Old 06-30-2010, 10:09 AM   #26
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: What are your favorite modifications to your ride?
Originally Posted by baclay9 View Post
Please tell me more about your steering colum mod. I am fat and need more room. Lol
in a nut shell, you relocate the park/neutral switch at the bottom of the steering column by cutting and relocating the hole in which it mounts to. drilling out the glue in the factory intermidiate shaft so it can then be collapsed a little bit.. re drill new holes and insert plastic rivit. lengthen the steering column mount (that holds the column to the dash) "fingers". the fingers im reffering to are the pieces that holds the aluminum slider piece. then reassemble and adjust shift linkage. easy peazy if you have a cut off wheel with a skinny blade and a welder... pretty hard if you dont have either.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 07-01-2010, 12:31 AM   #27
asphaltburner
asphaltburner's Avatar
Yo! All of them, I guess.
The whole truck is a modification,...it's FRANKENTRUCK!
Perhaps it's the 325hp/411ftlb torque 4blt main 350 that I built for it,...
No,...the rebuilt TH400 with new 1200 sp converter.
NAW,...it's the twinstick, machined NP205!!
A 4.11:1 Dana (Warn locking) and a 5560lb rated full-floater axle really makes it nice,...
33" on 17"s?,...
Great four channel stereo,...
It's a good truck.
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 07-01-2010, 09:24 AM   #28
KQQL IT
At the body shop.
KQQL IT's Avatar
9 inch rear. Cal trac bars. and 325/50 hoosier drag radials.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 07-01-2010, 10:49 AM   #29
dropd80s
dropd80s's Avatar
On my CC dually its a toss up between my semi's and SFBD so far...
dropd80s is offline   Reply With Quote
Old 07-01-2010, 11:02 AM   #30
justpball
justpball's Avatar
Sexy^!
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 07-01-2010, 05:45 PM   #31
dropd80s
dropd80s's Avatar
Man I really like your burb. I wish I could force myself to build something as I drive it and not tear everything down to the frame. The progression and quality of your burb makes me really jealous.
Old 07-01-2010, 05:50 PM   #32
justpball
justpball's Avatar
thanks bro! I fight the urge to tear it all the way down all the time!
87 Crew SWB
Build for the crew
90 burb 2wd
Old 07-01-2010, 06:14 PM   #33
mongoose
mongoose's Avatar
making it 2wd i'd have to say.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 07-01-2010, 06:24 PM   #34
boatpuller
boatpuller's Avatar
without a doubt...vintage air.....it's cool.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 07-01-2010, 10:07 PM   #35
54Caddy
GM Addicted
54Caddy's Avatar
isnt there a vintage air kit for our truck that already have air in them??
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 07-01-2010, 10:20 PM   #36
bigblock73
yeller
bigblock73's Avatar
Great mods guys...keep em coming!
My radio, it was re-worked by S&M Electrotech in Blaine, MN..google them. They did fantastic job, I am super pleased.
bigblock73 is offline   Reply With Quote
Old 07-01-2010, 11:17 PM   #37
Benelli
Watchin the rust grow
Benelli's Avatar
Probably converting the NP203 to a part time and also the front hubs. Bottom end actually has power and gas mileage sky rocketed.
Or the new motor, or the new transmission with the shift kit.
Man, this is tough. One thing is for sure it ain't the damn tires.
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000)
1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000)
1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850)
1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done
2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now
Underneath that rust is a heart of gold
Benelli is offline   Reply With Quote
Old 07-01-2010, 11:34 PM   #38
jrcaprai
I would have to say, having everything shaved, and the best is the 408 roller motor....
jrcaprai is offline   Reply With Quote
Old 07-02-2010, 12:38 AM   #39
jake wells
Talking Re: What are your favorite modifications to your ride?
doing away with the smog crap (we don't have emission testing or inspection here)
putting on a performance edelbrock carb and intake on it.
put on mud and snow tires on it the roads suck here!
and adding a smaller steering wheel as the stock one
rubs my fat roll
and 2.5 true dual straight pipes with 12 inch cherry bombs
that's all
jake wells is offline   Reply With Quote
Old 07-02-2010, 01:18 PM   #40
rare86
Extended cab fanatic
rare86's Avatar
The extended cabs. I know I didnt do them and cant take credit for them, ut they are my favorite mods. Lots of leg room for a fat boy.
If it has a motor, it has my attention.
rare86 is offline   Reply With Quote
Old 07-02-2010, 03:26 PM   #41
ECU PIRATE
ECU PIRATE's Avatar
Mine are some things I have not done yet but plan on doing.........bucket seat / console swap and the 4/6" drop on stock steelies. Also going to convert it to a manual tranny
The Fleet........
68' Camaro - 1st car (restored & still have it)
09' VW Tiguan (Wife's Daily Driver)
14' VW Passat SE TSI (my personal)
14' Ford Edge Sport (Daily Work Vehicle)
73' SWB Stepside - 77K org. miles
74' LWB 454/TH400 - drive train transplant for my (Sold)
98' SWB C1500 W/T - shop truck (Sold)
90' GMC Sierra SLE short step - aka " Jezabelle " (Sold)
ECU PIRATE is offline   Reply With Quote
Old 07-02-2010, 06:58 PM   #42
mooseknuckles
mooseknuckles's Avatar
My favorite mods...I fiberglassed my dashpad. I covered over the trim piece on the front of it to smooth it out with foil tape and cardboard, put tape over the old speaker holes, made the defroster vents the same size, which meant covering up where the vin was, and covered the whole dash with resin and woven fiberglass cloth. do not use the mat stuff unless you want a shag rug look or you like sanding, and then I bondo'ed the hell out of it. It turned out real good, and was really easy to do. dont waste your money buying a crappy looking dashpad...Another fave is my tailgate....after looking at DV8's build, I wanted to do something similar. I wanted it smooth though, but I liked what he did with the letters, but that was too much cutting and welding and it would probably end up warping alot when I was done, so I cut out the chevrolet sign and welded it in the lower right corner and welded a flat sheet of body steel over the rest of the tailgate to make it smooth, and moved the handle to the back. I have pics on my phone that I'll try to upload....
mooseknuckles is offline   Reply With Quote
Old 07-02-2010, 07:06 PM   #43
3r!c84
Badass
3r!c84's Avatar
can we get a pic of both
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 07-02-2010, 08:24 PM   #44
Benelli
Benelli's Avatar
Another of my favorite mods I've done is adding an extra leaf to the rear end, gave it an aggressive stance and it's a lot harder to squat.
