Old 06-30-2010, 07:55 PM   #1
Trick76
Living la vida broka
Trick76's Avatar
Re: TBI bogging?
on my 88 you had to remove a plastic cover over the fuseblock and there was a tan wire with a connector, running toward the brake booster. disconnect it, time the truck, restart and voila!! yeah its like 15-20 degrees retarded if you dont do that, even worse with a cam, lol.
Derek
1976 C10 Longbed lowered 5/7, hot 355/TH350. ~ SOLD
1974 C10 Shortbed Stepside 350/Saginaw ~ SOLD
1984 C10 Longbed 6.2l diesel 700r4. ~SOLD
1985 GMC C20 350 700r4, ~under the knife
Trick76 is offline   Reply With Quote
Old 06-30-2010, 11:36 PM   #2
Kmart2352
Kmart2352's Avatar
Re: TBI bogging?
i unpluged that tan wire and the truck would not start. There was no gas going in the throttle body.
87 2wd GMC Sierra Classic.
86 4wd GMC Sierra Classic.
95 2wd GMC Sierra.
96 2wd Chevrolet S-10.
Kmart2352 is offline   Reply With Quote
Old 07-01-2010, 12:11 AM   #3
chevymotocross
chevymotocross's Avatar
Re: TBI bogging?
Hmm, maybe the wrong wire? I remember on my 87', the wire being tan with a black stripe. You had to look real close. I'll double check mine and snap a photo if you'd like. One was already posted I see but I could snap one a bit more detailed.
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 07-01-2010, 05:22 PM   #4
Kmart2352
Kmart2352's Avatar
Re: TBI bogging?
I changed the the tps and the temp sensor and it is running better but it is still using to much gas.
95 2wd GMC Sierra.
Old 07-01-2010, 08:52 PM   #5
Trick76
Trick76's Avatar
Re: TBI bogging?
if you removed the distributor and set the timing without unplugging that wire, the timing is wrong. no matter the other issues, you definitely need to address the timing. heres a link for ya
http://westersgarage.eidnet.org/Set%...structions.pdf
Old 07-01-2010, 10:59 PM   #6
Kmart2352
Kmart2352's Avatar
Re: TBI bogging?
thanks i will give it a try this weekend at some point
95 2wd GMC Sierra.
Old 07-11-2010, 02:08 PM   #7
Fer79
Fer79's Avatar
Re: TBI bogging?
I did and it works, but when you connect the cable, the problem returns, if you do not connect my check engine is permanently lit...
I kept it off temporarily...
starting the engine keeps running, but to reverse or drive and motor cutting out...
I can do, help me...
Fer79 is offline   Reply With Quote
