:33 PM   #29
STOCKISH
STOCKISH's Avatar
Re: 4x4 conversion
Yeah the 60s are high as giraffe butt around here too! I am just going to use it mostly as a driver so I figure a 44HD with the 8 lug outers will be ok. Man I cant wait to get started on it.
--Josh
Old 06-21-2010, 12:39 PM   #30
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
Re: 4x4 conversion
im currently debating how i should 4x4 my 83c10 i just got. Im debating either swapping frames, or putting the 4x4 parts on my frame. B52 hangers, ord engine corssmember and heavy duty shackle, then you still need the shackle flip in the rear and change the front hangers to 4x4 style though. It would be easier keeping current frame since i daily it and it has dual tanks and other things id have to connect back up, but at the same time youve got to take the 2wd stuff off and the 4x4 stuff back on and im not sure how many of the holes the 2wd frame shares with the 4x4. Needs more research! haha.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 06-21-2010, 12:45 PM   #31
68 TT
68 TT's Avatar
Re: 4x4 conversion
The 44 will live with 33" tires through just about anything you can throw at it but when you get much taller than that they become a weak link and need some work to hold up. In a street truck it will do very well.
You will be running the same front & rear axles that are in my 78 K20 but with 4.10 gears instead of my 5.13's.
Old 06-21-2010, 06:17 PM   #32
Matt Man
Matt Man's Avatar
Re: 4x4 conversion
easiet thing to do is to find a beat k30 and swap everything from the c30 to the k30. i was going to do this until i "retired" my truck finding k30s around mee are hard everytime i found one it had really high miles. i found one that had 368k miles...
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 06-21-2010, 06:28 PM   #33
68 TT
68 TT's Avatar
Re: 4x4 conversion
Most of the time 1-ton's are worked pretty hard too so the drivetrain has seen some serious wear & tear a half ton never typically sees.
Old 06-21-2010, 07:32 PM   #34
dgodecke
dgodecke's Avatar
Re: 4x4 conversion
I thought about doing the same thing but opted against it. When I had the frame stripped of the everything but the front and rear axles and I was sandblasting it I found out home much flex a frame like this has built into it. I was afraid I would end up altering that engineered flex and run the risk of a stiff section causing the frame to crack later on.
I opted for keeping my 4WD frame and drilling it to fit the 2WD front end member.
07 Chev 2500HD Classic
Project Ranch Hand, Hauling A$$ since 1973
I was told this Project had a L-72 427 425HP, It did not.
It does have a 427 block and parts from various 427 motors. It will end up with a nice strong 454 in the end.
It has not been run for 20+ years
Frame up restoration started2/15/2010
dgodecke is offline   Reply With Quote
