Old 10-26-2010, 11:29 AM   #26
gontek
Re: Motor Pulling SOB
Kyle G in the OP area code 913
1970 Chevy C-10
1999 Chevy Tahoe LT
gontek is offline   Reply With Quote
Old 10-27-2010, 08:16 PM   #27
westofb
I really hate wet sanding!
westofb's Avatar
Originally Posted by raycow View Post
Not when you are trying to put it back together. Try bolting the transmission to the engine both in and out of the truck and you will know why.
Ray
Done many times, it is easier and cheaper to leave the trans in the truck....this isn't rocket science, pretty simple infact. Why mess with unhooking all the trans stuff (linkage, driveshaft, etc) and loose a considerable amount of trans fluid in the process. Only 6 bell housing bolts and 3 or 4 convertor bolts to remove.
Jeff,
68 C-10
75 C-20, now a C-10!
10 F-150
westofb is offline   Reply With Quote
Old 10-27-2010, 08:22 PM   #28
bigguy69
dazed and confused
bigguy69's Avatar
i agree, leave the trans in the truck i usually dont have a problem gettin everything back together.
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 10-27-2010, 08:34 PM   #29
Red Ron
Red Ron's Avatar
While you remember where the wires go mark it on masking tape wrap around wires. One hour a day I would forget. Mine only has a few... But still. Have FUN!
Red Ron is offline   Reply With Quote
Old 07-20-2011, 06:08 PM   #30
gontek
An hour a day was way too much an estimate of how much time I had. Since then we had a winter where I didn't want to go in my garage much, I adopted one kid, had another kid through birth (well my wife did the birthing), changed jobs (which will free up my time better).
So where I am at now, I am going this friday to pick up the block from the guys who bored and honed it and polished the crank. I am also getting my kit from them so maybe in another year (or hopefully by october) I will have the engine back in and running. My garage time will still be limited for a while by the excessive heat.
I do need to finish this project now that I have another car project to work on sitting in my driveway - a '83 diesel benz that I intend to be my commute to work car. That is a story for another forum though.
1970 Chevy C-10
1999 Chevy Tahoe LT
Old 07-20-2011, 09:12 PM   #31
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Ray
What?! I have, several times in a small garage and it is easy. Just get the dowel pins lined up and some bolts in. A bottle jack & some wood under the pan makes lining it up simple. Then bolt the engine to the engine mounts.
Like everyone else says, unless the trans needs to come out, just leave it in the truck. A 2x4 the right length between the frame rails works nicely to support the trans if you need to move the truck while the engine out.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
