#26 |
Re: Could someone I.D. these axles for me??
I lost count how many were at the junkyard today....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
#27 |
Its basically a set of 1/2 ton's 10 bolt front and 14 bolt rear. they probably have 4.10's with beaing from a k20 tho
on a side note a 14 bolt 9.5/semi float is the same design as a 10/12 bolt and altho its a 14 bolt cover the ring gear still has only 12 bolts holding it to the carrier. the 10.5 full float has the wheel bearings in the end and rather than a C-clip holding the axle shaft, the axle shaft bolts to brake drum. you can remove the axle shaft without taking off the tire or even a lug nut ![]()
1991 V3500 350TBI/4l80/205 D60/14bff - Crew long 1987 IrocZ-28 525 horse/567 Lb Tq 383 1976 K30 on 39.5s One wheel drive thanks to a np203 ![]() and some K5's lol |
